Cold start knock... Ideas?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EdubTRD, Jan 31, 2017.
  1. Feb 1, 2017 at 8:03 AM
    EdubTRD
    EdubTRD [OP] Well-Known Member
    Eastern NC
    2005 White SR5 2.7 Access Cab
    Now that makes me sick to my stomach. I haven't had the noise happen again the last 2 days. I'll change my oil this weekend, keep driving it and hope for the best...
    Old_Skool likes this.
  2. Feb 1, 2017 at 8:43 AM
    Old_Skool
    Old_Skool Well-Known Member
    Rich
    Maine
    2017 Subaru WRX, Crystal Black Silica
    That's about all you can do. Those two pics were from yesterday...... I'm in the middle of putting it back together right now and am inside warming up...... It's 20* here and snowing. At first all I thought was that I needed to put a $3000 motor in the truck, but once I got over the initial shock I decided to pull the pan. I'm hoping to have dodged the bullet.
  3. Feb 1, 2017 at 1:19 PM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    I would install a gauge and monitor the oil pressure, oil pump failure has killed a few 1gr-fe engines. Check out the thread I linked
    Oil pump failure
  4. Feb 1, 2017 at 2:18 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    Torspd[QUOTED] and ecoterragaia like this.
  5. Feb 1, 2017 at 2:35 PM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    I got chastised a bit in that thread for kinda agreeing with Torspd :)
    @07 sport 4x4, thanks for finding that thread, I was trying earlier today and came up short. My "keyword" skills are not all that great.
    07 sport 4x4 likes this.
  6. Feb 1, 2017 at 2:36 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    I can't ever find threads by searching on here. I did a google search. lol
    ecoterragaia[QUOTED] likes this.
  7. Feb 1, 2017 at 2:37 PM
    ecoterragaia
    Central Virginia
    FWIW, I have run 5w-30 synthetic in my '06 4cyl from day one because that is what the manual calls for (with regard to oil weight), no issues so far.
  8. Feb 1, 2017 at 2:37 PM
    ecoterragaia
    Central Virginia
    Same here . . .
  9. Feb 1, 2017 at 2:39 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    Yeah I'm a believer that a good oil of the specified weight is all that is necessary for a healthy engine. @qnyla has a 400k 1gr-fe that is a testament to that.
    400k
  10. Feb 1, 2017 at 2:55 PM
    EdubTRD
    Eastern NC
    Yeah, I've always done everything exactly to the manufacturers recommendations. Including, oil, oil filter, plugs, etc. I installed a k&n air filter and I service that every other oil change (10k miles).
    Being slightly out of warranty I don't want to take it to a dealer or shop and throw money at it to "try" to diagnose it. I bought a Tacoma specifically for their known dependability, and low cost of ownership / maintenance. Decisions, decisions.
  11. Feb 1, 2017 at 3:15 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    If you were gonna take it to the dealer you'd be better off to grab a used engine out of a salvage vehicle for about 3k and be done with it.
  12. Feb 2, 2017 at 3:13 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    No worries. I get chastized all the time too.
  13. Feb 2, 2017 at 3:55 AM
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    Did it knock years previous at startup during winter? Or was this the first time it started doing it, and it continued to worsen?
  14. Feb 2, 2017 at 5:54 AM
    Old_Skool
    Rich
    Maine
    The end of December was the first time and I then started hearing it just upon start-up. 2 weeks ago while driving to work it suddenly got really loud and pronounced, especially while going up hill under load and while decelerating. I bought the truck in 06/15.
  15. Feb 2, 2017 at 7:34 AM
    #35
    SpeedoJosh
    Florida
    Might be just a coincidence that it happened during winter, and/or a different problem all together. I get the knock, but it always goes away after warm, and only sporadically happens in winter.
  16. Feb 2, 2017 at 9:26 AM
    #36
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Have you guys had the tune reflash? I am just curious if it is gas related and not oil.
  17. Feb 3, 2017 at 8:15 AM
    #37
    jmanscotch
    jmanscotch Well-Known Member
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    Have you explored the possibility of the noise being an exhaust tick? Lots of ole Jeeps I've owned would tick when cold (due to a small exhaust leak at the manifold) and it's go away or calm down significantly once everything warmed up and the leak got slightly sealed up due to heat expanding gaskets/metal. Just a thought I didn't notice mentioned yet.
  18. Dec 9, 2021 at 4:58 AM
    #38
    Hoonigan82
    Hoonigan82 Active Member
    Max
    2008 Red Tacoma SR5
    Spyder headlights, caliraisedled fog light to light pod conversion.
    Jumping in an old thread here hoping someone has came up with some type of answers.
    I noticed im having the same “deep ticking” noise, this morning it was 28 degrees where im at in jersey. My commute is only 8ish minutes to work. I hears the loud ticking noise again and it seems to be coming from the driver side of things. It’s usually heard when its cold outside aswell but i do not always hear it. After about 3-4 blocks of driving i didnt really hear it anymore. I did try to get a video of the noise also. I believe it may be lifter related but im not versed well in motor internals.
    you can hear alot of valve noise which has always kind of been there and isnt too noticeable from the cab but you can definitely hear the “deep ticking” in the video.
