Cold start whine!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Torrencerodco, Oct 31, 2020.
  1. Oct 31, 2020 at 8:19 AM
    Torrencerodco
    Torrencerodco [OP] Well-Known Member
    2006 gold trd
    So my 06 dc 4.0 developed a cold start whine over a year ago. It starts about 30 seconds after starting, and stops when coolant temp is around the 130 mark or 5 minutes. I have replaced belt,all pulleys,tensioner,power steering pump,power steering reservoir,alternator,ac pump,water pump...the only thing I haven’t done is the fan clutch. I have done the spray everything down with a water bottle trick to no avail, also done a stethoscope and cannot pinpoint where it’s coming from. It’s literally making me go bad shit crazy any help is appreciated. It sounds like power steering wine but zero noise turning the steering wheel back-and-forth and like I said the whole front of the truck is new even the rack and Pinion.
    Rancher74 likes this.
  2. Oct 31, 2020 at 8:45 AM
    Torrencerodco
    2006 gold trd
  3. Oct 31, 2020 at 8:50 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    if U have replaced what U say..................live with it
    after 5 mins what the heck
    put in a CD........listen to some death metal or not
    some hip hop.........no
    hw about if it aint got tthat twang it dont mean a thang
    u wit me ??
    why spray with water ??
  4. Oct 31, 2020 at 8:58 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    What kind of belt? Ive had problems with cheap Bando belts. There's actually 2 kinds of Bando belts for the 4.0, a good quality bando that the dealer uses and a cheapie that's for sale everywhere else
  5. Oct 31, 2020 at 9:02 AM
    Torrencerodco
    2006 gold trd
    Hahaha
    It’s looking like I live with it more and more each day hahaha..
    I just feel there is definitely something causing the noise so why not try to fix it you know? In the local Toyota dealer told me to spray each belt contact area with a mist of water and see if it stops. They keep thinking it’s pulley misalignment, but they haven’t a clue either...and for music....I got that covered
    Tacomagirl38 likes this.
  6. Oct 31, 2020 at 9:04 AM
    Torrencerodco
    2006 gold trd
    I’m using a Bando!!!!! That is literally the first thing I did over a year ago, if that is the culprit I’m going to punch my own self ha ha
  7. Oct 31, 2020 at 9:38 AM
    Torrencerodco
    2006 gold trd
    Next up for today, I will remove the belt and do a cold start. Apparently I should of done this sooner. Does anyone know if I will get a check engine lights if I start it for a couple minutes without a belt?
  8. Oct 31, 2020 at 9:57 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    No check engine light. You'll see battery warning and be careful with the temp because the water pump isn't turning
  9. Oct 31, 2020 at 11:12 AM
    Torrencerodco
    2006 gold trd
    Thanks for all your help I greatly appreciated it. I just started the truck with the belt off and the whine is still present. Headgaskets and timing chain were done res entry, but whine was way before that! Looks like I will drive it till she blows haha as I’m not tearing it apart. I feel like an idiot I could’ve just taken my belt off before I spent the last year replacing all the stuff
  10. Oct 31, 2020 at 11:30 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Does it have oil in it? :anonymous:
  11. Oct 31, 2020 at 11:43 AM
    theturbodog
    theturbodog Well-Known Member
    Fort Worth, TX
    I had a whine sorta like that on my '07. It ended up being a transmission noise, but nothing ever actually broke while I owned it. I finally figured out it was coming from the trans while doing an ATF change. It didn't go away, but I could really hear it good when I was under there with my head next to the body.
  12. Oct 31, 2020 at 11:43 AM
    Torrencerodco
    2006 gold trd
    Haha haha yes...I’m one of those ocd buggers”hence the wine driving me crazy”...the truck has 320k so she’s served me well and still runs like a dream. Next up is a mechanical oil pressure gauge check this afternoon, But for some weird reason I am at peace after finding this out ha ha Ha.
  13. Oct 31, 2020 at 11:49 AM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    When mine did this turned out to be a bad alternator. New one made quiet as new
  14. Oct 31, 2020 at 11:51 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Get a mechanic's stethoscope and keep checking things 'til you find it. The annoying thing about noises like that is that they teleagraph so well through all the metal in the engine compartment. Is it a rotary noise? Does it change with engine speed?
    c212 likes this.
  15. Oct 31, 2020 at 12:06 PM
    Torrencerodco
    2006 gold trd
    Yes if I rev it it gets louder. But after five minutes it goes away completely
  16. Oct 31, 2020 at 12:07 PM
    Torrencerodco
    2006 gold trd
    I’ve changed EVERYTHING on the front of the motor,and still does it with belt removed
  17. Oct 31, 2020 at 1:34 PM
    Normshark
    Normshark Well-Known Member
    Great White North
    2014 Tacoma DCLB Limited
    Mine does the same thing. A little louder when it's colder outside. Replaced a few things but the whine remains unchanged. At this point I'm just chalking it up "one of the noises this particular truck makes". To the more engine mechanically inclined members, could this possibly be a noisy oil pressure relief valve? Seems to be located in the right area.
    Cheers.
  18. Oct 31, 2020 at 1:40 PM
    tirediron
    You don’t have an electric fan by any chance? If it’s tied to RPM and it does it with belt off, I would start with the harmonic balancer. Get you stethoscope and start poking around that area.
  19. Oct 31, 2020 at 3:24 PM
    ROAD DOG
    FEW
    True Dat !!
  20. Nov 1, 2020 at 4:08 AM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    Sounds like the fan clutch to me.
