Cold clutch
Discussion in '4 Cylinder' started by ACBWV91, Feb 12, 2012.
  1. Feb 12, 2012 at 6:46 PM
    ACBWV91
    ACBWV91 [OP] Well-Known Member
    Adam
    Charleston/Motown WV
    08 Access Cab 4x4
    So ive had the truck about 6 months now and now that the snow and cold have come, the clutch is acting funny. When I press it in, it should come back just as quick as my foot does, but it doesnt. It doesnt take too much longer but it is significant enough to ask about...
    Anyone else have this problem? Solutions?
    Another related question. How long is too long to be on the clutch. When I first got the truck, it was a clunky ride because of user error (i would let out too fast not wanting to burn it up). I can now shift smoothly but i do have to ease it out a little slower and want to know if there is a rule of thumb... Thanks
  2. Feb 12, 2012 at 9:09 PM
    19thHole
    19thHole Active Member
    NW Arkansas
    '12 AC MGM Prerunner I4
    I would think this has to do with the fluids of the master cylinder being too cold and maybe condensing? Not sure the exact cause but I am pretty sure it has to do withthe master cylinder and/or hoses
  3. Feb 12, 2012 at 9:14 PM
    19thHole
    NW Arkansas
    On my phone so I can't edit.
    I had a problem like this and it turned out my clutch master hose was leaking. It had gotten to the point that the clutch would some times not pop back after shifting.
  4. Feb 12, 2012 at 9:26 PM
    hXcCorey
    hXcCorey Member
    Corey
    So. Dak.
    Does the clutch feel normal after your truck warms up? Mine can feel sluggish if the temps get below 10 degree (F), but it gets back to normal within a few minutes.
  5. Feb 12, 2012 at 10:05 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    x2 I've had this happen when the temps get into the single digits. Once it warms up it's fine.
