Cold Start - Fast Idle
Discussion in '4 Cylinder' started by Fast1, Jul 21, 2009.
  1. Jul 21, 2009 at 1:43 PM
    Fast1
    Fast1 [OP] Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    Just purchased a 2.7L and noticed that when cold (even in the summer at 70 degrees) it idles at 2K to 2200 upon start up.
    Then after a few minutes I hear some type of click and the idle slows way down to almost normal hot idle speed. The click almost sounds like the a/c compresssor is being turned off when the idle slows down.
    Is this normal for this engine?
  2. Jul 21, 2009 at 1:56 PM
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    mine idles high on cold start up, around 1000-1100, i think, but nothing like urs!
  3. Jul 21, 2009 at 3:46 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    There are times when mine will fast idle from a dead cold start at 2000 RPM, but it backs down to 1500 or so in a few seconds. The other day on a very hot day that the truck sat out in the direct sun for 8 hours, when I started it, the cold start cycle didn't even happen and it idled at 700 RPM . :eek: If yours is idle is that high for two minutes something is wrong with the cold start cycle of the ECU.
  4. Jul 21, 2009 at 3:50 PM
    MiikeyD
    MiikeyD The Green Machine
    Upland, CA
    Green Prerunner DC 2.7L
    Suspension / Wheels / Tires 3.5" Fabtech lift w/ AAL 265/75/16 BFG A/T American Racing Baja Audio Alpine HU CDA-9886 Kicker DS650 Z-Edition 1000W Memphis M3 US Amps 4000W 2.5Farad Cap Lighting 6000K HID 2 Hella 500FF 2 Aux Bed Lights 2 Aux Driving Lights Performance Volant CAI Flomaster Super 44 Doug Thorley Long Tube headers (coming soon) NGK Iridium Sparkplugs Accessories Scanguage II Cobra LTD27-NW with 3' Firestik Radio Shack Triple Trunking Scanner Harbor Freight Hi-Lift Cosmetics Flat Black Bumper Trim Flat Black Grill Surrounding with Satoshi Clear Corners Future Modifications (not specific) Longtravel w/ king shocks or fox Caged bed Shackles rear suspension. Fox / king shocks custom front bumper Custom Glassworks extreme kit for 01-04 (only have hood and passenger side.. need driver panel) Supercharger + 8port intake manifold optima yellow top battery remounted new rims caged interior rear bench removal 4 sparc
    been idling at less than 1500 but above 700 all day any weather, 2000 seems high IMO
  5. Jul 21, 2009 at 7:05 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    one thing you can do to lower your idel if it bothers you is to buy a Pro dry S filter and remove the secondary charcoal filter. it will lower your idel rpms to about 1000 or even less
  6. Jul 21, 2009 at 7:08 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    mine def. goes up tp abput 2k at cold startup i usually put it in gear b4 if goes down, but putting it in gear drops it
  7. Jul 21, 2009 at 8:16 PM
    Fast1
    Minneapolis, MN
    that is exactly what I've been doing also..
  8. Jul 22, 2009 at 6:00 AM
    sriley727
    sriley727 Well-Known Member
    Aiken, SC
    08 Reg cab PreRunner SR5
    Bone stock
    Sounds normal to me. 2000 may be higher than most people see but its not abnormally high. I'd say you are alright.
  9. Jul 22, 2009 at 6:24 AM
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    Mine does the same thing... always comes down in less than a minute (but I haven't had it in the winter yet)
  10. Jul 22, 2009 at 6:45 AM
    98tacoma27
    Ben
    Not Beech Creek
    Try cleaning your MAF. How many miles are on the trck?
  11. Jul 22, 2009 at 10:00 AM
    Fast1
    Minneapolis, MN
    can you explain to me in techinical terms why a dirty MAF would cause a fast idle only during the first 60 seconds of cold start up?
  12. Jul 22, 2009 at 10:04 AM
    98tacoma27
    Ben
    Not Beech Creek
    It reads air temp and air flow.
  13. Jul 22, 2009 at 1:32 PM
    Fast1
    Minneapolis, MN
    and why would this only impact the engine idle when its cold and not hot?
  14. Jul 22, 2009 at 2:52 PM
    91r100gs
    Dan
    Kansas City area
    In winter under about 30 degrees it may go even higher. I've seen 2500 for a few seconds when it sits out in really cold weather.
  15. Jul 22, 2009 at 3:03 PM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    I wouldn't worry about it. I have the same engine and it tends to idle a bit high for probably 30 seconds or so. The engine does this to warm up quicker.
  16. Jul 22, 2009 at 4:08 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    2019 SR/SX Tacoma Access Cab 4x4 3.5L
    Two reasons why, one is emissions. The faster it warms the less it pollutes. The main reason is poor running concerns. In a cold engine the fuel does not mix well with the air. It will actually pool up rather than turn to vapor. Only the vapor burns, the liquid fuel does not. The faster and engine runs the quicker it warms up.
  17. Jul 23, 2009 at 5:54 AM
    sriley727
    Aiken, SC
    Bone stock
    It wouldn't. The engine runs in closed loop mode when its warming up and doesn't use the signal from the MAF.
  18. Jul 23, 2009 at 6:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No charcoal filter on the first gens.
  19. Jul 23, 2009 at 6:18 AM
    98tacoma27
    Ben
    Not Beech Creek
    Ah-ha!! Is too!!! Mine was in the drivers front wheel well area.
  20. Jul 23, 2009 at 6:19 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    On a 2000 2.7?????
