Colinb17's kinda sorta build thread - now with 4-link and long travel
Discussion in '2nd Gen. Builds (2005-2015)' started by colinb17, Jun 24, 2011.
  1. Nov 21, 2013 at 8:11 PM
    #3421
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    All Pro standards, 12" Kings, Shock hoops.
  2. Nov 21, 2013 at 8:11 PM
    #3422
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    i'll be keeping my toolbox with my bedcage. just angling the shocks towards the rear instead of the front.
    all i can guess is we have different line choice styles. i probably scrape somewhere else all of the time that you don't. but my hangers are untouched :notsure:
  3. Nov 21, 2013 at 8:12 PM
    #3423
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    exactly. and longer shackles if you want to sit a little lower without removing leafs and killing your load capacity.
  4. Nov 21, 2013 at 8:21 PM
    #3424
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
  5. Nov 21, 2013 at 8:22 PM
    #3425
    PLC721
    Patrick
    Chandler, Az
    Delrin bushings and greasable!
  6. Nov 21, 2013 at 8:22 PM
    #3426
    BradyT88
    BradyT88 Well-Known Member
    Or just different obstacles in general. haha
    I am planning on running the shocks off of the back of the axle and either angling straight up and down or slightly back if needed. I think I can fit straight up and down unless there isn't enough room for the hoop between the shock and toolbox. I'm hoping I can keep my bed extender, but that might be iffy since I am going to run the shocks inside the frame to avoid running wheel spacers and cutting my bedsides for now.
  7. Nov 21, 2013 at 8:25 PM
    #3427
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I have a set I am not going to use if you want them.
  8. Nov 21, 2013 at 8:29 PM
    #3428
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    FTW!
    both of our concepts are sound, now it's just the logistics that need ironing out lol
    love spending other people's money :D
  9. Nov 21, 2013 at 8:32 PM
    #3429
    PLC721
    Patrick
    Chandler, Az
    Being a single cab, it will lower you half an inch, and in return give approx 1-2" droop
  10. Nov 21, 2013 at 8:33 PM
    #3430
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I used the stock shackles when I first did the kit because I had not painted them.:eek:
    I ended up getting a coat of flat black on them but never got around to switching them out.
    Now I'm going with the other setup - won't need these... They are gathering dust in my shop very effectively though. :rolleyes:
  11. Nov 21, 2013 at 8:34 PM
    #3431
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    you will probably have a very hard time fully flexing expos with how light you are. if you want the full 3'' lift, defined makes those same shackles in stock length.
  12. Nov 21, 2013 at 8:34 PM
    #3432
    BradyT88
    I hope it works out! haha I wish I knew how to weld and what not so I could make it. I'll probably learn some from this but I doubt I will learn quick enough to trust my welds to hucking my heavy rig...
    And yep! I got this yesterday. haha
  13. Nov 21, 2013 at 8:35 PM
    #3433
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    That's what I've got. :D
  14. Nov 21, 2013 at 8:36 PM
    #3434
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    the expos, or stock length shackles?
  15. Nov 21, 2013 at 8:37 PM
    #3435
    PLC721
    Patrick
    Chandler, Az
    i'd just buy homers lol
  16. Nov 21, 2013 at 8:37 PM
    #3436
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    you'll like the low lift :cool:
  17. Nov 21, 2013 at 8:38 PM
    #3437
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Stock length defined engineering shackles.
  18. Nov 21, 2013 at 8:43 PM
    #3438
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Got a quick question for you:
    Do you have a shot of your cab mount & firewall mods? I'd like to compare notes...
    Right now I'm fine driving on the street, but I don't want to wheel it until I made some more room.:eek:
    I've got to replace the lower control arm bolts and bushings - at the same time I'll go with an aftermarket UCA to get more camber which will help too.
    I just like to get a closer look at how you did it.
    :thumbsup:
  19. Nov 21, 2013 at 8:46 PM
    #3439
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    no it doesn't!!!
    i'll probably be spending some time under the truck tomorrow at mark's house. i'll get some updated pictures then :)
    the little rub I have left is only at full flex, and only makes a little sound. no functional impact.
  20. Nov 21, 2013 at 8:47 PM
    #3440
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I took off more than you at the cab mount itself, but less where it meets the frame rail
