Cold Door Rattle?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Plannerman99, Mar 13, 2012.
  1. Mar 13, 2012 at 9:08 AM
    Plannerman99
    Plannerman99 [OP] Well-Known Member
    So Cal
    Our Adventure Vehicle
    Over the last few weeks, my driver's door has started squeaking or rattling, but only when the outside ambient temperature drops below 56 degrees F. I'm assuming that the rubber molding is either shrinking in the cold or becoming less compliant, thus causing the noise. I've tried cleaning it and am considering whether some type of lubrication or oil might help.
    Does anyone have any ideas on how to address this?
  2. Mar 13, 2012 at 9:32 AM
    XPOTRPR
    XPOTRPR EXPOtrooper
    Moose
    Chandler, AZ
    Mid-Travel, Boosted, Expo Taco
    CHECK BUILD
    I've thought this forever myself. When it gets warm here in az, my truck doeent have a single rattle. Only when its cold. Like everything Is stiff. I've used some lithium grease on the more problematic areas. It seemed to help, but there's still the occasional squeak or rattle. It's kinda. Learned to live with it. I mean Its only cold here for a few months. lol
  3. Mar 13, 2012 at 1:12 PM
    over60
    over60 "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Try to spray some silicone lub. on a rag and wet down the weather stripping.... I bet that works... We have to do that up here in the Great White & Cold North, or the weather stripping will freeze to the door frame....
    It works...
