Cold COLD raises some issues. A little help??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AlaskanTaco, Nov 21, 2011.
  1. Nov 21, 2011 at 9:41 PM
    AlaskanTaco
    AlaskanTaco [OP] Well-Known Member
    Anchorage Alaska
    09 sr5 acc cab tacoma
    Hey guys,
    So, here in Anchorage, it has been averaging about -10 here. With this, I have had a VERY easy frozen driver window. It won't even snow, and it will be frozen shut. We had a high of 15 today without any snow, it would hardly budge. Looks like it is frozen to the water seal. Anyone had this issue??
    Also, a frozen clutch? I press it in, and I could Pop the clutch, and it takes about a full second to come all the way back up. Usually takes a few miles before it is fine. Anyone else???
    AlaskanTaco
  2. Nov 21, 2011 at 9:43 PM
    4x4jeep
    4x4jeep Well-Known Member
    Kyle
    Destin FL.
    Wow it was 78 F here today. Bump for somebody that knows the cold
  3. Nov 21, 2011 at 9:54 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    Do you have a block heater, would highly recomend one for that kind of cold. Your fluids are close to freezing so your truck needs a long time to warm up. Dont know a solution to frozen clutch. For the windows i never roll them down in that kind of cold. Try scraping them off and heating up the rubber seal with a heat gun or blow dryer. Ive had doors and locks frozen shut before, riped off part of the paint. Winters are brutal on all cars. Take the time to make sure its warmed up.
  4. Nov 21, 2011 at 10:01 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Might try coating your rubber seals in some WD-40 or something similar to keep them from freezing and sticking to you window
  5. Nov 21, 2011 at 10:13 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Yeah I've had the clutch thing happen one 5* morning (thats about as cold as it gets here). You just gotta let it warm up for a bit on those mornings. Also definitely get a block heater, that oil is like molasses at that temp and cant lubricate the engine like it should, causing substantial engine wear.
  6. Nov 21, 2011 at 10:18 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    my clutch does that also too and gets back to normal after driving a few miles. My truck sits in a garage at night. Im in the biglake area and commute to anchorage, this morning it was -15 at my house. also this is not the time to be washing your truck until it warms up bit. Its weird we jumped right into january weather in freaking nov.
  7. Nov 21, 2011 at 10:24 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    Wow...sooo glad I live in FL
  8. Nov 21, 2011 at 10:29 PM
    AlaskanTaco
    Anchorage Alaska
    907taco. This winter has been crazy! I have an interior warmer, and a oil pan heater. Working on getting a block heater.
    AlaskanTaco
  9. Nov 21, 2011 at 10:57 PM
    Joe D
    Joe D .
    Mid 70s here right now but, used to live in the cold.
    Anywhot, the clutch is hydrulicly actuated so I would expect it to be stiff on first few uses after a good cold soak. If it were actually frozen, I would be it would not move at all.
    As far as the window, I'd attempt a very fine layer of thin lube.
  10. Nov 21, 2011 at 11:06 PM
    AlaskanTaco
    Anchorage Alaska
    Is the hydraulic clutch driven off of the brake res. too?? If not, where is the clutch res??
    AlaskanTaco
  11. Nov 21, 2011 at 11:08 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    no, its a smaller res by the brake master cylinder.
  12. Nov 21, 2011 at 11:11 PM
    AlaskanTaco
    Anchorage Alaska
    I don't see any res next to it?? It is just a line that goes from the brake res, into the bulkhead where the clutch res should be. This is an I4 btw
    AlaskanTaco
  13. Nov 21, 2011 at 11:29 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    oh just noticed this is a 2nd gen:eek:
    Sorry Im no help in that area. Maybe someone will chime in.
  14. Nov 22, 2011 at 12:00 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    You betcha someone will.:) Yup the 2nd gen Tacomas use the same reservior for the clutch as the brake - the small portion in front is divided off internally.:cool:
  15. Nov 22, 2011 at 12:24 AM
    GVY
    GVY All those moments will be lost in time
    Guy
    FT Bragg
    98 Tacoma 2.7L SR5
    Bushwacker Cut-Out Fender Flares, ARB Winch Bull Bar, 3" All Pro Bilstein Coilovers, All Pro UCAs, Wheeler Off Road Custom Rear Bumper, All Pro Standard Leaf Pack, Bilstein 5125 rear shocks, All Pro steel-braided brake lines, U-Bolt flip kit, JBA cat-back exhaust, KC 6" Daylighters & 2x6" driving lights, AFE Pro Dry Air Filter, Deck plate mod, Toytec 1" shackles, Rhinolined bed, Tiregate Prerunner, Procomp 85 gloss black steel wheels, 285/75/16 Toyo Open Country M/Ts
    Had the same issues in Fairbanks. Just gotta let all the fluids warm up, even with having the block, oil pan, and battery heater. These vehicles aren't really made for -50 deg. Best advice, get an Auto Start so it's ready by the time you leave for work.
  16. Nov 22, 2011 at 12:56 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    My clutch has been very stiff at 0* but no issues as far as actually driving in it.
  17. Nov 22, 2011 at 2:36 AM
    reg boulette
    reg boulette Well-Known Member
    -start using 0W40 synthetic oil
    -switch to synthetic for all fluids
    -your clutch will continue to be stiff for a few miles-no fix. At -40 this will be longer. You will have to get good at 'timing' (used to actually count off) when the clutch comes up and reaches release point.
    -red optima battery on next change
    -battery blanket
    -block heater for sure
    -isopropyl gas line antifreeze (not methyl)
  18. Nov 22, 2011 at 8:07 AM
    Takeem029
    Takeem029 Well-Known Member
    The interior warmer may be the problem with the window freezing, depending on how warm it gets the cab. It may be causing some moisture around the seals. You need to get a block heater and get it on a timer. I had 24 below yesterday morning and my clutch was stiff as well. That's just part of living in this great state. I had my clutch plate freeze to my flywheel one time in Cantwell. Not Fun!
  19. Nov 22, 2011 at 9:33 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Ditto.
    Sounds like moisture got in the window seal and froze in the middle of the night. Hit the center of the window squarely with your fist a few times. That's usually enough to break the ice and let the window move.
    Don't be a pussy about it either. It takes a lot to bust a window.
    For the love of god though, don't have keys in your hand when you do it.
    Second, sounds like your vehicle isn't winterized. Get on that shit ASAP.
  20. Nov 22, 2011 at 9:42 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    below ZERO???!!!
    holy crap, i would die. i wore shorts yesterday. i need to visit alaska soon...look for the guy wearing way to much down clothing..
