Cold Starts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lavrishevo, Dec 11, 2023.
  1. Dec 11, 2023 at 4:10 PM
    #81
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    That’s how any oil related thread works on TW. I don’t even try anymore.
    Hang around here long enough, you won’t either.
  2. Dec 11, 2023 at 4:15 PM
    #82
    MGMDesertTaco
  3. Dec 11, 2023 at 6:37 PM
    #83
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Just to keep it going,
    I've used ceratec before and think it does something. A mazda 6 I had would glide and barely having any engine braking when I added it to the oil. But in my ranger it made two oil pressure switches stick until they warmed up.
    However i've never used it in this truck.
    Foreign market owners manuals like Australia, Mexico state various viscosities from 0w-20 to 15w-40 depending on temperature.
    I use 5w/0w-30 because the engine is quieter when warm. I tried 40w once in the summer and didn't like it. The engine always felt laboured.
    Op you have some...interesting oil change habits. You should look into like a Fram ultra endurance something like that filter and use High Performance Lubricants oil
  4. Dec 12, 2023 at 4:27 AM
    #84
    Tac2021
    Tac2021 Well-Known Member
    Phil
    2021 SR5 Drk Grey Met Dbl cab 4 x 4
    none yet
    Waste of money, $39.99.? Using an oil weight not recommended for any engine is a path to disaster. Hey do what you want but I think some people are too anal on oil. ‍
  5. Dec 12, 2023 at 4:37 AM
    #85
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    Me too, 6 NH winters, never garage (thats for wifey) and many very cold get up and goes without warm up - no valve click/clatter here at 88k
    Tac2021 and Junkhead[QUOTED] like this.
  6. Dec 12, 2023 at 4:58 AM
    #86
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Oh the irony of this comment.
    99TacoDriver likes this.
  7. Dec 12, 2023 at 5:18 AM
    #87
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    Just to bring up the past...
    Teflon requires over 800 degrees F for it to stick to metal. If your oil ever experienced that temp it would ignite (flashover temp for synthetics is usually around 400 dgrees F), thus "Slick 50" and it's Teflon coating was bogus as hell.
    Another product from the old days was "ProLong". This one was advertised using a spinning shaft being braked with a lever and that lever was a dial indicating torque wrench. It was clever and indisputable. The shaft could be stopped at fairly low torque with normal engine oil as the lube, but when ProLong was added the shaft kept spinning (braking action was nil) even at very high torque. What the company didn't tell you was that at normal engine operating temperatures, that product would produce chlorine - which literally ate bearing material.
    Much research should be done with every product.
  8. Dec 12, 2023 at 5:24 AM
    #88
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    It's 29F here in Dover, DE.
    I remote started my 3G Sport to warm up my windshield...I have a Garmin Mini2 camera to attach.
    TnShooter[QUOTED] likes this.
  9. Dec 12, 2023 at 10:36 AM
    #89
    TnShooter
    Deogee
    STOCK
    Nice. You can sit in the house and watch these guys argue over oil. I still have to make a trip out into the cold to crank my truck up. :rofl:
    TacoTime55[QUOTED] and joba27n like this.
  10. Dec 12, 2023 at 11:15 AM
    #90
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Don't even have to listen to it rattle on startup. Boom, problem solved
  11. Dec 14, 2023 at 7:54 PM
    #91
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
