Cold Air Intakes
Discussion in 'Performance and Tuning' started by Billy Bones, Feb 15, 2011.
  1. Feb 15, 2011 at 3:26 PM
    Billy Bones
    Billy Bones [OP] Member
    NJ
    09 Tacoma 4DR LB
    Hello Everyone, new to this forum dont eat me up!
    Has anyone installed a cold air intake on a 09 Tacoma?
  2. Feb 15, 2011 at 3:30 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    welcome
  3. Feb 15, 2011 at 3:31 PM
    JStradaXR
    JStradaXR Well-Known Member
    Chuy
    Ontario CALI
    06 X Rated
    Everything but boost =[
    i have the trd in truck but its an 06. but im sure its the same...
  4. Feb 15, 2011 at 3:33 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    its even colder when you put ice in your air box
  5. Feb 15, 2011 at 3:35 PM
    Billy Bones
    NJ
    09 Tacoma 4DR LB
    Wanted to see if its worth it! Looking for a boost!
  6. Feb 16, 2011 at 5:32 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    He's got an 09, no APR for you!! :D
  7. Feb 16, 2011 at 9:23 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    If you want a boost get a supercharger. Everything else is a waste of money IMO!
  8. Feb 19, 2011 at 10:03 AM
    toddt
    toddt Well-Known Member
    todd
    Houston, TX
    2011 D-cab 4x4 TRD OffRoad
    TRD Supercharger, TRD cold air intake, TRD Sport Hood, TRD Exhaust, Pro Comp 6" lift
    TRD's newest intake dyno'd 10.x HP increase on 4.0L tacoma. It dyno'd over 20HP on over 20tq on s/c'd tacomas. TRD never published the results.
    I put mine on because on a supercharged vehicle it makes the engine bay look 100x better and my tacoma is used for show fairly often. They look ugly with the stock intake.
    I have sold quite a few of them to 4.0L owners, nobody has ever told me it was "just noise" ... i do hear that from exhaust owners though.
  9. Feb 19, 2011 at 10:10 AM
    Sproulesxrunner
    Sproulesxrunner Well-Known Member
    Canada
    08 Xrunner
    Too much for TW to know
  10. Feb 19, 2011 at 2:16 PM
    Sawick
    Sawick Still not worthy!
    JB MDL, NJ
    16 TRD Sport
    T4R TRD Pro Wheels, LED lights, Tonneau Cover, ICI running boards, AVS window/bug
    I put my aFe Pro Dry stage 2 on the other day. I can hear it pretty good after about 3.5k rpms. I guess it gives a slightly better response. I really just like the way it looks over the stock one though. Guess thats really all that matters anyhow, if "you" like it.
  11. Feb 22, 2011 at 8:14 PM
    dspills
    dspills Member
    Dustin
    09 TRD Sport V6 4WD
    I'm not gonna bash anyone on here but I'll say this I do a TON of research before I spend my cash on anything for my taco. The first thing I put on was a CAI. After a lot of research and though I went with the URD CAI w/o the MAF calibrator (for now). It's not loud at all unless you really get on the pedal and and when you do hear it, wow it sounds great. Now as far as everything else... I'm not sure on exact mpg increase but I'll say this I increased my total miles per full tank by an average of 76 miles/tank, throttle response has increased and power has some but not as much as you would think. After I get the calibrator it will even get better. All of these other guys that have CAI aren't truly getting cold air, the air that comes from a design where your filter is in front of your vehicle runs about 30 degrees cooler than inside your wheel well or inside the engine compartment itself where the air is stagnant. I'm done with my soap box to make it short hell yeah its worth it
  12. Feb 23, 2011 at 6:18 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Just a couple of notes on your post:
    • MAF cali only has an affect on the engine when in OPEN loop mode (start-up, 90%+ throttle or so), so mpg increase with MAF cali not likely, depending on your driving habits. Increased performance at full throttle, yes, should be.
    • Did you get the CAI before, or after getting 10k miles on the clock? I see quite a few CAI mpg claims by new(er) trucks, and suspect some of the mpg gains to be just break in mpg's. fyi, I noticed an unexplained mpg jump at about 7k miles on my stock truck.
    • As for temps, I've run stock, this , and an AFE. I've noticed no more than a 3-4 degree difference in all of those, and no mpg gains/losses. While I agree an in-engine-bay intake could reach 30 degrees difference, not so on the ones I've used.
  13. Feb 24, 2011 at 9:39 PM
    dspills
    dspills Member
    Dustin
    09 TRD Sport V6 4WD
    I got the CAI after 42k on my truck. Im not positive if the calibrator will make that big of a difference but since im gonna be running 35's any xtra help will be appreciated, or I could regear I guess.
