Cold COLD raises some issues. A little help??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AlaskanTaco, Nov 21, 2011.
  1. Nov 22, 2011 at 10:11 AM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    -23 is nice weather round here u dont really need to start pluggin in till around -30 and all you need is a block heater and decent battery, optimas are now overpriced crap btw they were bought out and the qaulity went downhill
  2. Nov 22, 2011 at 10:57 AM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    I've seen mornings down to -33 here, never plugged the truck, no problems (that's -33 celcius btw)
  3. Nov 22, 2011 at 10:58 AM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    82 in Panama City Beach :)
  4. Nov 22, 2011 at 11:09 AM
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    This happens to me all the time in the winter. The window will thaw and be movable if you get it warm enough - the problem is frozen condensation forming on the joint between the window and the seal. Don't hit the window - thats a good way to break it. You can sometimes get a credit card in there and work that along if the ice isn't too thick. A hair dryer works well if you really need it open.
    Run the heater with the AC on the dry out your interior and this should abate.
    The clutch thing is just it being cold. Let the truck idle for a few minutes before moving and it will loosen up.
    My favorite part is how the shocks get stiff and the truck rides like shit.
  5. Nov 22, 2011 at 12:39 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    you can try using rainx on the windows too. works here in mass. inside and out. dont bother with the windshield i hate it for that but works great for frozen to the gasket windows. if you have problems with the door gaskets freezing use a little rub of any silicone clear grease and wipe off the excess. this also keeps you from not getting into your vehicles in the wintertime... ymmv good luck
  6. Nov 22, 2011 at 4:50 PM
    AlaskanTaco
    AlaskanTaco [OP] Well-Known Member
    Anchorage Alaska
    09 sr5 acc cab tacoma
    FYI, when you put your vehicle on defrost, it uses the ac to de-humidify your interior. So, there is no reason why you need to turn on the ac.
    AlaskanTaco
  7. Nov 22, 2011 at 5:11 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    at the end of the day all vehicles are subject to this in cold weather, when i worked up on the north slope in -30 ambient temps with wind chill temps regularly in the -60's, we kept our vehicles running 24hrs./day heat on high etc...... diesels with high idle kits on them for sitting for extended periods, the transmissions would be shit for shifting gears along with the normal, we had this one truck that was a stick shift it was my assigned vehicle and the clutch peddle was almost non existent, push in and it would stick then pop up, what a pain in the ass it was to drive in those temps. maintenance is key for any vehicle in cold or hot temps. ample warm up time and never wash vehicle in extreme cold temps. ive had door locks freeze, tailgates, hoods and gas doors freeze and it all sucks.
  8. Nov 22, 2011 at 5:49 PM
    muisejt
    muisejt Well-Known Member
    YMM
    08 TRD Sport DC LB
    Katzkin, Bi-xenon Morimoto Mini Stage III Kit (D2S), 4Runner Mirrors, Complete Stereo Upgrade with Backup Camera, Pop&Lock PL5400, Extang Solid Fold Tonneau, TRD OR Tow Hook, rcbs204 4x4 Illuminated Switch, Grillcraft, 10" Rigid light bar behind grill, relocated horns, Redline Tuning hood struts, 5100's with 883 and Wheeler 5 leaf, OME carrier barring drop kit, ECGS Bushing, MarionB2B front hubs
    my windows freeze from time to time, I just bang the ice scrapper on it a few times and it breaks free
  9. Feb 13, 2012 at 6:35 AM
    warrior79
    warrior79 Member
    baltimore
    ARE Cap
    Hi everyone,
    My first post along with my first Toyota, a 2012 Tacoma Sport DC 4x4. At less than 1000 mi on the clock I have exerpienced the frozen window seals mentioned here. I'm in Baltimore, MD a very mild region in comparison to most, but including today I have had issues with my windows lowering at any temp 30 and below. I haven't washed the truck or had precipitation when this occurs. It is frosty in the mornings pre dawn when I go to work. Problem is I have to show an ID two times when entering my workplace and have had to stop and get out of my truck because the windows are frozen/stuck. At least two times the driver window did open after a momentary pause followed by a very disturbing loud bang. I know better than to do that again. I could spray silicone on the outer seal but don't want that mess all over the windows when they do lower. Rain X is on the windows now and has not helped. I am about to call the dealer but really don't have time to run out there with the job and family demands.
    Has anyone been to the dealer for this problem? and if they had a fix, what did they do?
    Thanks,
    warrior79
