Colinb17's kinda sorta build thread - now with 4-link and long travel
Discussion in '2nd Gen. Builds (2005-2015)' started by colinb17, Jun 24, 2011.
  1. Jan 20, 2014 at 8:42 AM
    #3781
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Definitely digging the bedrack I saw on Overland's facebook page!
  2. Jan 21, 2014 at 12:01 PM
    #3782
    BradyT88
    BradyT88 Well-Known Member
    I don't know if you saw this with all the LT talk in my BS thread, but I took your advice on the rear diff skid and got the AllPro one.
    It leave a hell of a gap to fill at the bottom when welding it on though. We decided to leave the sides open so that if mud and such collects in there I should be able to hose it out the bottom.
  3. Jan 21, 2014 at 12:19 PM
    #3783
    BradyT88
    Probably should have. It was a lot simpler looking than I had expected when I got it. I also expected it to fit a bit better although like Konsta and I discussed maybe the left the gap on the bottom on purpose so it doesn't become a catch all. I've had it for a couple months now, just barely put it in Sunday.
  4. Jan 21, 2014 at 12:34 PM
    #3784
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    yeah, leaving some openings at the bottom is good. seal it off and you're just going to rust out the rear of the pumpkin. they are very simple, but it's really all you need.
    your diff drain plug looks so much happier than mine :eek:
  5. Jan 21, 2014 at 1:07 PM
    #3785
    BradyT88
    Bahaha. That funny. I noticed it is pretty worn down. About even with the plug now. What is it like 1" tube around it? Maybe I can add a 1/4" to it to keep my drain plug from looking like yours next trip out. Haha Definitely much happy than yours at the moment.
  6. Jan 21, 2014 at 1:10 PM
    #3786
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    yeah, whenever i get around to it, i'm just going to cut a piece of tube the next size up and essentially sleeve the original plug guard.
    luckily a little dremmel work and it came right out. new one is much prettier.
  7. Jan 21, 2014 at 1:14 PM
    #3787
    BradyT88
    Yeah as I typed my last post I debated doing that actually. Then if it gets shaved down bad again it won't push into the drainplug like it does now.
  8. Jan 21, 2014 at 1:19 PM
    #3788
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    thats how mine looks
    i ran a bead around it to reinforce it
  9. Jan 21, 2014 at 1:20 PM
    #3789
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    exactly. i was also thinking of just welding a strip of 2''x1/8'' flat stock along the bottom of the diff housing. between that, the sleeved bolt guard, and an all-pro style diff guard, it's going to be hard to hurd your diff at all. most volnerable part at that point is probably the pinion seal, if you were to smack the front of the diff too hard on something.
  10. Jan 21, 2014 at 1:53 PM
    #3790
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That was gnarly. Put some of the cutting board material on there too. ;)
  11. Jan 21, 2014 at 1:57 PM
    #3791
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    fun part was trying to get the little pieces of rock out from between the bolt and guard
  12. Jan 21, 2014 at 2:05 PM
    #3792
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    I had to weld a nut to mine the last time the diff fluids were done...
    :bananadead:
  13. Jan 23, 2014 at 9:23 PM
    #3793
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Poor trailer just sits at the storage facility these days :( had to stop by it today to grab some wheels and tires out of it.
    Can't wait to get a garage again and finish the overhaul
  14. Jan 24, 2014 at 5:06 AM
    #3794
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    lol... sitting next to a food trailer
  15. Jan 24, 2014 at 5:59 AM
    #3795
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    it's the Houston way :rolleyes:
  16. Jan 24, 2014 at 6:03 AM
    #3796
    NC15TRD
    Nick
    PA
    What are you gonna do to the trailer? You mentioned an "overhaul" and I'm assuming you're pointing that towards the trailer.
  17. Jan 24, 2014 at 6:13 AM
    #3797
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Mmmmm taco truck!
  18. Jan 24, 2014 at 6:15 AM
    #3798
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I currently have separate coils springs and shocks on the suspension. I am going to tear those out and put in an actual coilover.
    The enclosure is also too large. I built the enclosure to carry around just about everything I own (minus furniture), for when I had to essentially move from Fl to VA and back every year in college. now that I don't have to handle moeving my own stuff, I want to cut the enclosure height about in half. the goal is a 2-2.5 foot high watertight space, and a rack on top for a RTT.
  19. Jan 24, 2014 at 6:17 AM
    #3799
    NC15TRD
    Nick
    PA
    I want to eventually build a trailer big enough to haul my Grizzly with a rack over it for a RTT. Someday
  20. Jan 24, 2014 at 6:25 AM
    #3800
    Delmarva
    Tucson, AZ
    indeed... we are a fat city
