Cold Start Power Steering Chirp Under Load
Discussion in '1st Gen. Tacomas (1995-2004)' started by mateo_roberto, Oct 5, 2019.
  1. Oct 5, 2019 at 1:46 PM
    mateo_roberto
    mateo_roberto [OP] Well-Known Member
    Mateo
    San Diego, CA
    1995.5 Tijuana Teal 4x4
    Stock
    I'm having an issue with my power steering system making a distinct chirping noise under load, only when I start the truck up cold. The noise only occurs under a 'heavy' load, i.e. turning wheels sharply while not moving, and only does it for the first 10-15 seconds of driving/using the steering. It's worse the colder it is in the morning. The chirp also has a resultant vibration which I can feel thru the steering wheel, as if the power steering is losing partial power and then regaining it cyclically.
    Some background on the service of the power steering system:
    1995 3.4L V6, currently has 131k, I replaced the steering rack about 20k miles ago with new OEM rack, partially due to a fluid leak on the inlet/outlet hard lines of the rack. I filled with fresh dex atf fluid, and did the lock to lock method to get all the air out. Fluid level is fine and unchanging, although smells slightly burnt. Checked belt tension last week, but don't believe its the belt or the pulley because the issue only happens while cold and goes away permanently after 15 seconds max. I should add that I didn't have this issue prior to installing the rack, and its been happening pretty consistently since then. My thought is that its possible the leak from the previous rack allowed contamination into the system, and messed up something internally with the pump.
    Am I incorrect in thinking that the pump has to be the source of the issue? I hate being a parts-thrower instead of doing a full diagnosis, but process of elimination has led me here.
    GQ7227 likes this.
  2. Jan 17, 2020 at 1:25 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Did you ever figure this out?
