Cold Weather hesitation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Pilvr83, Nov 28, 2018.
  1. Nov 28, 2018 at 4:53 AM
    Pilvr83
    Pilvr83 [OP] Well-Known Member
    Panhandle, Florida
    2020 Tacoma Limited
    Spiker struts, tailgate step, MESO...$$
    I noticed today in our Florida 36 degree frigid morning that my truck ran awful. It hesitated very bad when moving from a dead stop up to about 50 mph; like bad gas.
    I have been thinking when to go to the dealership to inquire about the TSB hesitation but my truck has never acted like I needed the TSB in my nonprofessional opinion.
    Would the TSB smooth out the cold morning run or is this typical of our newer trucks?
    thanks
    twitchhero likes this.
  2. Nov 28, 2018 at 6:39 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Not typical...it was 16f where I live this morning and my 18 ran fine.
  3. Nov 28, 2018 at 7:17 AM
    CTF
    CTF Well-Known Member
    2017 TRD OR
    I’m in Tallahassee. I showed 34 degrees this morning. While starting was noticeably sluggish, I didn’t have any issues with my ‘17. I do have the T-SB-0058-18 update.
  4. Nov 28, 2018 at 7:20 AM
    skierd
    skierd Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
    You probably have a bit of water in your gas. Run a bottle of yellow HEET, if you can even get that in Florida, through your gas next time you fill up. It should help, I use it at the beginning of every winter up here for the same symptoms and it clears it up immediately.
    pinochle likes this.
  5. Nov 28, 2018 at 7:23 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Not normal at all, my truck has performed well in cold morning at first start in the teens.
    If you can, I would check for loose air-intake hose clamps.
    There should be two past the air filter box. The first is easily accessible, the second one requires lifting and removing the plastic top engine cover which snaps on.
    I would also recommend a trip to the stealer if all is well there, as a temperature sensor could be a culprit and should be a simple fix
    Good luck
    Cheers!
    shakerhood likes this.
  6. Nov 28, 2018 at 8:28 AM
    Pilvr83
    Panhandle, Florida
    2020 Tacoma Limited
    I will try this.
  7. Nov 28, 2018 at 8:29 AM
    Pilvr83
    Panhandle, Florida
    2020 Tacoma Limited
    I will also check these clamps. I was starting to regret my purchase of the truck. thank you.
    Funny, just went out to check the clamps - all good.
    This is the first time I really inspected the engine compartment. The air filter cover looks like it will be much easier to line back up than the Gen 2 truck I had. The spark plug change now, looks a little daunting compared to my previous Gen 2. I did not realize all the space from the grill to the radiator; was a little stretch.
    I appreciate the motivation!
  8. Nov 28, 2018 at 9:59 AM
    twitchhero
    twitchhero ___YOU BOYS LIKE___ MEX-I-CO???
    North Carolina
    2017 Tacoma TRD Off-Road
    See Profile for a full list of Modifications: *Suspension* -Total Chaos Upper Control Arms -Total Chaos Lower Control Arms -Rock Rash performace welded spindle gussets -King EXT Coilovers with adjusters (front) -King Tundra EXT Shock with adjusters (rear) -Icon RXT leaf pack (Option 2) -Timbren active off-road bump stops (front) -Timbren active off-road bump stops with U bolt flip kit (rear) -DRT cab mount relocation -DRT Shackle hangers with DRT cross member -Dobsins front leaf greasable bolts -Polyurethane front body mounts *Performance* -AFE intake (noisemaker) -JLT oil catch can -OTT Tune -Stoptech stainless steel brake lines -Power Brake D-Line kit -Extended stainless steel rear brake lines -AGM Odyssey battery -Tacoma TRD Pro Exhaust *Interior* -Window Tint -Tacoma Door Sill Protectors -Clazzio (black leather seat covers) -Dashtop Single Mount -Sound deadening material -GATOR floor mats -Cup holder hero mats -Garmin mini front dash cam -JOYING Headunit -Tacoma Kicker tweeter upgrade -Kicker KS front and rear speakers -Rear USB -Meso Customs interior lights *Exterior* -Tacoma tailgate inserts -Mobtown offroad "No drill" Bolt-on rock sliders. -All-Pro Hi-Lift bed rail mount /w Hi-Lift -Rear Diff breather relocated -Alpha REX TRD Pro style headlights -Baja Design squadron sport (Amber fog lights) -Total Chaos Fabrication bed stiffeners -Window Deflectors (AVS) -TRD Pro Grille -Summit DAKAR (BRONZE) -Toyo Open Country R/T Trail (35x12.50 R17) -Sequential turn signals -Softtopper (black) -Toyota Bed Mat -Vinyl wrapped tail gate (black) -C4 high clearance fender liners -C4 High clearance Rock Runner rear bumper w/ Baja Designs S1
    I'm also in Florida.... it was 45 when I woke up. When I got my vehicle it had the hesitation and I wondered if it could be bad gas. I ran premium gas in the truck for awhile and it has never hesitated since. Try it out, I think it's a better option instead of getting the TSB and having the truck "learn" all over again.
  9. Nov 28, 2018 at 10:01 AM
    Victory
    Victory Well-Known Member
    St. Pete, FL
    2016 White Tacoma TRD Off Road
    I actually thought mine ran better this morning, not that I think it runs poorly at other times. I figured the cooler denser air was helping, but it was in the low 50s here this morning and my truck is garage kept so was probably mid 60s in the garage all night.
  10. Nov 28, 2018 at 10:11 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Vehicles will actually run better in cold weather, but you gotta let them warm up for a few minutes. Remember, even though this is a modern engine, there is still a "choke" being used, albeit a high tech choke, that will limit air mixture for the first few minutes.
    stun gun likes this.
  11. Nov 28, 2018 at 10:38 AM
    Pilvr83
    Panhandle, Florida
    2020 Tacoma Limited
    This I do not do, as I read somewhere that a warm up is not needed on the new trucks. I used to warm up my older Tacoma. I will have to try again with a warm up tomorrow.
    I am open to anything as I would like to love this truck but am having serious reservations.
  12. Nov 28, 2018 at 10:44 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    You do not need to “warm up” an engine. In fact idling is bad for your engine. It warms up faster by driving it.
    I would not run anything like HEET. Too big of a risk with modern cars with excessive sensors.
    The only time you should have higher amounts of water in your gas is if you’ve been using that same tank of gas for a few months or you put in like E-85 by mistake.
    It is winter time, so the winter blends have started. Gas prices have also gone down tremendously, makes me wonder how much ethanol got added in this year.
    Jaque8 likes this.
  13. Nov 28, 2018 at 10:55 AM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    The only cold weather hesitation I experienced with my 3rd gen is when I refused to get out of bed.
    Jaque8, shakerhood, Catfish21 and 2 others like this.
  14. Nov 28, 2018 at 11:00 AM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Got em'
    stun gun[QUOTED] likes this.
  15. Nov 28, 2018 at 11:21 AM
    Taco-piper
    Taco-piper Well-Known Member
    2016 Tacoma OR 6MT
    It may be a modern engine that doesn't require warm up or idling but regardless it's an engine that uses oil. The viscosity is going to be high while cold. As it warms up, the viscosity will lower allowing for better performance.
    You can drive it cold, but I wouldn't hot rod it until it's at operating temperature.
  16. Nov 28, 2018 at 11:25 AM
    Catfish21
    Catfish21 Well-Known Member
    Stockton, Ca.
    Trd off road 4th Gen
    LOL its florida. They don't know COLD. he needs to just warm it up a bit to its operating temperature and go. it was like 6* by UAF this morning at about 5AM
  17. Nov 28, 2018 at 11:30 AM
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    I agree with not needing to warm up engines. Idling is the worst for engines. It's better to drive gently, it will warm up faster.
    As for Heet, any gas tank antifreeze is good to run through a vehicle in the beginning of frigid temps. I run the red bottle with FI detergents.
  18. Nov 28, 2018 at 11:31 AM
    pinochle
    NNJ
    0W20 is super thin already. Your engine will be fine.
  19. Nov 28, 2018 at 11:34 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I had a little mishap with my car last winter, it had been sitting in freezing temps for 2 months accidentally revved it to about 5 grand upon start up, sure that probably shaved a few miles off its life.
  20. Nov 28, 2018 at 10:16 PM
    skierd
    David
    Fairbanks, AK
    I know, I live in Ester and drive past UAF every morning. I’m real curious to see how my Taco will act when it gets really cold. My Mustang loved it, even down to -60F, but my Mazda and Subaru both hated anything below -20.
    My guess is the OP got enough water in his tank through condensation or from his last fill up or both to cause a drivability issue, and the HEET will help get the water out.
    Catfish21[QUOTED] and Rick Speed like this.
