Cold Starts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lavrishevo, Dec 11, 2023.
  1. Dec 11, 2023 at 11:02 AM
    #61
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Remember, it's not an oil change it's an oil extraction
    Tocamo, PTSDTherapy and SR-71A like this.
  2. Dec 11, 2023 at 11:09 AM
    #62
    lavrishevo
    lavrishevo [OP] Well-Known Member
    2023 Trail Edition
    correct, the first three were extractions, and the fourth was a change, although there was no difference in the amount of fluid that came out. Believe it or not, you can suck that pan dry through the dipstick and add a little extra fresh fluid in there suck a bit more out and she’s clean as a whistle. 12 quarts of M1 euro is only 60 bucks, I got to put it to good use!
  3. Dec 11, 2023 at 11:18 AM
    #63
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    What fluid? You mean oil?
    Why wouldn't it be clean in there? It's a brand new truck.
    If you are worried about particles you should be changing the filter constantly. Sucking out oil and putting fresh oil in to feel better is absolutely a placebo effect
    Honestly i'm super confused about what you're worried about that is driving all this.
    I kind of feel sorry for your truck
    Junkhead, PTSDTherapy and SR-71A like this.
  4. Dec 11, 2023 at 11:19 AM
    #64
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Oh gawd. This is the same guy huh
    jmneill and PTSDTherapy like this.
  5. Dec 11, 2023 at 11:25 AM
    #65
    lavrishevo
    2023 Trail Edition
    Time for the ignore function, good luck! So many disgruntled people in this forum. Life is too short to engage in useless conversation, I suggest you ignore me as well, those of you who wish to. If not, I enjoy thoughtful and respectful conversation. It will make our time more enjoyable.
  6. Dec 11, 2023 at 11:29 AM
    #66
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Is there anything that doesn't last 15 times longer with a ceramic coating?
    I'm having my entire truck ceramic dipped next week. Shop says I can expect a million miles out of everything from my driver's seat to the front brake pads.
    How in the hell did our vehicles ever survive before this modern miracle?
    wayupnort, Junkhead, jlemmond and 2 others like this.
  7. Dec 11, 2023 at 11:34 AM
    #67
    lavrishevo
    2023 Trail Edition
    I was not a believer in ceramic paint coating being that great vs wax until I did it myself. Of course the prep process is essential but I get 2+ years out of the one I used. I don’t believe in snake oils or any miracle products but I do believe in advancing technology. As far as a million miles, I don’t know about that. 2-4 years seems to be the average on the paint.
  8. Dec 11, 2023 at 11:45 AM
    #68
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Have you actually done anything with your truck to warrant all this oil changing/extracting?
  9. Dec 11, 2023 at 1:38 PM
    #69
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    In my book this is one of THE winning posts of this long-winded Yet Another Oil Thread because it quotes the factory specs, which directly state that more than one viscosity grade of oil is acceptable for regular use in that particular engine.
  10. Dec 11, 2023 at 1:59 PM
    #70
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    post up a video of you pouring ceratec into your engine next time. just so we're 100% sure you're using it.
    JaxsonPotato likes this.
  11. Dec 11, 2023 at 2:11 PM
    #71
    PTSDTherapy
    22 SR5 DCSB
    Wondering what manual that chart came from… I have a 22 and friend has a 23…that chart with the two oil viscosities listed on it doesn’t exist in his manual nor mine. Both simply state 0w20 as recommended but a higher viscosity can be used.
  12. Dec 11, 2023 at 2:19 PM
    #72
    GilbertOz
    GilbertOz Driver
    CA
    Hmm, on further research, this is what I found on page 546 of the 2023 Taco user manual. (See below.)
    Says there 0W-20 is recommended, 5W-20 may be used, but "..must be replaced with 0W-20 at the next oil change."
    Where did your screenshot claiming up to 15W-40 is acceptable come from?
  13. Dec 11, 2023 at 2:54 PM
    #73
    lavrishevo
    2023 Trail Edition
    Because of CAFE regulations the oil chart is removed from the US manual. It is in other manuals. As per the service manual, 0w-20 through 15w-40 is acceptable. This means any weight in between these. 5w, 10w, 15w, 20, 30, 40.
    This is also a great article that explains why this is happening.
    https://www.machinerylubrication.com/Read/518/motor-oils
  14. Dec 11, 2023 at 3:03 PM
    #74
    GilbertOz
    GilbertOz Driver
    CA
    Hell yeah. Thanks, very useful information.
  15. Dec 11, 2023 at 3:12 PM
    #75
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Engine noise be damned.
    If it’s 29 degrees, imma crank that tank up and get me some heat ASAP.
    You folks can argue over oil type in the cold. I’m going to sit in my warm truck and watch:thumbsup:
    TacoTime55, wayupnort and jlemmond like this.
  16. Dec 11, 2023 at 3:29 PM
    #76
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I'm confused! Is this a stupid oil thread, a worthless additive thread, or both?
    TacoTime55, PTSDTherapy and wayupnort like this.
  17. Dec 11, 2023 at 3:32 PM
    #77
    GilbertOz
    GilbertOz Driver
    CA
    2-for-1 special, today only. You lucked out.
  18. Dec 11, 2023 at 3:33 PM
    #78
    Bishop84
    Bishop84 Well-Known Member
    It's not cold unless you hear the power steering pump screaming.
    dnlskier, joba27n, Tocamo and 3 others like this.
  19. Dec 11, 2023 at 3:39 PM
    #79
    TnShooter
    Deogee
    STOCK
    Wasting your time my man.
    Those that don’t want to know, never will.
    When giving advice on oil, on TW.
    My advice is, “it best to use the oily type”
  20. Dec 11, 2023 at 4:04 PM
    #80
    lavrishevo
    2023 Trail Edition
    It’s a bring on the moronic comments thread… :rolleyes:
