Cold Air Intake
Discussion in 'Performance and Tuning' started by Manofs, Apr 30, 2008.
  1. May 1, 2008 at 12:43 PM
    nagelg
    nagelg Well-Known Member
    George
    Northern Wisconsin
    2015 TRD Sport
    I installed an AFE CAI a couple of days ago. I bought it right so figured WTF try it, can always take it off. The metal box/shield didn't fit and had to be ground some, the holes in the thing didn't match so I had to re-drill and the vacuum hose connection fitting was wrong so I bought the right one at Checkers. What should have been a 45 minute install took a few hours. Major PIA!!
    My son has one on a F-150 and says it's improved his MPG considerably. He doesn't like the noise so he drives more careful to avoid revving it :).
  2. May 1, 2008 at 1:39 PM
    hail-bop Command
    hail-bop Command Well-Known Member
    I Don't Crawl I Haul A$$!
    I dont believe anything is "Bulletproof" against sucking up water except maybe a snorkel.... Volant has an attachment that connecst to their intake system to suck air from the bottom of the vehicle of all places. I dont ever hear anyone say anything about that. I would be more worried about that.
    I read that same story on ToyotaNation and i'm not to sure the author of that story knew what he was talking about. He claimed his engine sucked up water because his exhaust was leaking water,:D Anyways I think any after market intake system can encounter an extreme case and suck up water but its highly unlikely. Tacomas stand pretty high off the ground and you really don't get alot of water splashing up to the grill and in to the radiator...
  3. May 2, 2008 at 3:34 AM
    Zebra
    Zebra Well-Known Member
    Millington, TN
    2008 Tacoma 2.7L 4x2 Reg. Cab 5-speed
    Volant ram air and CAI setup, Fumoto oil drain valve, Pioneer DEH-3900MP
    actually it sucks air in from the very top opening in the front grille on tacomas.
  4. May 2, 2008 at 10:24 AM
    hail-bop Command
    If thats the case then it faces the same problems the URD intake is getting flamed for pretty often. But Volant does make a an attachment that scoops from the bottom.
  5. May 2, 2008 at 10:59 AM
    awoit
    awoit Well-Known Member
    CA
    08 TRD, SR5
    im not too familiar with my engine, but i heard that you have to be careful with CAI because you can get water in them? do i need to be careful?... and also will getting this have any effect on future upgrades like installing an exhaust system or does it have no effect on limiting my upgrades?
  6. May 2, 2008 at 11:03 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    You should not go mudding or do deep water crossing if you go with the URD intake, which is mounted behind the grill. All the other CAI have a mounting similar to the stock air filter, so you don't have to be especially careful, but I still would go through water over the bottom of your door. (I love my truck too much to risk screwing it up.)
    Also, the automatics have some sort of vent that might let water in. I don't know the details, but someone else here could help.
  7. May 2, 2008 at 11:06 AM
    hail-bop Command
    Really? Man somtimes I kick myself for not getting a Manual!:mad:
  8. May 2, 2008 at 11:08 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    Really.
    If you had a manual, you wouldn't have a foot free to kick yourself.
    The auto gets better gas mileage and accelerates faster. I made the right decision.
  9. May 2, 2008 at 11:11 AM
    hail-bop Command
    Seriously?..... The auto is faster, Are you sure...?
    Thats great news
  10. May 2, 2008 at 11:27 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    I don't know about faster, but the autos have a different OD gear so they run lower RPMs than the manuals at highway speed.
    As for the vent.... I dunno... But I do know you need to relocate the breather valve on the rear differential regardless of tranny if you want to do water crossings without sucking water into the gear oil. I have a DIY in the thread in my sig for it. Less than $10 worth of parts IIRC.
  11. May 2, 2008 at 11:32 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    Maybe that was it. I don't drive through water, so my brain turned off when I was reading about it.
  12. May 2, 2008 at 11:36 AM
    hail-bop Command
    From what I though I knew the manuals have more HP? Like 10 or so...
    0-60 The manual should be able to take the auto right....?
  13. May 2, 2008 at 11:42 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    From what I know, all stock 1gr engines produce the same HP.
  14. May 2, 2008 at 11:43 AM
    hail-bop Command
    But what about to the wheels?
  15. May 2, 2008 at 1:06 PM
    #35
    death valley fan
    death valley fan National Champions
    Louisiana
    2007 TRD OFF-ROAD
    lsocoee, have you had any problems with water getting into your intake. I'm on the fence and the water issues are what keeps me from going ahead and buying the URD. If you have no problems in New Orleans then I will definately be ok were I'm at.
  16. May 2, 2008 at 1:15 PM
    #36
    Hotdog
    Hotdog
    Wet Okole Underwear
    Don't know about that.
    I run a drycharger with mine that supposedly helps keep the filter dry. Prior to that, I didn't have any issues. My truck starts up normal every time. I don't offroad much. I've been to the spillway a few times, but not in the past couple weeks. If I did any water crossings, then I wouldn't get it.
  17. May 2, 2008 at 1:20 PM
    #37
    hail-bop Command
    I was cringing when I had the SawZaw to the fire wall of my truck... Even these girls next door were like "That dont sound good on that brand new truck":D
  18. May 2, 2008 at 1:28 PM
    #38
    Hotdog
    Hotdog
    Wet Okole Underwear
    stupid girls.
  19. May 2, 2008 at 3:08 PM
    #39
    Zebra
    Millington, TN
    i've been in some pretty bad rainstorms here in the mid south and no water in the box or wet filter when i've checked
    here is what it looks like on a 2.7L tacoma:
  20. May 3, 2008 at 12:09 AM
    #40
    gsxr3000
    gsxr3000 Well-Known Member
    08 TRD Sport
    OME Lift Kit, TRD S/C CAI EXHAUST
    TRD CAI ...
