Cold Start, Brake Stuck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by arthur106, Dec 13, 2024.
  1. Dec 13, 2024 at 11:41 AM
    arthur106
    arthur106 [OP] Well-Known Member
    Jacob
    Houston
    Black '10 SR5 4WD 5MT
    Got in my truck this morning. Started up fine. Released the parking brake and shifted into reverse (MT) and eased off the clutch. No movement. I could feel the truck "tugging" as if held back by something so I figured I had forgotten to release the parking brake. The parking brake was indeed disengaged, so I got out to check if there were any objects wedged under my tires (I've occasionally had this issue as there is a rock bed near my parking spot, sometimes one gets dislodged and finds its way behind a tire). ...nothing. I get back in the truck and really try to give it a good jolt to get moving, rev up to 2500rpm and give the clutch a good "kick". I can feel the truck "tugging" and even feels as if the frame is being "torqued" but no movement. I scratch my head and for the first time try depressing the brake pedal. As soon as I apply pressure, I head a slight "pop" sound from up front and now the truck will roll. I went for a short test drive and observed no adverse conditions.
    Can anyone explain to me what the hell I'm dealing with?
    Edit: More info. It was 50F outside and dry. I don't think it got below 40F last night and it's certainly been colder than that recently without having this issue. Brake lines appeared to be connected with no noticeable leakage. I did observe fresh grease that appears to be leaking out of the boot on the Front Left CV joint. I'll get around to fixing this but I can't imagine it's related.
  2. Dec 14, 2024 at 6:45 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    Sometimes corrosion can "hold" the brakes like this (but I dont think EVER to 2500RPM), or possibly a sticking caliper (Which given the amount of gas you gave it) might be the case. This the first time it "stuck" like this?
  3. Dec 14, 2024 at 12:47 PM
    arthur106
    Jacob
    Houston
    Yeah, first time. It’s a relatively new caliper, maybe 2-3 months old.
  4. Dec 14, 2024 at 12:56 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    My guess is stuck parking brake.
    Check your rear brake condition/shoes/etc. Are the plastic grommets where your parking cables go into the rear drums broken? Can you pull the drums and have a look around?
    MSgt O likes this.
