Cold Start Problems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Putzcommander, Dec 15, 2019.
  1. Dec 15, 2019 at 3:21 PM
    Putzcommander
    Putzcommander [OP] Well-Known Member
    2016 Trd Sport Doublecab 5ft Box
    Softopper
    Have a 16 dcsb mt sport. On cold days if i dont get it to start on first turn its a beast to get going. Seems like motor floods a bit or something. Normally have to wait 10min and try again, not letting off the starter.. never had a "new" vehicle have this problem. Bit nervous of when the battery gets older and a cold streak hits if ill be out of luck some day.. Anyone else have this problem? Wondering if its an atkins cycle artifact or something else..
  2. Dec 15, 2019 at 3:25 PM
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    My 2nd gen used to do the exact same thing randomly also when it was new..
    Junkhead likes this.
  3. Dec 15, 2019 at 3:41 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Possible bad tank of gas, (water in gas) You can try Sea Foam, and Alcohol, (red bottle, not yellow)
    Big tall dave likes this.
  4. Dec 15, 2019 at 6:02 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Ive heard that turning off the headlights helps start in the morning, it draws from the battery at the same time the starter motor is trying to turn over.
    Grossomotto likes this.
  5. Dec 16, 2019 at 3:00 AM
    Putzcommander
    Softopper
    Fuel might be it. Its not electrical.. feels like the fuel air ratio is not resetting from the last time the truck was turned off (imagining a choke setting)... if thats possible or it was just tuned horrible for cold weather climates...
  6. Dec 16, 2019 at 8:11 AM
    SirPuck
    SirPuck Well-Known Member
    2016 Tacoma TRD Offroad
    Have you had this issue in the past or is this the first time with the issue?
  7. Dec 16, 2019 at 8:16 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    still running original battery? How do your terminals look?
    shakerhood likes this.
  8. Dec 16, 2019 at 8:17 AM
    KBOX
    KBOX In a va.. *cough* truck down by the river.
    Jody
    Acton, Ontario
    2017 Tacoma DC Sport V6M 4X4
    Stock
    Which battery do you have? It's possible you don't have enough CCA to turn it over the first time.
  9. Dec 16, 2019 at 4:28 PM
    Putzcommander
    Softopper
    It can turn over lots.. just doesnt catch
  10. Dec 16, 2019 at 4:28 PM
    Putzcommander
    Softopper
    Batt seems fine. Turns over good just doesnt catch. Thinking fuel
  11. Dec 16, 2019 at 4:29 PM
    Putzcommander
    Softopper
    Happened last winter once.. twice again in the last month
  12. Dec 16, 2019 at 4:34 PM
    Technically_Simple
    Technically_Simple Member
    Test the battery and alternator then go from there...
  13. Dec 16, 2019 at 6:05 PM
    Putzcommander
    Softopper
    Not electrical. Seems like fuel management.any thoughts?
  14. Dec 16, 2019 at 6:06 PM
    Bishop84
    Bishop84 Well-Known Member
    Have you done the crank sensor recall? 16's had it.
    The 16's and 17's sometimes have high pressure fuel pump issues, super hard to diag.
  15. Dec 17, 2019 at 2:43 AM
    Putzcommander
    Softopper
    Sounds interesting. Have tsb?
  16. Dec 17, 2019 at 1:09 PM
    swissrallyman
    Try turning just the ignition on for a few seconds before cranking and let the fuel pump run. Seemed to help in the past.
  17. Dec 17, 2019 at 3:24 PM
    Putzcommander
    Softopper
    Will do.. seems like if it doenst catch the first time the second try never works..
  18. Dec 17, 2019 at 3:45 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Any CEL?
  19. Dec 17, 2019 at 4:31 PM
    Putzcommander
    Softopper
    Nope
  20. Dec 19, 2019 at 4:40 PM
    Putzcommander
    Softopper
    Happened again this morning. Definately a fuel problem. Can anyone try turning off their truck within 1-2 seconds of starting and see if its hard to start again?
