cold start humming noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TOMMCINTIRE, Aug 14, 2014.
  1. Aug 14, 2014 at 6:07 PM
    TOMMCINTIRE
    TOMMCINTIRE [OP] New Member
    Tompaw
    Ft Worth Texas
    13 Tacoma 4cyl auto
    ON cold starts, even when outside temp is over 80 degrees, with the auto trans in park, ac and radio off, I get a high pitch humming noise that is pretty loud inside the truck. Seems to be coming from engine area, sounds like a noisy fuel pump, then after 15-20 seconds, I hear a loud "Crunch" noise from engine, and the noise immediately stops. (2013 4 cyl - automatic) 11,800 miles. Any suggestions or ideas on what the noise is. This is my 1st Toyota vehicle.
  2. Aug 14, 2014 at 6:20 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    smog pump air injection system... completely normal.
  3. Aug 14, 2014 at 6:26 PM
    TOMMCINTIRE
    Tompaw
    Ft Worth Texas
    13 Tacoma 4cyl auto
    Thanks !
  4. Aug 15, 2014 at 12:02 AM
    nine3
    nine3 Well-Known Member
    Seattle, WA
    14 DCSB TRD OR Supercharged MT
  5. Aug 15, 2014 at 6:26 AM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    I get the same noise; It appears that the system closes an air valve prior to shutting off the air pump. So what I hear is the humming for about a half minute, the a short rattling (you called it a crunch) sound (1 second), which is basically the air backing up into the pump causing this noise, then the circuit shutting of the pump kicks in, and it's off.
    With the engine running cold, I experimented by squeezing the rubber input hose closed (Simulate the closing of the valve), while the pump ran, and it rattled, released it and the rattle disappeared.
