Cold weather Brake issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by Xbeaus, Jan 3, 2017.
  1. Jan 3, 2017 at 7:51 AM
    Xbeaus
    Xbeaus [OP] Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    When it's really cold out I have noticed every once in a while that I have to about stand on the brakes to get them to work or pump them to get them work. After that they work great. No leaks in the Master cylinder that I can see. It's almost like the brake booster is froze up briefly. I might try and flush the system and use new fluid. I have not done any recent brake work.
    Anybody else had this happen before? is my brake booster going on on me or is there some water contamination in my lines?
  2. Jan 5, 2017 at 7:08 PM
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    Could be lack of vacuum. Anytime it's below 10 degrees here, it takes a pump or too, before I have working brakes. My front brakes and rotors have less than 15K miles, and I replace the brake fluid every 24 months.
  3. Jan 5, 2017 at 7:09 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Flush it to make sure there's no water in the brakes freezing up
  4. Jan 5, 2017 at 9:24 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    could be that ^
  5. Jan 6, 2017 at 1:40 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just like other fluids Brake Fluid does need changed
    It can get enough water to freeze been there done that
  6. Jan 6, 2017 at 8:20 AM
    smmarine
    Melbourne FL
    I flushed a 99 that never had a brake fluid flush last year. Filled half of a 20ml water bottle and the bottom half was water. Brake fluid attracts water over time, and is important to flush regularly.
  7. Jan 6, 2017 at 8:22 AM
    Xbeaus
    Beau
    Gonna flush it. Fluid is pretty dark. I bet I have some moisture build up.
    smmarine likes this.
  8. Jan 6, 2017 at 8:39 AM
    smmarine
    Melbourne FL
    This was the stuff I bled out of my rear the first time. Half was water and it was full of stringy funk.
    OneWheelPeel likes this.
  9. Jan 6, 2017 at 9:29 AM
    EngRWW33
    EngRWW33 Well-Known Member
    :eek: That's incredible. Can't say I've ever seen brake fluid that dirty before.
  10. Jan 6, 2017 at 10:17 AM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    looks like it was filled with oil or something
  11. Jan 6, 2017 at 11:32 AM
    The Driver
    Raph
    Dude!!! That's nasty, when was the last time that you flushed the brake fluid?
  12. Jan 6, 2017 at 2:09 PM
    smmarine
    Melbourne FL
    Good question. I bought it 3rd owner. It was probably genuine 1999 Toyota brake fluid
  13. Jan 6, 2017 at 3:35 PM
    The Driver
    Raph
    :poking:
    May wanna consider replacing ALL other fluids...
    99SuperTaco4x4 likes this.
  14. Jan 7, 2017 at 11:28 AM
    smmarine
    Melbourne FL
    That truck is gone now. My new truck has been flushed
    The Driver[QUOTED] likes this.
