Colinb17's kinda sorta build thread - now with 4-link and long travel
Discussion in '2nd Gen. Builds (2005-2015)' started by colinb17, Jun 24, 2011.
  1. Sep 3, 2013 at 7:01 AM
    #2061
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Matt, i'll send you a pm later today. but yes, still no tools :(
    question for erbody.....
    who thinks these 35s are going to rub the hell out of my UCA with stock wheels and spidertrax spacers?
    I don't need the truck wheelable for the next few weeks, but i do need it streetable. so a little rub on the cab mount or fenders when i hit potholes or speedbumps is fine for the time being, but a constant rub between the sidewall and UCA is a nono.....
  2. Sep 3, 2013 at 7:03 AM
    #2062
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    really? i had a couple little scuffs near the backside of the wheel wells, but for comparison, the suffs/dents left by my UCA hitting the inner fender was far worse than what the tire did.
  3. Sep 3, 2013 at 7:16 AM
    #2063
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :notsure:
    :popcorn:
  4. Sep 3, 2013 at 7:33 AM
    #2064
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    stock wheels are 5.5 backspacing, so with 1.25 spacers, i'm at 4.25 backspacing. so in theory, good to go. gues it'll just depend on what kind of sidewall curvature i get from the narrower wheels.
  5. Sep 3, 2013 at 7:39 AM
    #2065
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    10-4, thanks man. i think when i go in tomorrow i'm goint ot have them mount the spare first, and test fit it. if i have rubbing at right height, with the wheels straight, i'll hold off on the other 4 until i can get new wheels or bigger spacers. fingers crossed for that not being the case though.
    i texted john and asked, since he's on 35s with stock wheels, but i think he went right to the 2'' bora spacers, and never even tried them with the spidertrax. haven't heard back yet though, so we'll see.
  6. Sep 3, 2013 at 7:50 AM
    #2066
    BradyT88
    BradyT88 Well-Known Member
    Yeah. It has started to rip the plastic lining up in there out. If it keeps it up the end of my intake will be exposed... I need a snorkel. Haha
    As for the 35's from what PSU said it sounds like you will be alright. Skinnier wheel should pull the side wall in a little making the tire a little skinnier as well. Might have some rubbing at lower psi though. I will rub my frame at full lock but only when at lower PSI.
  7. Sep 3, 2013 at 7:56 AM
    #2067
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    yeah, my inner plastics dissappeared as soon as the snorkel went on. I removed the rear liners long ago and couldn't be happier. so much easier to clean after wheeling since there's nothing to trap mud and dirt anymore.
    I'm hoping that you're right, and the narrower wheel will help my case.
    won't make a difference at lower PSI though for the UCA. Luckily tires only go flat at the bottom :D
    I could see the tire briefely tapping the UCA at lower psi, but only on higher speed stuff, like when you get jarred ina rut on a high speed turn. then a lower psi tire will "bend" to the outside of the turn from the force. a litle rub from that would be acceptable though.
    but back to what's important.......when you getting a snorkel :popcorn:
  8. Sep 3, 2013 at 8:28 AM
    #2068
    BradyT88
    Yeah. Higher speed stuff is when my tires hit my frame. Took me a while to figure that one out because on a lift I couldn't get the tire to touch the frame no matter how hard I tried.
    At $400-$500 I'm having a hard time justifying that cost... especially since I have plans for fiberglass in the future. I need to find out if that new snorkel (its Airaid right?) Will fit onto glass with minor modifications or if another one will work better. At the moment I'd rather put that money into a 50T leaf pack or some custom alcans and shocks and hoops/bedcage to go with it.
  9. Sep 3, 2013 at 8:33 AM
    #2069
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    yeah, all kinds of crazy things happan at speed. not only with the tire bend further in and out, but you'll get all kinds of bushing movement that you just can't simulate, short of a come-along from the lower arm to the frame. and on top of it all, you then have frame flex thrown into the mix as a little extra fuck you, straight from the tire clearance gods......
  10. Sep 3, 2013 at 8:43 AM
    #2070
    BradyT88
  11. Sep 3, 2013 at 8:50 AM
    #2071
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    hear back from john. he's gonna take a look at his clearance between the sidewall and UCA. he's running the same wheels and UCAs as me, with 2'' spacers, and 315 treadwrights.
    as the treadwrights generally run large compared to other tires in the same size (due to their construction), i figure that if he's got 0.5''-0.75'' clearance or more, i should be ok.
    0.5'' and less will be bad news most likely.
  12. Sep 3, 2013 at 8:53 AM
    #2072
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Airflow
  13. Sep 3, 2013 at 8:55 AM
    #2073
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    that ^^^
    airaid is just a standard intake, like volant/afe/k&n/etc
  14. Sep 3, 2013 at 9:52 AM
    #2074
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    hmm, tracking says my tires have been delivered already, a day early. gonna call up firestone and see if that's true, and if so, go have one test fir tonight if they have the time, and then the rest mounted if the test fit goes well.
  15. Sep 3, 2013 at 10:19 AM
    #2075
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Just got off the phone with firestone. Tires are in, and appointment is moved to today. They're gonna mount up my spare first for test fitment. Fingers crossed :goingcrazy:
  16. Sep 3, 2013 at 6:03 PM
    #2076
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    :popcorn: i think your ganna rub the UCA. Even at 4.25 BS thats a skinny wheel, so your offset isnt very low, either way good luck!
  17. Sep 3, 2013 at 6:30 PM
    #2077
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    :popcorn:
    Eagerly awaiting the results of your trip to Firestone.
    :popcorn:
  18. Sep 3, 2013 at 6:38 PM
    #2078
    BradyT88
    x2!! Pass the popcorn!!
    :popcorn::popcorn::popcorn:
  19. Sep 3, 2013 at 6:40 PM
    #2079
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
  20. Sep 3, 2013 at 6:46 PM
    #2080
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    This!
