Cold weather performance (or the lack thereof)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Jan 1, 2016.
  1. Feb 14, 2016 at 10:25 AM
    #41
    mclaugj
    mclaugj Active Member
    Jim
    2016 Black Tacoma SR5 LB
    NA
    It won't come out of Park... I'll try Toyota Roadside...
  2. Feb 14, 2016 at 10:27 AM
    #42
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Good luck. Sorry to hear you are having issues.
  3. Feb 14, 2016 at 10:31 AM
    #43
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Check your brake light fuse.
  4. Feb 14, 2016 at 10:33 AM
    #44
    DanielTaco
    DanielTaco Well-Known Member
    Daniel
    Iceland
    2016 Tacoma DCSB TRD OR 3.5
    Good idea ^. Are the brake lights coming on? Also, can you shift it out of park using the emergency release? Then you could just drive it to the dealer....
  5. Feb 14, 2016 at 10:39 AM
    #45
    mferguson
    mferguson Well-Known Member
    Marc
    2011 Tacoma TRD Sport
    -22°F in VT last night
  6. Feb 14, 2016 at 11:46 AM
    #46
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    I wouldn't risk driving it. Toyota will pay for the tow. If the defrost isn't working he'll never clear his windshield of snow or ice when it's that cold out today. why risk injuring someone or himself? I doubt it's one single fuse, even if it is you'd want to know why or what caused it to burn out
  7. Feb 14, 2016 at 12:08 PM
    #47
    mclaugj
    Jim
    NA
    Thanks everyone for your recommendations and support. Toyota Roadside will be sending a Tow Truck 1st thing Monday AM to tow my 2016 SR5 DBCB to the dealer. I will update you tomorrow.
  8. Feb 15, 2016 at 5:19 PM
    #48
    mclaugj
    Jim
    NA
    The FIX - Thanks again everyone for all of your responses to my trouble. It was a long day. Toyota service called at 06:30 this morning saying a Tow Truck was on it's way. TT arrived at 08:30 the driver hooked up my truck and off we went to Romano Toyota in Syracuse. After 2 hours at the dealer the service rep. told me my trouble was caused by the after market remote starter I had installed. They could disable it for $100.00. I told them to forget it and asked if they could start the truck by use of the over ride switch. They did this for me and I drove the truck to the vendor who installed the remote. After a 3 hour wait they were able to fix my problem. Turns out there was a loose wire that needed to be relocated and grounded. Thanks again everyone.....Jim
  9. Feb 15, 2016 at 5:40 PM
    #49
    nevadabugle
    Elko, NV
    Glad you got it figured out.
  10. Feb 15, 2016 at 5:56 PM
    #50
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    I install them for a living. I don't know what they could of done, sounds like they fed you a line of bull crap. Everything is in different circuits and depending on what they used the brake input and stuff runs through the CAN wires. Ignition wires are all separate. My guess is they grabbed the second 12v wire at the ignition switch. It's only rated @ 5amps. If this blew it probably powers your second start and ignition wire. Which would explain why the shifter wouldn't release of it was powered by the ign 2 circuit. That's a rookie mistake is so
  11. Feb 15, 2016 at 6:40 PM
    #51
    WOTaco
    WOTaco Well-Known Member
    NY near the old capital
    2016 MGM DCSB TRD OR MT
    So yea, my truck exhibits the same issues except the shifting into first hasn't been a problem. The only one that really worries me is that screeching grinding noise for a split second when it fires up. All the other symptoms are explainable but that noise sounds damaging. Oil pump? Even this 0 weight oil is probably pretty thick at -20f no?
  12. Feb 15, 2016 at 6:44 PM
    #52
    nevadabugle
    Elko, NV
    Maybe. I'm not a mechanic so I am not sure if a lighter oil would be ok or not.
  13. Feb 15, 2016 at 7:11 PM
    #53
    WOTaco
    I don't know but a block(oil) heater would be a good place to start. If the noise went away with the warmed oil you'd know you were in the right neighborhood. I have an old magnetic oil heater but I think we have aluminum oil pans.
  14. Feb 16, 2016 at 4:20 AM
    #54
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    F150s were doing that, it was the timing chain
  15. Feb 16, 2016 at 5:50 AM
    #55
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    May have been asked already, but is there any gear oil that is rated for colder weather? Seems like the oil they used may not have been rated for that cold. Once it gets warmed up you say it starts to drive better.
  16. Nov 21, 2016 at 4:34 AM
    #56
    ievko82
    ievko82 Well-Known Member
    WV
    17 sport DCSB quicksand
    Sorry to revive an old thread but, I got in my truck last night (it was only 35F degrees) pressed my clutch in and it is very sluggish to return. I saw that atleast 1 person had this issue but theirs didn't do it till it was -15 out. My clutch pedal returned to normal feeling after about 5min of driving. I just wanted to know if this is a normal characteristic of these trucks or should I be thinking of making an appointment with the dealer?
  17. Nov 21, 2016 at 5:53 AM
    #57
    nevadabugle
    Elko, NV
    Mine is definitely cold blooded. I have not heard too many others complain about it and my dealer said it was normal.
  18. Nov 21, 2016 at 5:55 AM
    #58
    ievko82
    WV
    I'm fine with the clutch being a bit sluggish as long as it doesn't get way worse when it gets colder out. We rarely see anything like -15 here but 0 is pretty common.
  19. Nov 21, 2016 at 6:46 AM
    #59
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    Glad this got bumped.
    This morning was the first time my truck has seen under 30 degrees (built and bought this summer). It had nearly all of the same mannerisms @nevadabugle described but again it was only about 30 degrees out, not into the negatives that were described before. About a mile or two into my commute the truck warmed enough to shake out the symptoms.
    Makes me wonder if a fluid change would help.
    OA
  20. Nov 30, 2016 at 6:18 AM
    #60
    Farcedude
    Farcedude Well-Known Member
    Greg
    Westminster, CO
    ‘23 MGM DCSB OR
    Yeah, been feeling the clutch pedal coming out just a bit slowly in 20 degree weather this week. Not a fan, since my commute takes me from my neighborhood to a left turn onto a 55 mph highway - can't be screwing up my shifts just because the truck is cold. Anyone find any better lubrication that might help the clutch? Or get anything done by the dealer?
