Colinb17's kinda sorta build thread - now with 4-link and long travel
Discussion in '2nd Gen. Builds (2005-2015)' started by colinb17, Jun 24, 2011.
  1. Apr 22, 2012 at 11:30 AM
    #381
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    that a good or bad "hmmmmm"?
  2. Apr 22, 2012 at 12:30 PM
    #382
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    good....i need to figure out something....hey do you need a sport rim for a spare?
  3. Apr 22, 2012 at 12:39 PM
    #383
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I'm actually looking for 4 of them lol. 1 for the truck spare, and 3 for the trailer.
  4. Apr 22, 2012 at 12:44 PM
    #384
    hard2kill
    Rhinebeck NY
    im picking up 2 of them on tuesday....i only need one so if you want i can bring it to the june meet or if you want it to mount spare before trip ill send it too you bro
  5. Apr 22, 2012 at 12:45 PM
    #385
    hard2kill
    Rhinebeck NY
    after wheeling with a group of jeeps yesterday im heavily considering 315 treadwrights
  6. Apr 22, 2012 at 5:34 PM
    #386
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I thought you already had 5? gonna run 2 spares?
    I may take it from you. shoot me a PM with what you want for it.
    Just be ready to cut the shit out of your truck. the height isn't the problem, it's the width. even with 295s that are a tad shorter and about the same amount wider, i not only have to rechop my cab mounts because i still rub on the "standard chop", but at full lock and some compression, I also rub on the frame itsself.
    with a reagear it'll be worth it, I just wanted to give you a heads up. i'd recomend getting the hang of welding on your dad's equipment, or pick up a cheap welder for yourself becorehand. it'll make life a whole lot easier, come 35s
  7. Apr 22, 2012 at 8:15 PM
    #387
    hard2kill
    Rhinebeck NY
    yea im hoping if i remove flares,cut most of cab mount off and reweld and beat pinch weld back with the 3.25in of lift or so i have ill be ok....i may need to get 2in wheel spacers from ecgs and sell the spidertrax.....acording to treadwrights website 315's are 1.5in taller and wider then i have right now 33.3 vs 34.7 10.2 vs 11.8........so its only 3/4in actual gain ill have to clear for....from looking at it today the cab mount and a very little bit of firewall is all that will hit on full stuff....this could get interesting buddy :)
  8. Apr 22, 2012 at 9:14 PM
    #388
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    remember, lift doesn't have anyhting to do with tire fitment. but you seem to have the right ideas. you'llprobably have to cut the pinch weld instead of just beating it (i had to cut mine). I hactually need to cut my pinch completely off and just lay a regular bead down the seam. I'm curious of the effects of the 2'' spacer. if they seem to fit when you do the test fit using a spidertrax, i'd stick with that.
  9. Apr 23, 2012 at 5:30 PM
    #389
    hard2kill
    Rhinebeck NY
    id rather not run a bigger spacer...2in is last resort
  10. Apr 23, 2012 at 5:44 PM
    #390
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    good call. in fact, unless the 315s rub the spindle or UCA with the 1.5s, i bet a 2 inch would rub even more.
  11. Apr 24, 2012 at 4:55 PM
    #391
    hard2kill
    Rhinebeck NY
    hey how much were you able to adjust the tires forward from the cab mount with the LR ucas?
  12. Apr 24, 2012 at 5:51 PM
    #392
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I didn't try. just put the spc logo out so it's in the zero position. i figured i'd rather cut up the fenderwell and cab mount more than sacrifice on-road handling at this point.
  13. Apr 24, 2012 at 7:07 PM
    #393
    pAP
    pAP ==========
    NJ
    24 Tacoma TH
    Just tint and ppl for now.
    I rotated mine one notch forward from logo out. Then had the alignment shop adjust the caster on the bottom to max and was at 2.4. Rides great on the road like that. I don't get any rub on my cab mounts anymore. Before, I had caster set at 2.6 with logo out and would get cab mount rub during flex.
  14. Apr 25, 2012 at 2:06 AM
    #394
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Soooooo, I'm thinking about building my own set of UCAs this summer if I have the time..... i'd take off the LRs, make sure they are set where i want them, and then build a jig around them. then put them back on while i build a new set using the jig. Compared to other suspension components on our trucks, the UCAs undergo relatively low forces. however, I will build them as if that were not the case.
    the plan would be to use a 1.25'' stainless FK uniball. Greasable bushings for the frame pivots (not sure if i would use poly or delrin yet), and then thicker walled tubing than any of the current UCA manufacturers. I would also strap the bushings and uniball cup for extra tensile strength at the welds, and then gusset the tubes on the bends. then to cap it off (litteraly), i would make a dust cap similar to what comes on the Icon billit UCAs and the allpro long travel UCAs.
    two reasons for doing this:
    1) I want uniball ucas, mostly for ease of maintenance
    2) I want to prove to myself that i can build a stronger product than what's out there (with the exception of the icons), and for a much lower price.
    edit: 3rd reason: ball joint UCAs and spindle gussets are kind of a pain in the butt when paired together.......
  15. Apr 25, 2012 at 7:02 PM
    #395
    hard2kill
    Rhinebeck NY
    Get em brotha I got faith in ur abilitys
  16. Apr 25, 2012 at 7:05 PM
    #396
    FearNothing321
    FearNothing321 You gonna eat that taco?
    Tony
    Knoxville, TN
    2019 Audi S3
    Heims :cool:
  17. Apr 25, 2012 at 7:07 PM
    #397
    drade
    drade BRUINS 4 LIFE
    ME
    2016 Toyota Tacoma TRD Off Road Short Cab Silver
    TRD PRO skid plate, wet kole seat covers, tint all around, red line tuning quick Lift system, paint protection film, gloss blacked out OEM emblems, electric start, heated seats.
    I hate SWB on tacomas, but let me say, yours is literally the only one I approve of. This thing is a beast. Props/rep to the max. Great job, and great choice of road armor. All pro FTW!
  18. Apr 25, 2012 at 8:16 PM
    #398
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I'm not sure i need the extra adjustment, and it woud make it more labor intensive, but they aren't too much more expensive, so it's something to consider.
    Thanks man! :oldglory:
  19. Apr 25, 2012 at 8:24 PM
    #399
    FearNothing321
    Tony
    Knoxville, TN
    2019 Audi S3
    Do it
    Solid mount your lowers, so you can align from the UCA
  20. Apr 25, 2012 at 8:29 PM
    #400
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I'm not sure I want to get that serious quite yet. pretty sure firestone wouldn't be too happy having to take out the uca bolts to do an alignment. I could align it myself, but I'd rather just take it to them since it's free. may do it to have the option later on down the road though.
