Cold Transmission Problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by icurt06, May 3, 2011.
  1. May 3, 2011 at 4:00 PM
    icurt06
    icurt06 [OP] New Member
    Moline, IL
    03 PreRunner
    I have an 03 PreRunner 3.4L V6 with an automatic transmission. When the truck is cold it won't shift into 3rd until about 35mph. When the truck warms up it shifts fine. This is pretty annoying around town...
    Has anyone had this problem?
    Any ideas how to fix it?
    Thanks for the help,
    Curt :)
  2. May 3, 2011 at 4:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Hows the fluid level?
  3. May 3, 2011 at 4:33 PM
    ChavisT93
    ChavisT93 Well-Known Member
    Lexington, SC
    07 reg cab base
    Line-X, Undercover tonneau, Westin step bars, Husky Liners, EGR in-channel window deflectors
    Sounds normal. Most automatic transmissions have different characteristics when they are cold vs. when they are at normal operating temperature.
  4. May 3, 2011 at 4:39 PM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    This is normal on the first gens, they wot shift until you are going either fast as youdo, or until it has warmed up. It stays in the lower gear for higher RPMs to warm everything up quicker. Use the search bar and you'll find a couple threads about the same thing.
  5. May 3, 2011 at 6:52 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Yep......annoying but normal. My 04 does it as well.......fluid level is where it needs to be.
  6. May 3, 2011 at 9:11 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor 15x8 D Window Steelies 33" BFG KM2s Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Check out this thread. Likely information in there you will find helpful.
    http://www.tacomaworld.com/forum/1st-gen-tacomas/134267-wont-shift-out-2nd-when-cold.html
  7. May 4, 2011 at 10:32 AM
    mikracer
    mikracer Well-Known Member
    San Luis Obispo, CA
    2009 DCSB | TRD Sport 4x4
    I think its been discussed quite a bit on this forum. I remember reading something about 2nd gear shifts at 2600 rpm when its cold.
