Cold start squeak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pacificclam, Jul 15, 2025.
  1. Jul 15, 2025 at 4:33 PM
    Pacificclam
    Pacificclam [OP] Well-Known Member
    Carl
    Hawaii
    2010 Tacoma 4x4 Access cab
    6” pro comp lift Kings Coils and Shocks 700lbs Element UCA Atlas Leaf spring kit 17x9 stealth custom series ray 10s -38 33x12.5 toyo open country mt Tom woods driveshaft CSF high performance radiator 4.88 GEARS
    where do you think this squeak comes from? A idler pulley bearing? A part of the power stearing pump assembly? This squeak only happens when I start it first thing in the morning. It takes about 15 seconds to start up. Once the motor runs for a couple minutes, it goes away. Ive replaced the belt and the water pump recently. thanks for your input.
    https://www.youtube.com/watch?v=NOqdGe6AoeA
  2. Jul 15, 2025 at 7:21 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds like the belt, did you clean the pulleys before installing the new belt.
    Or if you spilled any coolant on it, it only takes a few drops of coolant on a belt to make it squeak.
    Or if a pulley is out of alignment.
    A good test to see if it's the belt or a bearing is to take a spray bottle and spray a bit of water on it, if the noise changes/goes away it's the belt.
    Pacificclam[OP] likes this.
  3. Jul 15, 2025 at 11:17 PM
    Pacificclam
    Carl
    Hawaii
    thanks I will give the spray bottle a shot.
  4. Jul 16, 2025 at 11:06 AM
    Pacificclam
    Carl
    Hawaii
    Here is a video of the spray bottle trick. So this must be a belt issue then?
    https://www.youtube.com/shorts/Da5nzCH-WgY
  5. Jul 16, 2025 at 1:35 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
