Cold start engine squeal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pacificclam, Jan 14, 2025.
  1. Jan 14, 2025 at 4:17 PM
    Pacificclam
    Pacificclam [OP] Well-Known Member
    Carl
    Hawaii
    2010 Tacoma 4x4 Access cab
    6” pro comp lift Kings Coils and Shocks 700lbs Element UCA Atlas Leaf spring kit 17x9 stealth custom series ray 10s -38 33x12.5 toyo open country mt Tom woods driveshaft CSF high performance radiator 4.88 GEARS
    when I start my truck first thing in the morning I get this engine squeal. Im wondering if this is my serpentine belt or if it is something else? If i let it run for a few minutes it goes away, but Im curious if changing out my serpentine belt would stop this noise. See video below. Let me know your thoughts, Thanks!
    https://www.youtube.com/shorts/I9c8aWG3A6U
    Black97v6MT likes this.
  2. Jan 14, 2025 at 4:19 PM
    Bishop84
    Bishop84 Well-Known Member
    Why is the belt so glossy? I'd definitely start with the belt.
    drizzoh likes this.
  3. Jan 14, 2025 at 4:22 PM
    Pacificclam
    Carl
    Hawaii
    Im not sure.... and Im also not sure when the last time it was replaced. Im starting with the belt, but didnt know if it might be a pulley or bearing or something else.
  4. Jan 14, 2025 at 4:24 PM
    545 Well-Known Member
    2015 Access Cab
    Cause it’s 15 years old
    lol
    Tacogar61 likes this.
  5. Jan 14, 2025 at 6:44 PM
    Bishop84
    I think its the humidity difference, its 40% here and its considered high lol
  6. Jan 14, 2025 at 6:52 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    If you have 100,000 miles or more on the belt replace it yesterday. If it breaks on you and leaves you stranded on the side of the road it can become an expensive PITA. This isn't one of those repairs that is an easy to DIY on the side of the road. And it could cause further damage. Ask me how I know.
  7. Jan 15, 2025 at 10:18 AM
    Pacificclam
    Carl
    Hawaii
    Im waiting for the belt to come in. Changing it asap.
    Black97v6MT, Tacogar61 and XSplicer62 like this.
  8. Jan 16, 2025 at 5:14 AM
    Tacogar61
    Tacogar61 Active Member
    Garrett
    GA
    2015 DC Sport 6spd 4x4
    Is yours auto or manual? I get a similar squeal on mine that goes away once I push the clutch in. If you have an auto disregard lol.
  9. Jan 16, 2025 at 3:00 PM
    Pacificclam
    Carl
    Hawaii
    I got a manual 5 speed.
  10. Jan 16, 2025 at 8:56 PM
    DailyTacoMD
    DailyTacoMD Well-Known Member
    Jeremiah
    2006 2.7L AC 4x4 5spd
    I’d do the tensioner too just to be safe. Mine has 190k. I did the belt in the summer (high humidity) and a few weeks later the squeal came back. Turned out to be the bearing in the tensioner pulley failing so I did the whole tensioner assembly, the spring inside also softens over time/mileage. The idler pulley bearings can fail too and you can buy those pulleys or bearings individually, fairly inexpensive.
    I’d vote to start with belt & tensioner. If it persists afterwards you can spray some WD40 on the other pulleys individually until you find the culprit (don’t get any on the belt or surface of the pulley). Hopefully it’s not a more expensive problem like ac pulley, alternator pulley, power steering pulley…
    If the belt you take off is worn but not damaged I recommend to save it in the truck somewhere under seat or in one of the back seat cubbies in case you break a belt in the future u can install the old one to limp it to safety and not be stranded.
    Black97v6MT and Pacificclam[OP] like this.
  11. Jan 16, 2025 at 11:42 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    With engine running, try and spray water on the belt. First on the outside, then the inside. If noise stops or significantly changes pitch, then squealing is most likely the belt. If the squealing hardly changes pitch, it is most likely a bad bearing.
    When you have the belt off, check each pulley-bearing for wear. Rotate each one gently; it should spin smoothly. Then, move each pulley side to side and fore and aft. Except for the PS, there should be no play. The PS may have a 1-2 mm fore/aft movement. Test each pulley-bearing that the belt touches.
    In general, it is good preventive maintenance practice to replace the belt and hoses by 150K. Since you’ll be doing a coolant change at that mileage, I’d also replace the thermostat and cap.
  12. Jan 17, 2025 at 5:21 PM
    TacoTuesday1
    FL
    when did you last replace your rotating assembly
  13. Jan 20, 2025 at 9:46 AM
    Pacificclam
    Carl
    Hawaii
    Thanks for the info. Im changing the belt today and will keep all that in mind moving forward.
  14. Jan 20, 2025 at 9:47 AM
    Pacificclam
    Carl
    Hawaii
    Im the second owner of this truck, and I've never replaced the rotating assembly. I will look into it, thanks
  15. Jan 27, 2025 at 1:47 PM
    Pacificclam
    Carl
    Hawaii
    Update: I replaced my serpentine belt, as well as my water pump and the cold start squeal is gone. Thanks everyone for your input.
    Kolter45, drizzoh and Rexfordian13 like this.
  16. Apr 7, 2025 at 6:17 PM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    What caused you to think it was the water pump?
    Mine has been making the same noise for a long time but it goes away during winter, oddly enough. I’ve already replaced the belt. Tensioner, A/C compressor, alternator and all the idlers. Frustrating.
  17. Apr 7, 2025 at 7:11 PM
    Pacificclam
    Carl
    Hawaii
    I had a very slow coolant leak where you could see white dried up coolant drops below the water pump. The coolant would slowly leak and drop onto the belt area which would then cause the squeal. When was the last time you replaced the fan clutch and blades? The fan clutch could be whats causing the noise. I'm surprised it goes away in the winter as my noise mainly came during first start in the morning.
    Black97v6MT and b_r_o like this.
  18. Apr 7, 2025 at 7:31 PM
    Pixeltim
    '15 Black DCLB SR5
    I’ve never done the clutch and blades. When it’s warm out, it’s always squealing.
  19. Apr 8, 2025 at 10:58 AM
    Pacificclam
    Carl
    Hawaii
    Thats strange. Mine is always when its cold in the morning. Once its warm, it didnt happen. Id do a bit more research on the fan clutch. But id also look at if you see any dried up coolant below the pump. It will dry white on metal.
    Pixeltim[QUOTED] likes this.
  20. Apr 8, 2025 at 12:53 PM
    Peter603Taco
    Peter603Taco Well-Known Member
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    Mine also has a high pitched squeal on cold starts, really only in winter and goes away mostly in the summer. Didn't notice it much until I started using a remote starter as I can hear it from the outside more than inside but it's been doing it for over a year now, and belt and idlers were all replaced with OEM. Thinking at this point I should go ahead and do the water pump and fan clutch as I'm almost at 200k anyways
