Cold feet!
Discussion in 'Suspension' started by Taco Guy11, Mar 1, 2012.
  1. Mar 1, 2012 at 1:54 PM
    Taco Guy11
    Taco Guy11 [OP] Well-Known Member
    Joe
    Western Maryland
    2020 Tacoma TRD off-road
    So i have my 3" lift Billys 5100 and 2" aal. The lift is to be installed Tuesday, but after reading things on here im getting scared. My truck has 9k on it and no problems yet. I hear horror storys of vibs on here. The biggest one that is scaring me away is the front diff since the lift with screw my warranty. Has anyone had a 3" lift go on with success with no front diff vibs? Thanks
  2. Mar 1, 2012 at 2:15 PM
    aidenhardcore
    aidenhardcore Well-Known Member
    mike
    boston,ma
    2017 trd off road
    None yet but soon all black.
    I feel your pain. I was the same way. I have an ome 3 in getting installed next week and should know if i get vibes or not. Its the cons of getting a lift. Some people have it and some people don t. It shouldn't be that bad and about the warranty. I have only 20,000k on my truck and its going to void only the parts you replace i think. So if you change the shocks,spring and aals then they wont cover them. But you should be ok with the other parts. Just dont go hardcore offroading and you'll be fine. Dont worry.
  3. Mar 1, 2012 at 2:18 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    Vibes.. Some people get them, and some people don't.. From what I have read, guys who buy the identical lift may get a vibe of some sort, and the other won't. I am not worried about my truck getting vibes,... I'm about to pull the trigger on the OME 3" lift in a few days!!!! I can't wait till I make that call :)
  4. Mar 1, 2012 at 2:19 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You'll probably get some kind of vibe you may or may not figure out a way to fix OP
  5. Mar 1, 2012 at 2:20 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    my 2012 has a bit of a vibe on take off sitting stock, my 08 with billstein 51000's and eibachs with 1.5'' AAL did not. I wouldn't worry about it whatsoever, there are fixes for vibes.
  6. Mar 1, 2012 at 2:21 PM
    aidenhardcore
    mike
    boston,ma
    2017 trd off road
    Hurry up and make the call lol. I brought from toytec and got shipped the same day.
  7. Mar 1, 2012 at 2:44 PM
    Swampmonkey
    Swampmonkey Well-Known Member
    Wes
    Fairhope, AL
    2011 Prerunner TRD DC
    UWS black low profile toolbox, TRD intake, TRD exhaust, TC uca's, Rear 2" toytec aal, OME Front and Rear shocks, OME 885s, NFABs
    I was the same way. Just do it!
  8. Mar 1, 2012 at 2:47 PM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    You gotta pay to play. You may or may not get any problems, but if you do, prepare to spend more money
  9. Mar 1, 2012 at 4:31 PM
    Taco Guy11
    Joe
    Western Maryland
    Thanks guys for the support I got the 3" kits from toytec 5100's eibachs 2" aal diff drop shims for under the aal and LR UCAs so hopefully it will work out well
  10. Mar 1, 2012 at 4:33 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    East coast gear supply has a fix for those of us with vibes and will be available in a few weeks! Fret not my friends!
  11. Mar 1, 2012 at 4:44 PM
    Taco Guy11
    Joe
    Western Maryland
    Is that for the front diff issue
  12. Mar 1, 2012 at 5:17 PM
    OZ-T
    Peter North
    British Columbia
    Yes
  13. Mar 1, 2012 at 5:21 PM
    jandrews
    '09 FourDubDee TRD OR
    If you want to keep your warranty, don't modify your truck. It's pretty simple.
  14. Mar 1, 2012 at 5:32 PM
    Taco Guy11
    Joe
    Western Maryland
    How did east coast gear fix the problem?
    I'm not really worried about warranty. My only question is does it void the whole warranty or just the parts it modifies
  15. Mar 1, 2012 at 5:37 PM
    ST3VE
    ST3VE IG: @fishsohard
    MD --> SC
    Tint, car seat, baby wipes
    The only parts that will not be covered under warranty is the aftermarket parts you install.
  16. Mar 1, 2012 at 6:10 PM
    jandrews
    Not necessarily. The way the law works, the auto manufacturer can deny warranty coverage to failures caused by the modified/non-OEM parts.
    This is a pretty flexible definition.
    In reality, the manufacturer will probably deny warranty regardless, and hope you aren't willing to take them to arbitration to prove your case. Have fun dealing with that...OR...start doing your own wrenching.
  17. Mar 1, 2012 at 6:13 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Most of your vibes will some from the rear! Usually drivshaft angle from the lift! Lube all the zerk fittings to keep everything smooth as it's mostly the slip yoke/axle wrap type of thing, and hope for the best! I wouldn't worry about the front....diff drops dont do shit, just keep your CV's at good angles 2.5-3" and your fine if 4x! There's a certain amount of "crap" you'll have to put up with to lift a truck....it's worth it!
