Cold Start Rattling Noise
Discussion in '3rd Gen. Tacomas (2016-2023)' started by flyinhyin808, Mar 27, 2025.
  1. Mar 27, 2025 at 5:50 PM
    flyinhyin808
    flyinhyin808 [OP] New Member
    2016 Tacoma TRD Off Road
    Hey TacomaWorld,
    I’ve been dealing with a rattling noise on my 2016 Tacoma TRD Off-Road (75K miles) for the past couple of months. It only happens on cold starts in the morning and is more noticeable on colder mornings (which, where I live, means around 40–50°F). The noise lasts for a few minutes, then eventually goes away usually for the rest of the day. The truck runs fine otherwise, but I wanted to see if anyone else has experienced this.
    Here's a video of the noise.
    https://youtube.com/shorts/7UjBoopuNhU?si=qbMKydCj_6rpr4Ky
    Any ideas what this could be?
    Thanks in advance!
  2. Mar 27, 2025 at 8:13 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    It’s hard to say for sure but it sounds like a belt tensioner or an idler pulley. If you are good at wrenching you can pull the belt off start the engine and see if the sound goes away. Just don’t run the engine too long so it doesn’t over heat. If the sound goes away you can spin the pulleys by hand while the belt is off with the engine not running and usually find the noisy one.
    BTW Welcome to TW!
  3. Mar 28, 2025 at 3:42 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Definitely sounds like a pully loose or the bearings are going out on it .
