Cold climate package - how to tell?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tomrad, Jan 29, 2024.
  1. Jan 29, 2024 at 5:01 PM
    tomrad
    tomrad [OP] Well-Known Member
    2008 Tacoma Access cab, automatic 4x4
    I ordered a new wiper 'transmission' (linkage), and see there are two part numbers available, 85150-04042 (cold climate spec) and 85150-04052 (standard spec).
    Does anyone know the difference in these two parts? Same motor is used on cold and standard, so I'm assuming there's some difference in the 'transmission' (or, linkage).
    Or, is there some way to tel from the data plate on the truck or from the state where it was sold new?
    I ordered the 'cold climate spec' part just in case.
    Thanks!
  2. Jan 29, 2024 at 5:14 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    as I understand it, it is a beefer unit to deal with the extra weight of snow and ice
    I would assume most of Canada and the Rust Belt get them
    the build sheet for the VIN at Toyota would list it I think
  3. Jan 29, 2024 at 5:40 PM
    tomrad
    Thanks. I checked the info from the Toyota owner site and it doesn't mention it so I'll assume it's standard type. Thanks!
  4. Sep 18, 2024 at 12:48 AM
    MarkNap128
    MarkNap128 Well-Known Member
    Mark
    West Warwick RI
    2013 Black Tacoma TRD Sport 4x4 dbl cab
    None
    Hey man
    can you tell me what parts that transmission came with? I’m trying to get the bolts that lock it into the body of the truck as well as those large cushion like washers. Thanks
  5. Sep 19, 2024 at 10:02 AM
    tomrad
    It didn’t come with bolts, but it did have the rubber bushings.
