Cold weather performance?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Prestovie, Jan 10, 2022.
  1. Jan 10, 2022 at 5:54 PM
    Prestovie
    Prestovie [OP] Well-Known Member
    Preston
    2019 Cement TRD OR 6MT
    Alright guys, need some advice from my fellow “it’d be fine if it weren’t for the wind” folks.
    2019 OR 6MT w/ 45k miles, only “mod” is Wildpeak AT3s 265/70/16 @ 33psi in the cold.
    So, after a recent career change I’m now faced with a weekly 340mi round trip drive at least until the summer. Getting to that bitter cold part of the winter around here and just want to know how everyone’s truck performs or if I’m an outlier?
    Just got done driving one way ~2.5hrs on a mainly 70mph speed limit highway. About 15F most of the trip, windchill around -2F. Just felt like I… struggled. I mean I had to lay into this thing to “maintain” speeds of 70-75mph, and anytime my attention wasn’t directly on maintaining my speed id fall out of the zone. Sipping coffee? 67mph. Changing the station? 65mph. Adjusting the seatbelt? Well pin that right foot down - you get the idea.
    Obviously the cold/winter fuel has effect I just didn’t think this drastically. I averaged 15MPG on a trip that would usually net me around 19-20MPG. Wish I lived in an area that doing 55-60mph was acceptable but it’s not fun getting sucked into semi’s air stream as I get passed for a few hours straight.
    I guess I’m just curious if this is the norm around winter time? This is my first winter with the truck and wanted to get opinions before i start chasing down a mystical diagnosis that probably just leads to an OVtune.
  2. Jan 10, 2022 at 6:03 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I hear ya yeah these Tacoma's hate cold. Getting tuned will hands down be your most effective route . I recommend kdmax pro tune normal throttle and run premium . The tunes are octane learning so you can run regular if needed . Another good tune is Valley Runner.
    boston23 likes this.
  3. Jan 10, 2022 at 6:07 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    You’re fine, 15° is plenty warm and not going to cause any problems. Colder weather means denser air which requires more fuel. Coupled with winter blend fuel that is less energy dense and you’ll see lower fuel economy.
  4. Jan 10, 2022 at 6:10 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    This is not unique to the Tacoma. Your trip MPG will improve slightly if you warm the truck up first. ECU fuel mixtures and winter blend gas also make a difference.
    Also, cruise control is your friend. Inconsistent speeds (especially acceleration to get back to your desired speed) will also greatly reduce your MPG.
    coma toy likes this.
  5. Jan 10, 2022 at 6:15 PM
    Murd3rd
    Murd3rd I believe I Toyota harder than most
    Your Mom's House, USA
    00.5 Reg Cab Slammed, Turbo'd/19 TRD OR 6MT S/C
    1st gen - it's got a built engine, a turbo, and waaaaaaay too much to list. 3rd gen - basic-bitch lift, S/C, Pro Wheels
    you dont use cruise control (either dynamic or reg)? Especially while cruising. Even before my s/c, I could cruise on the interstate at 70-75 no problem. Some folks don't like it, and I understand it for around town (even though I still use it literally every time I get to speed, no matter where), but cruising on the interstate? cruise all day baby!
    gmtech, BMH, oneikr and 1 other person like this.
  6. Jan 10, 2022 at 6:19 PM
    eurowner
    eurowner Duke Sky
    Scoty
    At the coldest before you leave, check your tire pressure and inflate at that time.
  7. Jan 10, 2022 at 6:21 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Cold air is denser and requires more power to push through it. Winter blend gas tends to give worse MPG also.
    So its pretty normal what your seeing.
    SilverBulletII, sporin and Mark77 like this.
  8. Jan 10, 2022 at 6:23 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Tacomas, like any vehicle, have an ideal speed they cruise at before the exponential increase in wind resistance, overcomes the increase in HP as your press on the accelerator. I find my truck will zoom right along at 55MPh / 90kmh , but any faster, and I have to try. Like OP, if I get distracted, back down she goes.
    shakerhood likes this.
  9. Jan 10, 2022 at 6:27 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    15mpg, with that speed and temp out. You should be happy.
    P.s. wind chill means nothing to your truck, only pertains to living, breathing things.
    TartanEagle and Insomnivore like this.
  10. Jan 10, 2022 at 6:28 PM
    Stocklocker
    17TRDORDCSBAT
    Who drives on the freeway at 15MPH?
  11. Jan 10, 2022 at 6:38 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Increased air density
    So colder air means more molecules, and more air molecules means more energy released in each combustion cycle. A drop from 30 C to 0 C is roughly a 10% drop measured in Kelvin, which suggests 10% more energy for each combustion cycle --> 10% more horsepower!
    Junkhead and eurowner like this.
  12. Jan 10, 2022 at 6:39 PM
    na8rboy
    WI
    MPG, typo.
  13. Jan 10, 2022 at 6:44 PM
    Prestovie
    Preston
    Appreciate all the help guys, the scientific comments are great too! Think I’m going to start forcing myself into the habit of using cruise, never thought about the constant back and forth as a cause for more fuel consumption.
    Going to be making my trip back this weekend with cruise set and more realistic expectations!
    Murd3rd likes this.
  14. Jan 10, 2022 at 6:45 PM
    5nahalf
    Erik
    Minnesota
    Remember, if the roads have snow or ice do NOT use cruise control.
    Little Lion and Junkhead like this.
  15. Jan 10, 2022 at 6:46 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    My Camaro loves colder / denser air !!
    sporin, bigmw and Junkhead like this.
  16. Jan 10, 2022 at 7:59 PM
    Underdonk
    Underdonk Well-Known Member
    It's been cold here in Central KY recently... along with 9in of snow during the course of an afternoon last weekend. I've noticed the opposite. It felt like my truck was wheezing during the hot, humid summer and really woke up in the colder weather. This is both with the stock ECU software and KDMax v6 and Pro. Just based on how motors work, I can't see any logical way a motor would be less efficient in the cold weather than the warm.
    D. Lengua likes this.
  17. Jan 10, 2022 at 8:00 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    @Prestovie
    The air-fuel ratio at operating temperature should require less air to maintain that ratio since there are more oxygen molecules in the air.
    If cold air hurts power, why is there such a focus on cold air intakes?
    eurowner and D. Lengua like this.
  18. Jan 10, 2022 at 8:05 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Cold air doesn’t hurt power, it creates power. You have more oxygen in cold, dense air which requires more fuel to maintain the same air/fuel ratio and produces more power as a result. That also leads to decreased fuel economy.
    CanadaToy, US Marine and eurowner like this.
  19. Jan 10, 2022 at 8:05 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
  20. Jan 10, 2022 at 8:06 PM
    shotgunbilly420
    A chevette yes
    shakerhood[QUOTED] likes this.
