Cold Start - Fuel issue?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pjf1119, Nov 10, 2017.
  1. Nov 10, 2017 at 3:59 AM
    Pjf1119
    Pjf1119 [OP] Well-Known Member
    Morning all,
    Been a while since I posted last. It's getting a bit colder here in MA and when i went to start my truck this morning it has plenty of crank and runs just fine, however when i turned the key it wanted to start but also acted as it we starving for fuel, it puttered and never fully started. I turned the key off and tried again, after cranking for a few seconds it sputtered, caught and started right up and has run fine since. This is all after sitting for 10 hours or so in high 30 degree temps.
    Any ideas on what might be going on here? Fuel issue? the battery is less than a year old.
    Thanks very much,
    Rambo54 likes this.
  2. Nov 10, 2017 at 5:41 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    When was the last time you changed your spark plugs?
  3. Nov 10, 2017 at 5:45 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Spark plugs?
  4. Nov 10, 2017 at 6:12 AM
    Pjf1119
    Swapped them out probably 8K miles ago with my 90K tune up.
  5. Nov 10, 2017 at 6:13 AM
    DrFunker
    DrFunker Well-Known Member
    Same issue here. Just the truck expressing its displeasure with the coming weather. :D I just gas it a little more to let it know who's boss. :boink:
    a400ryan and Torspd like this.
  6. Nov 10, 2017 at 6:25 AM
    JayRolla
    Colorado Springs
    It could just be the cold weather, but its usually more of a hard crank when it starts getting cold. I would just watch it and see if it gets worse.
  7. Nov 10, 2017 at 6:30 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Have you cleaned the MAF and throttle body recently?
  8. Nov 10, 2017 at 6:53 AM
    Rambo54
    Rambo54 TacomaBob
    Robert
    Eustis,FL
    2013 Nautical Blue Metalic Tacoma PreRunner DCLB
    Many !
    Swith over to a Brand name 100% Fully Synthetic Motor Oil,maybe from a 5W-30 to a 0W-30 for the winter months if under 32F.
  9. Nov 10, 2017 at 7:38 AM
    PackCon
    Connor
    What oil you run has nothing to do with it since no matter what all the oil is sitting in the pan with a cold start up.
    No place in the US gets cold enough for oil to sludge at cold temps, except maybe ontop of Denali in Alaska LOL
    Its sunny with a hi of -51F today.
  10. Nov 10, 2017 at 7:42 AM
    Pigpen
    Dan
    Northwest Montana
    The cold has nothing to do with it, it's a fuel or truck issue. You may have some condensation causing a little water in your fuel, but even that is unlikely.
    Do you drive far enough to rally warm up the engine regularly? How far is your daily commute? Short trips are hard in engines.
  11. Nov 10, 2017 at 9:33 AM
    Larueminati
    Larueminati Well-Known Member
    Western MA.
    2013 DCSB TRD 0FF-ROAD
    Normal, mines always done it here and there since i've owned it.
    Did it today after I drove it to work and it sat for two hours. Hasn't done it probably since last winter. Thats a coincidence.
    EDIT: For what it's worth plugs, cleaning the MAF, new battery, mobile 1 oil, none of that has changed anything. Trucks always done it. Always warm the truck up for ten minutes or so, 25 miles commute each way to work. Can count on one hand how many times it does it in a year.
    I've always chalked it up to something with the pressurized fuel system. Maybe because after 5 hours being off i've heard the pump running on it's own to pressurize the system. I don't worry about it anymore.
  12. Nov 10, 2017 at 9:49 AM
    blu92in99
    blu92in99 Hates everyone, equally
    Justin
    Elk Grove, Ca
    This.
    Most likely fuel pressure is bleeding down more than it should. Probably the check valve in the fuel pump has failed, or an injector is leaking enough to bleed off rest pressure but not enough to cause a drivability problem.
    Sitting for short periods of time, probably never notice it. Let it sit for a few hours or more, acts like a long crank/hard start then sputters for the first few seconds when it finally fires up due to the air in the lines.
    If you have a fuel pressure test gauge with the right adapters, you can isolate sections of the fuel delivery system to narrow down where the potential problem might be.
    Jeffs68 likes this.
  13. Nov 10, 2017 at 9:52 AM
    Pjf1119
    Thanks All,
    My daily commute, while i consider myself lucky, is very short, 4 miles each way so while the truck reaches temperature it doesn't see much road time until the weekend. It's done it very few times so i'd imagine its a result of the changing weather - I just recently moved back from California to Boston so the truck hasn't lived in the cold very much, i keep good care of everything else and it runs like a top otherwise.
    I'll keep an eye on it and try to make sure the truck gets up to temperature and driven especially on the colder days. Any additional suggestions?
    Thanks again, nice to be back on the forums.
    Larueminati likes this.
  14. Nov 10, 2017 at 9:56 AM
    Larueminati
    Western MA.
    If this was the case why would it only do it two maybe three times a year since the truck was brand new? I've also never had it happen consecutively, it's just random then it may happen again 2 months later or maybe 1 year later.
    If it was happening on a regular basis I would think there was a problem somewhere.
  15. Nov 10, 2017 at 10:03 AM
    blu92in99
    Justin
    Elk Grove, Ca
    Intermittent problems are just that; intermittent. They're also the hardest to diagnose, unless it's acting up when you're trying to diagnose it.
    Check valve in the fuel pump might stick occasionally, not all the time. It does this in my Jeep, maybe a handful of times throughout the year it'll act up on a cold-start. I've already confirmed it's the check valve in the pump in my case, but since the pump performs fine otherwise I'm not inclined to spend the time/money to drop the skid plates and the tank to replace the fuel pump until it fails to perform.
    Not saying this is guaranteed to be your issue, just spreading information. Thankfully I haven't had this problem with my Taco yet. Honestly, in your case, unless it becomes a more consistent problem I really wouldn't worry about it.
    Larueminati[QUOTED] likes this.
  16. Nov 10, 2017 at 3:10 PM
    capecodtaco
    capecodtaco Active Member
    Tom
    2014 Spruce Mica SR5
    Stock
    My 14 did the same thing this morning too. I filled the tank at my normal fill up spot, did two short drives then it sat for 2 hrs in the Cape Cod cold. Long crank, had to try it a couple times and it finally started. I drove it about another mile. It sat for 6.5 more hours and started fine. Its a 4.0, 43K, I changed the plugs around 8k back.
  17. Nov 10, 2017 at 5:45 PM
    Larueminati
    Western MA.
    Must be a massachusetts thing. Three guys all on the same day, id say the blustery cold with the wind might have somethin to do with it.
  18. Nov 10, 2017 at 9:16 PM
    atavuss
    atavuss Well-Known Member
    I had an intermittent long crank on a first gen 2.7 4 cylinder, it ended up being the fuel pressure regulator was failing to keep the system presure where it was supposed to be.
  19. Nov 10, 2017 at 9:38 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    X2
  20. Nov 15, 2017 at 3:33 AM
    Pjf1119
    Thanks for the input all,
    everything was fine since my last post. Truck did the same thing this morning, although not as bad. Seem to be intermittent and everything is fine otherwise. I'll keep an eye on it and report back with any updates. Sounds like some others have had similar issues!
    Thanks again,
