Colinb17's kinda sorta build thread - now with 4-link and long travel
Discussion in '2nd Gen. Builds (2005-2015)' started by colinb17, Jun 24, 2011.
  1. Oct 11, 2013 at 11:24 AM
    #2861
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    :woot:
    and 4.56s.... :goingcrazy:
  2. Oct 11, 2013 at 11:24 AM
    #2862
    Delmarva
    Tucson, AZ
    lmao... that would look horrid
  3. Oct 11, 2013 at 11:26 AM
    #2863
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Crooked
  4. Oct 11, 2013 at 11:29 AM
    #2864
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Even if a joke you can't paint ARB snorkels. The UV coating it has stops the paint from adhering. ARB even has a letter floating around somewhere about it.
  5. Oct 11, 2013 at 11:32 AM
    #2865
    Delmarva
    Tucson, AZ
    finally
  6. Oct 11, 2013 at 11:33 AM
    #2866
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Is there something else you can do to change the color? I only ask because there's a FJ I always see around here that is colormatched tan to his vehicle.
  7. Oct 11, 2013 at 11:36 AM
    #2867
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Woot! I need some 4.56's and a locker or two.
  8. Oct 11, 2013 at 11:37 AM
    #2868
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    you do :anonymous:
  9. Oct 11, 2013 at 11:38 AM
    #2869
    CanisLupus
    Stokesdale | NC
    Yep it looks pretty sweet.
  10. Oct 11, 2013 at 11:43 AM
    #2870
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    pretty sure mine's just a reflection. grill paint is just as old as the truck, and neither have really faded much.
    which is funny, because mine usually looks small next to all the guys with 3'' lifts and 33s. a lot of it in this picture is the rack though. our roof lines and mirrors are very close to being even
    shadup! :pout:
    you too :pout:
    isn't that called stance or something? thought it was supposed to be cool :confused:
    a 1/4'' thick coat of professionally sprayed on bedliner maybe :notsure:
    that way even when it doesn't adhere, it's got high enough tensile strength and stays on the snorkle like a sock lol
  11. Oct 11, 2013 at 11:49 AM
    #2871
    XXXX
    sKiP
    05 Prius
    Cross linked polyethylene is a low surface energy plastic, meaning that it essentially will not stick to anything, and nothing will stick to it.
    Google "Gougeon co."
    They make PEX repair kits and may know how to prep it for paint.
  12. Oct 11, 2013 at 11:54 AM
    #2872
    BradyT88
    BradyT88 Well-Known Member
    You have an S/C and 4.56's. Do you smoke the rear tires all day long?! haha:cool:
  13. Oct 11, 2013 at 11:59 AM
    #2873
    Delmarva
    Tucson, AZ
    lol... It will def smoke one tire if I hit it.... :goingcrazy:
    I also have a 2.85" pulley from URD :anonymous:
    she's quick...
  14. Oct 11, 2013 at 12:00 PM
    #2874
    Delmarva
    Tucson, AZ
    LOL... I'm only at about 1/2" of lift with these 884s and the armor up front :eek:
  15. Oct 11, 2013 at 12:05 PM
    #2875
    BradyT88
    Where's your Trutrac or Locker :cool:
    I'm all factory under the hood with 4.88's and skinny 33's and I can't even 1 tire fire on pavement:pout: I also live at about 5000 ft so that puts a big damper on power...
    I'm at or just under 2" of lift up front now and I have 886's... Damn armor. haha And I don't even have a winch...
  16. Oct 11, 2013 at 12:08 PM
    #2876
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    psh, all you tall fellas.
    locked and low is the way to go! hah, rhymes AND makes sense. take that rappers.
    however i've only got the second half of the rhyme at the moment :eek:
  17. Oct 11, 2013 at 12:10 PM
    #2877
    Delmarva
    Tucson, AZ
    needs work :D
  18. Oct 11, 2013 at 12:12 PM
    #2878
    Delmarva
    Tucson, AZ
    I'm not a fan of engaging the locker for a burnout... :D
    886s will be next one of these days when I deem the current setup to be invalid for my needs :D
  19. Oct 11, 2013 at 12:20 PM
    #2879
    BradyT88
    I see where you are coming from, but that's only kind of true depending on what you are doing. For crawling you want height but from tires not lift. The lift is mostly just to fit the taller tires and to add travel in the rear ends case as well as gain a little more clearance.
    I didn't mean a burnout per se. Just a better launch. haha Besides the locker is pretty tough. It's only weak point is during engaging.
  20. Oct 11, 2013 at 12:32 PM
    #2880
    CanisLupus
    Stokesdale | NC
    Lift doesn't change how tires will fit. Lift=travel
