Cold start up and engine shut-down
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JohnnyU, Jan 6, 2016.
  1. Jan 6, 2016 at 5:36 PM
    JohnnyU
    JohnnyU [OP] Member
    2015 Tacoma V6 4x4
    Greetings - new 2015 4x4 6 cylinder; noticing on cold start up only, two minor machine like sounds at appx the 30 second point, then no further noise. On engine shut-down, hear longer noise with what sounds like air escaping. These noises come from the passenger side engine compartment. I spoke to a few dealers and followed some threads, and indications are this might be a pump of some sort and is normal. Anyone experience this, both on cold start and at shutdown? Thanks for any info.
  2. Jan 6, 2016 at 5:39 PM
    King Dad
    King Dad Active Member
    2013 Toyota Tacoma Prerunner
    2013 prerunner, on shutdown makes the machine noise but have been told it is normal, haven't talked to dealer about it yet though
  3. Jan 6, 2016 at 5:40 PM
    JohnnyU
    JohnnyU [OP] Member
    2015 Tacoma V6 4x4
    Thanks very much.
  4. Jan 6, 2016 at 5:42 PM
    big_jarv
    big_jarv Well-Known Member
    2020 TRD Pro
    The shut down noise a normal.
    Also welcome!
  5. Jan 6, 2016 at 5:43 PM
    JohnnyU
    JohnnyU [OP] Member
    2015 Tacoma V6 4x4
    Thanks.
  6. Jan 6, 2016 at 5:43 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Possibly an EGR pump? Something to do with the emissions controls?
  7. Jan 6, 2016 at 5:45 PM
    JohnnyU
    JohnnyU [OP] Member
    2015 Tacoma V6 4x4
    Some mentioned evaporator, others a smog pump - supposedly pressurizes on start up, and releases when shut down.
  8. Jan 6, 2016 at 5:46 PM
    CBrva
    CBrva Well-Known Member
    Glen Allen, VA
    2012 Sport DCLB 4x4
    Toytec Boss, LR UCAs, Dakars, FN f(x)pro wheels, ko2
    Probably the good ole Secondary Air Injection Pump - totally normal. Pray that it fails when you're still under warranty or be prepared to shell out $1100. Mine died at 53k miles and sent the truck into limp mode.
  9. Jan 6, 2016 at 5:47 PM
    JohnnyU
    JohnnyU [OP] Member
    2015 Tacoma V6 4x4
    Thanks very much.
