Cold idle time 2014 v6
Discussion in 'Technical Chat' started by Bxmarauder, Mar 19, 2016.
  1. Mar 19, 2016 at 5:56 AM
    Bxmarauder
    Bxmarauder [OP] Member
    new york
    2014 Silver Sky Metalic Tacoma Dbl Cab TRD Off Road
    Tonneaupro hard trifold, Bed mat, Bed extender, Nerf bars, interior LEDs pop&lock (elec)
    Seems like the truck takes a long time for the idle to drop
  2. Mar 19, 2016 at 11:47 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It depends how you define long time !!
    Mine can take 15 to 20 minutes at times
    Then what the ambient air temperature is
    After that if the sensors are working correct
    Bxmarauder[OP] likes this.
  3. Mar 19, 2016 at 3:18 PM
    Bxmarauder
    new york
    Thanks 15 to 20 minutes seemed a little long to me but if that's normal COOL!
  4. Mar 19, 2016 at 3:32 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    The faster it comes up to temperature the sooner the idle drops down to normal
    If you were having a abnormal idle the MIL would trip most likely with The PO505 code
  5. Mar 19, 2016 at 3:39 PM
    TN_Tacoma
    TN_Tacoma Well-Known Member
    David
    New Jersey
    07 Taco PreRunner SR5 DCSB
    K&N CAI, MBRP Cat-Back Exhaust, 265-75-16s Nitto Terra Grappler, Tuff A.T. 15s 16 inch wheels, 1.25" wheel spacers, black bumper, bumper light bar in grill, CB radio, Aftermarket speakers and 2 10 inch subs, LED odometer mod
    As mentioned above, It all depends on the ambient air temperature outside. For example during winter it will idle at a higher temperature to warm it's self up.
    15-20 minutes seems like to long for engine to run idle at higher revs than normal.
  6. Mar 20, 2016 at 6:19 AM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    2015 4.0L, auto - Using an Ultra gauge, I let my truck idle until the coolant temp reaches about 100 degrees, takes just a few minutes at 40 degrees, ambient.
    Quicker when temp is higher. When temp reaches 100, I just go.
  7. Mar 20, 2016 at 8:05 AM
    Bxmarauder
    new york
    I have two Chevy's and they warm up much faster, enabling idle to lower quicker,using less gas!
  8. Mar 20, 2016 at 10:59 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I was talking about those balmy days down around 0 degrees F
    then the 3.4 needs to come up to around 192 degrees
    Sometimes one just gets in the truck and leaves .
    If your MIL works and has not tripped you should be good to go.
    The only way to tell for sure is to get real time data of the coolant temp
  9. Mar 20, 2016 at 11:25 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    It's a Toyota thing. My '99 Tacoma and both my Scions (Camry engines) were the same way, especially in cold weather.
  10. Mar 21, 2016 at 3:56 AM
    Bxmarauder
    new york
    Thanks for the peace of mind!
  11. Mar 21, 2016 at 1:03 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I am sorry I might have mentioned this is after sitting about 12 hours outside .
