Cold feet about larger tires...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MasterPenguins, Jul 21, 2016.
  1. Jul 25, 2016 at 3:48 PM
    #121
    SamSin
    SamSin I can resist everything except temptation
    Jersey Sam
    NJ
    Longbed 4x4 SR5
    Oil Free AFE Pro Dry S Air Filter, Nitrogen filled tires, Tonno Pro Tri-Fold Hard Tonneau Cover BLU Logic Handsfree
    I replaced the rear shocks on my 2011 SR5 this weekend with the Monroe OE Spectrums and when removing my rear tires I noticed they needed to be replaced
    Going to box store that starts with Wal, their policy is that they will only mount the recommended size as indicated on the inside door panel which read 245/75/16. I wanted a larger tire and I went with four 265/75R/16 Sumitoma Encounter HT (60,000 mile) at $127 each a local tire dealer. It isn't an aggressive tire (I thought with a more aggressive tread I would use more gas, but I could be wrong), it is an all-season highway tread that holds the road well, and is very quiet. I notice with the larger tire, I hardly have any lean as I did with the smaller tire . . which I still had with the new shocks installed.
    The sky opened up as soon as I drove out of the tire dealer and it poured, and these tires perform very well in wet weather. I did no mods or lifts, the truck is stock and the tire fits comfortably without rubbing or any trimming of the mud guards.
    It is about 1" larger height wise giving the truck added ground clearance and the 65's are narrower than the 70's . . . I did not want a wider tire. What I did notice is that the larger tire now exactly matches the speed on my GPS! As Marshall R mentioned the 265/75R/16 is less expensive than a 265/70/16 and also not as wide. I wanted a higher tire and not the width or a 70.
    I'm posting this for those who are hesitating on going to a larger tire size.
    They fit in the wheel well, the truck sits higher, less lean, quiet, less bounce, smoother ride, no trimming or need of lift to fit, and as an added bonus (for me at least) the truck looks great with the larger size.
    For an extra $100 I had a wheel alignment, which I always do when I replace my tires, why spend the money on new tires only to have them wear out before their time?
    That's my story and I'm sticking to it. http://www.sumitomotire.com/trucks/products/Encounter/EncounterHT.aspx
  2. Sep 18, 2016 at 9:28 AM
    #122
    octant
    octant Member
    San Diego
    2016 white 4X4 ACOF
    You're right about what makes you happy, unless the truck is strictly a work truck. I leveled my truck and it's not really how I wanted it to turn out. The 3rd gen tacoma is a bigger truck and 33s seem a little small on it to me. So now I'm waiting for my parts to come in and get my 35s put on.
  3. Sep 18, 2016 at 9:35 AM
    #123
    Erie Co Tacoma
    Erie Co Tacoma Well-Known Member
    Bro
    Bro Land
    2016 TRD Offroad fully loaded
    6 inch procomp stage 2 lift 35 inch procomp ExtremeMTs on 18x9 rockstar 2 wheels
    Send some pics when you get it done.
    octant likes this.
  4. Sep 18, 2016 at 10:17 AM
    #124
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Pic ?
  5. Sep 18, 2016 at 11:05 AM
    #125
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    How will going up one size in tires effect the speedometer reading from the middle display? I tend to use that because it is dead accurate compared to the actual speedo which is about -2mph off anyway - reads 68mph when going 70mph.
  6. Sep 18, 2016 at 11:27 AM
    #126
    Frito
    Frito Well-Known Member
    Run what ya got, no shame in that. It will give you time to think about what you want in the next 30 or 40 K miles. :anonymous:
  7. Sep 18, 2016 at 11:44 AM
    #127
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    https://www.tacomaworld.com/tirecalc
  8. Sep 18, 2016 at 11:49 AM
    #128
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Yes, I'm aware of how to calculate the size difference. I've read the thread and I realize that the speedo will be corrected with larger tires. I'm asking how/if the electronic speed readout (from the middle display) will be effected.
    The electronic readout is dead accurate on my truck, compared to the incorrect speedometer.
  9. Sep 18, 2016 at 11:53 AM
    #129
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    The needle and the digital display are connected together. A 5% bigger tire will read 5% slow
  10. Sep 18, 2016 at 2:18 PM
    #130
    smitty99
    Scottsdale
    They're the same thing man.
    OkTacoTRD likes this.
  11. Oct 13, 2017 at 12:13 PM
    #131
    sxe4533
    sxe4533 Well-Known Member
    Edmond, OK
    2016 TRDORDCSBAT
    2015 TRD PRO suspension
    I use the middle display exclusively since my analog display started jumping all over the place one day on the highway and couldn't tell how fast I was going. When I set my cruise control to 78 my waze app showes 80-81 so I'm hoping once I install the 75's this should be fixed
