Cold Tacoma? Why You Should Let It Warm Up First
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hiPSI, Jan 4, 2018.
  1. Jan 9, 2018 at 9:38 AM
    #41
    AlabamaBlackSnake
    AlabamaBlackSnake Well-Known Member
    Jim
    4wd TRD OR 2017 dcsb
    Chrome..lot of chrome
  2. Jan 9, 2018 at 10:51 AM
    #42
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    yes....
    Boneretreiver likes this.
  3. Jan 9, 2018 at 11:01 AM
    #43
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    I can see. VROOM VROOM!
    Sadly, I've seen several of these on highways :(
    Boneretreiver[QUOTED] likes this.
  4. Jan 9, 2018 at 11:03 AM
    #44
    TVCDCLB
    TVCDCLB Well-Known Member
    Long Island NY
    2016 TRD-OR DCLB
  5. Jan 9, 2018 at 11:20 AM
    #45
    xlucidx
    xlucidx Well-Known Member
    2017 TRD Off Road DBCB SB
    I let it run while I scrape the windows, then I go.
    I do take it easy until the temp gets past the first line on the guage, but with todays engines and engine oil I dont think it does much good to let it run other than warming the cab.
    our trucks use 0w-20 syntehtic - which means the oil is thinner and easier to circulate when its cold!
    When the engine comes up to temp the oil acts as a 20w. so the oil is thicker when your truck is warm.
    All the engine warm up stuff was true in the days before fuel injected engines, carbureted engine's needed to warm up for the carb to work correctly - not to circulate oil.
    Plus if you had a carb tuned in the summer that tune needed to be adjusted in the winter when you have a cooler more dense air or the air fuel mixture would be way to lean.
  6. Jan 9, 2018 at 11:41 AM
    #46
    cshrum
    cshrum Well-Known Member
    CO Springs, CO
    17 blue TRD sport DCLB
    Unfair comparison...she has a Heep! :ohsnap:
  7. Jan 9, 2018 at 11:47 AM
    #47
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    The only time I warm up my vehicles in freezing weather is for human comfort. I live downhill and 4 miles away from the freeway entrance heading to work. I also park my truck/car in a closed by not heated garage which is about 15 degrees warmer than outside. I open the garage door, start the truck, back-out, and head down the road. The truck mostly coast down the hill and hardly goes faster than 40mph. As soon as the temp gauge even moves up past the bottom bar, on comes the heater. If on rare occasion I have to scrape the windows, it gets started first. My next vehicle will have a remote starter mostly to get the truck COOLER in the summer when leaving from work to home.
  8. Jan 9, 2018 at 11:51 AM
    #48
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    There is an electric PTC heater in the heater core. It works when you turn the temp to max and have the fan on. There are a few threads about it here, including pics. There is a PTC relay under the hood. If there is a relay in that spot, you have the heater.
  9. Jan 9, 2018 at 11:54 AM
    #49
    doubletap
    doubletap Well-Known Member
    Los Angeles
    2017 Tacoma TRD Offroad MGM
    Try this. Wake up in the morning and without getting ready or anything immediately go outside and start sprinting half a mile and see how you feel. That’s how your truck is going to feel without a small warm up.
    coma toy likes this.
  10. Jan 9, 2018 at 12:10 PM
    #50
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    No. There is absolutely no correlation between your human body and your 'feelings' and how your truck and its mechanical components work.
    OCD TACO, Heepspo, Holdfast4 and 2 others like this.
  11. Jan 9, 2018 at 12:11 PM
    #51
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    If you're cold, they're cold.
    Bring them inside.
  12. Jan 9, 2018 at 12:34 PM
    #52
    doubletap
    Los Angeles
    You no FUN.
  13. Jan 9, 2018 at 1:32 PM
    #53
    knayrb
    Bryan
    Pure stock
    On a 2nd Generation???
  14. Jan 9, 2018 at 1:38 PM
    #54
    GTS Bruce
    GTS Bruce Well-Known Member
    W
    Let it idle for a minute or two. Drive gently for 15 to twenty minutes before hammering it. Drive gently for several minutes or idle a couple of minutes before shutting down. Start,circulate,gentle warm up,hammer it,gentle cool down. Just like a Ferrari,Mclaren,racecar etc. If its leased or rental just hammer it. Rental try some curb driving at speed. One side on the curb and one side on the pavement. Before you burn the tires off a rental make a note that said tires seem to have very low tread.
  15. Jan 9, 2018 at 1:49 PM
    #55
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    My bad!
  16. Jan 9, 2018 at 1:59 PM
    #56
    knayrb
    Bryan
    Pure stock
    No problem. This is one feature that might just help get me into a 3rd Gen in the next 2 years.
    tonered[QUOTED] likes this.
  17. Jan 9, 2018 at 2:05 PM
    #57
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It is a nice feature, but it only blows slightly warm air until the coolant takes over. Definitely better than frigid air. I really like my 3rd Gen, but I wouldn't make it a deciding factor if I was on the fence. Try a cold start at a dealer.
  18. Jan 9, 2018 at 2:17 PM
    #58
    Markcal
    Markcal Well-Known Member
    I don't know how you cope this time of year where you live, this year is setting records where I live and glad it's not our norm.
  19. Jan 9, 2018 at 4:02 PM
    #59
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    De icing fluid. My Ace in the hole for 20 years and shitty winters.
  20. Jan 9, 2018 at 5:21 PM
    #60
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    People who live in frigid climates like Northern MN, Canada, Alaska can attest that when it is minus 30 for a couple days and then warms up to 12 above it actually doesn't feel all that bad. Funny how temp is relative. I got in to go to work this morning and the temp said 12. I didn't mind so much.
    tonered and Markcal[QUOTED] like this.
