Cold Air Intakes. Debunking false claims.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoSauceHB, Apr 18, 2018.
  1. Apr 23, 2018 at 2:26 PM
    #301
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    A engine is basically a multi cyl air pump , so the more air you can efficiently put into it and then force out of it you'll make more hp !!!
    Jckdnls and Dirty Harry like this.
  2. Apr 23, 2018 at 2:28 PM
    #302
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    scotty kilmer does understand the uselessness of a CAI on a fuel injected engine tho
  3. Apr 23, 2018 at 2:29 PM
    #303
    BillsSR5
    bill
    2014 SR5
    that's only true in a carbed engine, not an EFI engine
  4. Apr 23, 2018 at 2:30 PM
    #304
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It's true for both, but the stock intake isn't enough of a restriction to make a difference in this case. Now with FI it would.
    US Marine likes this.
  5. Apr 23, 2018 at 2:32 PM
    #305
    BillsSR5
    bill
    2014 SR5
    the 3rd GEN already comes from the factory with the best designed and functional CAI already in it, why waste more $$ on a debunked aftermarket system when u already paid for the best for the truck designed Toyota engineers for the 3.5l engine
  6. Apr 23, 2018 at 2:35 PM
    #306
    BillsSR5
    bill
    2014 SR5
    the stock efi computer and Mass airflow sensor is designed to operate optimally on how much air the stock intake system gives it, not a bolt on system that only introduces hot air from the engine bay
  7. Apr 23, 2018 at 2:37 PM
    #307
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    What about in a few years when the aftermarket catches up and starts making hiperf parts for it like cyl heads , cams , headers and bigger throttle bodies
    What will you say then ???
    Mully and Speedytech7 like this.
  8. Apr 23, 2018 at 2:38 PM
    #308
    Speedytech7
    No, if that were true it would be PGMFI and no MAF would be required. The MAF tube is sized for the sensor to properly reference the airflow over it. But that doesn't mean you cannot flow more air through that space, at a certain point it will become a restriction. But if you couldn't flow more air then things like superchargers and turbos wouldn't exist. You can put a less restrictive filter in and presumably see gains (however small and useless they may be for their dust intake tradeoff). The EFI adjusts to the volume of air supplied to it.
    Mully and DieselTech1 like this.
  9. Apr 23, 2018 at 2:39 PM
    #309
    BillsSR5
    bill
    2014 SR5
    i'll say its a truck not a drag race car, I don't need it
  10. Apr 23, 2018 at 2:40 PM
    #310
    Speedytech7
    Bill, I think you might want to read how modern EFI systems tune their mixtures and what all the sensors do.
  11. Apr 23, 2018 at 2:42 PM
    #311
    BillsSR5
    bill
    2014 SR5
    those minute gains made by trying to force in more air into system already tuned to use X amount of air from the factory is not worth the effort in the stock engine platform, you will never feel it.
  12. Apr 23, 2018 at 2:46 PM
    #312
    Speedytech7
    Yes, I said that already, I was merely correcting your understanding of how a modern engine management system functions. You made it sound as if they cannot adjust to an increase in airflow. And they don't force more air in unless there is a supercharger or turbo, it allows the engine to DRAW air with less restriction. They have lots of adjustment, I threw a Supercharger on an old ass taco last week and saw major gains from it haha. In this particular case it is absolutely pointless to throw a hot air intake with a freer flowing filter on a third gen, but at WOT they may see a whole 2HP haha
  13. Apr 23, 2018 at 2:47 PM
    #313
    BillsSR5
    bill
    2014 SR5
    Toyko Joe likes this.
  14. Apr 23, 2018 at 2:48 PM
    #314
    BillsSR5
    bill
    2014 SR5
    exactly 2hp hahaha
  15. Apr 23, 2018 at 2:49 PM
    #315
    Speedytech7
    Again Bill, I am not arguing whether these stupid things work we already know they make a very insignificant change very high up in the rev range at the expense of filtration. I was arguing your explanation of why they do/don't work
  16. Apr 23, 2018 at 2:56 PM
    #316
    BillsSR5
    bill
    2014 SR5
    Speedytech7 said>>>>In this particular case it is absolutely pointless to throw a hot air intake with a freer flowing filter on a third gen, but at WOT they may see a whole 2HP haha
  17. Apr 23, 2018 at 2:57 PM
    #317
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    If HP gain is what you're after, and you believe that more/better air flow is the answer, go and buy yourself a supercharger. Shove that air into your cylinders! Whiiiiiiiiine!
    US Marine and BillsSR5 like this.
  18. Apr 23, 2018 at 3:01 PM
    #318
    Blazingbluesport
    Blazingbluesport Well-Known Member
    The OC!
    2016 TRD Sport 4x4 double cab.
    Umm well Toyota does put them in the truck. The TRD performance intake comes with a TRD oiled air filter. And Toyota sells the TRD oiled air filter as a “performance air filter”
    https://www.oempartworld.com/oem-parts/toyota-trd-performance-air-filter-ptr4300083
  19. Apr 23, 2018 at 3:02 PM
    #319
    Speedytech7
    This is all I disagree with, it will operate (negligibly) better with one of these dumb CAI. These sensors don't give a shit what piping and filters are feeding them, if there's more air (however little) then they can adjust for it and you get more power.
    Dirty Harry likes this.
  20. Apr 23, 2018 at 3:05 PM
    #320
    BillsSR5
    bill
    2014 SR5
    Re:
