Cold Weather Problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jake1530, Nov 25, 2015.
  1. Nov 26, 2015 at 12:52 PM
    kegman
    kegman Well-Known Member
    Ron
    Regina sask canada
    tacoma trd 4x4 2007
    Use small spray bottle containing windshield washer/deicer and small 2inch plastic putty knife takes like 20 seconds
    Jake1530[OP] likes this.
  2. Nov 26, 2015 at 3:40 PM
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    lol spoken like a true Canadian!
    It is possible to scrape your mirrors while still looking stylish...
    skiergd011013 and Pigpen like this.
  3. Nov 26, 2015 at 3:42 PM
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    :eek:
    :D
  4. Nov 26, 2015 at 6:13 PM
    evilcorvette
    evilcorvette Well-Known Member
    oderus urungus
    Syracuse NY
    Holy hell, just answer the mans question already. :p
    There are several spray on bottles you can buy that you put on the night before that prevents freeze. It leaves a slight protective film. One product that I use religiously is spray on de-icer. They sell it in aerosol cans and I believe its alcohol based. Spray it, wait 30 seconds. Light frost will disappear, heavy, thick ice (anything more than 1/32nd of an inch) will become MUCH easier to knock off.
    skiergd011013 and Jake1530[OP] like this.
  5. Nov 26, 2015 at 6:21 PM
    Pigpen
    Dan
    Northwest Montana
    I've used plain alcohol, both ethyl and isopropyl with good results. $1.50 should last an entire winter.
  6. Nov 28, 2015 at 3:59 AM
    Jake1530
    Jake1530 [OP] Well-Known Member
    2015 Tacoma TRD
    Thank you Evilcorvette
  7. Nov 28, 2015 at 4:11 AM
    DrFunker
    DrFunker Well-Known Member
    @Unchained 5150 Just did the heated mirror mod. Ask him for the details, if you would like. I think he has the same year Tacoma too.
    Although the jimmy mitten is very stylish, imo. :D
