cold weather woes
Discussion in '1st Gen. Tacomas (1995-2004)' started by alumaman, Feb 5, 2015.
  1. Feb 5, 2015 at 12:02 PM
    alumaman
    alumaman [OP] Well-Known Member
    Yukon
    95 Tacoma
    Header, cold air intake 2" body lift
    It has been in the -25 to -33C (-13 -27F) range here and so far one of the seals on my new rear shocks blew, there`s a ticking in the motor since I didn`t have the block heater plugged in long enough before starting and there`s is a grinding noise coming from the front hub. They are locked but I`m thinking it`s not quite engaged. It clears up after driving it for a while which probably isn`t the best thing to do but the batteries are frozen in my other truck and I`m not changing them until it warms up. The one good thing about all this is the digital clock only works when it`s below -20
  2. Feb 5, 2015 at 4:39 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    My clock works bellow 5C in the cab to ahaha. My truck ticks while real cold too. Dont have manual hubs but grinding is never a good think. Could be ice in them.
  3. Feb 5, 2015 at 6:05 PM
    Deere9798
    Deere9798 Well-Known Member
    Charles
    Western NY
    2001 Tacoma 4x4
    It's not nearly as cold as the Yukon but I just had to disassemble
    My rear parking brake due to ice in the rubber boots, causing the brakes to be stuck on.
