Cold starts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Onehugenut55, Jan 10, 2018.
  1. Jan 10, 2018 at 1:43 AM
    Onehugenut55
    Onehugenut55 [OP] Well-Known Member
    Dave
    2017 TRD OR DCLB
    With my work schedule, the truck sits in a parking lot for 3 weeks. After so long I assume the oil has drained out of the cylinders. Is there anything I can do to prep the truck and make that first start a little less severe?
    Follow up question: I can possibly swing by and start it once a week for a few minutes. Would that be worse for the engine or is it possible the cylinders still have enough oil in them to justify starting it? Everyone likes pics so here is the truck
  2. Jan 10, 2018 at 1:54 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    I find it comical how some max security facilities issue khaki to persons behind the fence.... i mean, look at that tacoma blend
  3. Jan 10, 2018 at 1:59 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Just use thicker oil like 10w-30 so there will still be a film on everything vs the watery 0w Toyota calls for that runs right off. The only reason they use oil that thin is for economy reasons, squeeze out that last .001mpg.
    Your oil will still be in the pickup pump and passages so as soon as the engine starts to turn over pressure will be there.
    In my honest opinion, you're over thinking this one. I wouldn't worry about it. ;)
    over60 likes this.
  4. Jan 10, 2018 at 2:11 AM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    That 0W20 also is flowing through all the oil passages much quicker that 10Wanything too.
    If you really wanted to, pull the fuel pump relay and crank it for about 30-40 seconds before the initial start after 3 weeks of sitting.
    over60 likes this.
  5. Jan 10, 2018 at 12:43 PM
    Onehugenut55
    Dave
    2017 TRD OR DCLB
    Over thinking it is good news but I’ll run it by the dealer when I got in for my 5k next week. The high/low viscosity debate is an interesting one.
  6. Jan 10, 2018 at 1:07 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    ugh no... thats the worst advice ever.
    OP leave it be, start it when you can actually drive it and put a load on it to warm it up properly (dont let it sit and idle for long to "warm up")
    Stick with the stock oil weight and you will be fine.
    EdgeCrusher likes this.
