Colinb17's kinda sorta build thread - now with 4-link and long travel
Discussion in '2nd Gen. Builds (2005-2015)' started by colinb17, Jun 24, 2011.
  1. Nov 18, 2013 at 10:06 AM
    #3341
    BradyT88
    BradyT88 Well-Known Member
    That is pretty crazy by the way! I wonder how my center pins look in my leaf pack...
  2. Nov 18, 2013 at 10:06 AM
    #3342
    Manwithoutaplan
    ID
    damn that Bolt is nearly straight :p why did you replace it.
  3. Nov 18, 2013 at 10:08 AM
    #3343
    BradyT88
    That's true. haha Did your coilovers blow up too when you tried it?:devil:
  4. Nov 18, 2013 at 10:08 AM
    #3344
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    next time you have your wheel off, pop off the bump stops and see if the nut on top is directly over the center of the spring perch. if not, it may be closer to this....
    the ones i replaced these with are now my 4th set of center pins btw :eek:
  5. Nov 18, 2013 at 10:10 AM
    #3345
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    technically, it's just a bunch of little straight pieces, offset from one another :D
    too busty making sweet sweet love to the tire, so i didn't notice.
  6. Nov 18, 2013 at 10:10 AM
    #3346
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Keep your u-bolts properly torqued and you won't be going through as many center pins :D
  7. Nov 18, 2013 at 10:11 AM
    #3347
    BradyT88
    I am getting a new leaf pack soon so I'm not worried about it anyway. haha Maybe I'll check it out when I swap packs though.
  8. Nov 18, 2013 at 10:11 AM
    #3348
    Manwithoutaplan
    ID
    booommm there is it :D.
  9. Nov 18, 2013 at 10:11 AM
    #3349
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    that's what Mike said, but i check them as part of my pre and post wheeling trip checklist :annoyed:
    the first few sets weren't bad, just a little tweaked at the head. this set, i definitely blame the blown out axle shims for
  10. Nov 18, 2013 at 10:15 AM
    #3350
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Seized =/= properly torqued. ;)
    This set I'll give ya bc of the shim issue.
  11. Nov 18, 2013 at 11:00 AM
    #3351
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    plenty of antiseize on the new u-bolts, so no more locked up nuts and bent breaker bars.
    also plenty of locktight on the new center pins. lost the stock center pins because the nut on them, below the bump stop came lose. only realized that when i took off the bumps to replace them with timbrens and instal the u-bolt flip for the first time
  12. Nov 20, 2013 at 6:52 AM
    #3352
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    So i don't know if i mentioned this when it happened, but i had a little mishap a couple months ago when i was installing the doug thorly y-pipe. all of the studs out of the stock manifolds were seized up, so i had to cut them off, drill them out, and just use a regular bolt for the new y-pipe. in the process, i had a cuttoff wheel crack on me, catch the stud, and shot the grinder sideways. i was able to correct pretty quickly, but not quickly enough. it caught one of the hard lines on the tranny and blew right through it.
    luckily there was a vaccume on the line, and i only lost a few drups of fluid. maybe half an oz. the autoparts store down the road didn't have the right size hard fittings to splice it back together, so i had to resort to the ol' hose clamp method.
    a couple months, two wheeling trips, and a 1000 mile, single day drive later, it's holding strong with no leaks. makes sense though, since if you follow the line forward, it just transitions into a rubber line with a clamp as well.
  13. Nov 20, 2013 at 7:23 AM
    #3353
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Check out that MacGyver shit. :cool:
  14. Nov 20, 2013 at 7:26 AM
    #3354
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    rubber bands and paperclips FTMFW!
  15. Nov 20, 2013 at 7:27 AM
    #3355
    xweslingx
    xweslingx Well-Known Member
    Wes
    Durham, NC
    09DCSB locked and armored
    Just gussets... everywhere
    And I was complaining about how the bolts sheared off when I was installing my y-pipe. Good thinking there!
  16. Nov 20, 2013 at 7:30 AM
    #3356
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    yeah, pretty common to twist off the studs regardless of your methods. the studs are threaded in to the flange, but there was no breaking mine lose, so i had to drill....
  17. Nov 20, 2013 at 7:32 AM
    #3357
    xweslingx
    Wes
    Durham, NC
    Well damn I was happy thinking my own might did it lol it gave me a good excuse to replace the headers with Doug thorleys though
  18. Nov 20, 2013 at 7:34 AM
    #3358
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    lol. break $1.00 part, replace with $400 part.
    i'd be lying if i said i'd never done the same :D
  19. Nov 20, 2013 at 7:37 AM
    #3359
    xweslingx
    Wes
    Durham, NC
    Perfectly justifiable right? I keep telling myself it's gonna prevent future mishaps haha
  20. Nov 20, 2013 at 7:39 AM
    #3360
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    same reason i'm on 35s. $170 for a new 33, or $1500 for 5 new 35s :eek:
