"Cold Weather" starter?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jdhreiss, Jan 4, 2015.
  1. Jan 4, 2015 at 7:05 PM
    jdhreiss
    jdhreiss [OP] Active Member
    Joe
    SW Washington
    99, Tacoma SR5 TRD Debadged
    Fiberglass bed cover, Linex bed liner, Optima red top battery, 1150/32/15 BFG AT
    Finally wiggled my "clicking" starter out through the wheelwell on my 99 taco and figured I'd replace the whole unit instead of the contacts since I'll be RVing with it this year. I see there is a "cold weather" version. What is the difference over the standard starter?
    Joe R.
    Kelso, WA
  2. Jan 4, 2015 at 7:07 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I've never heard of a cold weather starter, but most will tell you that the best starter unit to buy is the OEM one as many have had 3rd party replacements die shortly after purchase.
  3. Jan 5, 2015 at 3:00 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    A higher KV rating,,or horsepower rating. Easier to turn over the motor.
    I had 3 choices at Baxters in Longview when I replaced mine in 2011. Bought the highest rated one they had at that time (1.9hp rated). Had the quality control dyno/test sheet in the box and it actually exceeded 1.9hp.
    The 3 at that time was a 1.3, a 1.7 and a 1.9
  4. Jan 5, 2015 at 12:00 PM
    jdhreiss
    Joe
    SW Washington
    Thanks Mod.
    CR NAPA has their "NAPA Power Supreme" reman denso's (1.4kw) for $114, both std and cold. A brand new Bosch 1.9 kw is pushing $300. I'll check Baxters.
    Tanks again!
  5. Jan 5, 2015 at 4:32 PM
    CR, WA
    stock
    Crapola! now $300?. Uhh, I paid somewere south of $175ish for mine,,just 3 years ago. Should have bought a pallet of em.
    Tell em to price beat on the better starter. It's a bugger to replace.
  6. Jan 5, 2015 at 7:56 PM
    acidfly
    acidfly Well-Known Member
    Kevin
    Kitsap, Wa
    Toytec 3" lift, 4.88 gears, ARB locker, Elite front/rear bumper with sliders, Fully LineXed, Custom bedrack
  7. Jan 5, 2015 at 7:59 PM
    jdhreiss
    Joe
    SW Washington
    I never heard of the "Cold Weather" starter either, and I've owned many cars and trucks in my 60+ years. Today I found a document from Toyota that has some pretty good basic starter info. It mentions the cold weather package indicating the CWP starters have greater power, usually up to .5 Kw over the non CWP.
    see: WWW.autoshop101.com/forms/h7.pdf
    FYI: NAPA lists a new Bosch starter @ $344 bucks. My oh my!
    Joe again
  8. Jan 5, 2015 at 8:28 PM
    1998tacoma4x4
    1998tacoma4x4 Well-Known Member
    Orange County
    1998 Tacoma 4x4 3.4L Auto
    Deaver j59 pack 2.5 SAW coilovers, rear bilstein 5100's. Extened stainless rear brake line, deck plate mod, drop in K&N filter, Kenwood headunit & pioneer speakers, SnugTop Shell.
    I purchased the cold weather version of an AC Delco replacement starter for my 98 and burned it out within a few days.
    Apparently trucks that are built to live in colder areas can come equipped with an upgraded starter but you cant just put it on your truck if it never came with it.
  9. Jan 5, 2015 at 9:15 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
  10. Jan 6, 2015 at 9:29 PM
    jdhreiss
    Joe
    SW Washington
    I bought new Denso Cold Weather starter for 145 in Chehalis. Bolted right in after 30 minutes of wiggling/twisting and cussin. No issues. Same size as the OEM I took out. everything appeared to be the same. I also found the starter listed as "Cold Region" starters. Maybe they put them in rigs headed to the north? I dunno.
    Now I found the right valve cover weeping a little oil.......
    Thanks for the input guys, it helps!
    Joe R.
    milepost 43
    Kelso, WA
  11. Jan 7, 2015 at 6:04 AM
    CR, WA
    stock
    I think your autoshop101 link told the tale Joe. The higher output starters for overseas/exported/imported diesels in the severe cold,,which would make sense. Also to cover other applications, ect, ect.
  12. Jan 10, 2015 at 1:24 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Check to make sure the bolts on the cover are not loose. Mine's doing the same but I am going to tighten them back to spec first to see if it goes away.
  13. Jan 10, 2015 at 2:45 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    The cold weather starter is part of an optional "All Weather Guard Equip Package" code "CK", $75 (in 99). The package included "heavy-duty battery, heavy-duty starter, rain-channel windshield molding and heavy duty windshield wiper motor".
    It was a stand alone option commonly bundled with the "SR5", "TRD" and "LTD" packages.
  14. Jan 10, 2015 at 9:36 PM
    CR, WA
    stock
    XHD wiper motor.
    All Pac Northwest trucks should have had that,,for the XHD rain we get.
    Who got the cheap wiper motor?,,
    hmm.
  15. Jan 23, 2015 at 12:04 PM
    jdhreiss
    Joe
    SW Washington
    Thanks for that info, Dirty Pool. Those hard to find facts interest me. They should have thrown in some XHD wiper blades. I use a couple sets a year in the PNW. Took a trip to Moab last year. Outfreekingstanding!!!
    Joe R.
    Kelso, WA
