Colinb17's kinda sorta build thread - now with 4-link and long travel
Discussion in '2nd Gen. Builds (2005-2015)' started by colinb17, Jun 24, 2011.
  1. Mar 4, 2014 at 9:55 AM
    #4121
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Just ordered yet another electronic goodie (thanks for spending more of my money SMKYTXN :p) Dash cam this time. records on startup, records or takes photos when there is motion detected while the vehicle is off. has gps tracking/overlay. also has an accelerometer, so if you hit a certain g-force, it saves video from 15 seconds before and after the incident in a separate, locked file, that will not be overwritten, when card memeory is full. i think i may just put the rear view camera inside, to capture any break-ins, instead of trying to mount it in a way to capture a rear-end collision. the other option is to forget the second camera that it comes with, and instead, pull the feed from my existing back-up camera. some experimenting will happen.
    good news is that supposedly, this one actually records HD, vs the "fake" hd that the other cheap cameras in this price range tend to record.
    http://www.amazon.com/gp/product/B00CY9PFRI/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
  2. Mar 4, 2014 at 10:18 AM
    #4122
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    I am looking forward to seeing the video quality from that unit. If it's even close to 720P I'll be upgrading mine.
    Oh, and you're welcome!
  3. Mar 4, 2014 at 10:22 AM
    #4123
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I don't know if it'll be installed by the weekend, but i'll at least have it with me, along ith one of my laptops, so we'll at least get some nighttime and daytime samples for you.
    supposedly the main camera is 1080 and the rear view is 720. being that it's only a $100 unit, i will be more than happy with true 720. 1080 would just turn it into the deal of the century.
  4. Mar 6, 2014 at 5:23 AM
    #4124
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Hmmm, seems someone has stolen my tow rig idea. Inestead of a trailer, i want to do this same thing, but with a duce and a half.
  5. Mar 6, 2014 at 5:58 AM
    #4125
    SMKYTXN
    Nathan
    Houston
    DCFB
    Damn, that's hot
  6. Mar 6, 2014 at 6:08 AM
    #4126
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Let us know how you like it please.
    I'm interested in getting a dash cam but would like a review from someone I trust before I drop that amount of cash on one.
  7. Mar 6, 2014 at 6:50 AM
    #4127
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    hoping to get it all installed tonight, so i should have an idea after the weekend. i did record a few seconds on it in the apartment last night, and my guess is that you should be able to make out license plate numbers.....but we shal see.
    pictures for now:
    The main camera and screen
    top plug is for the auxilary camera, middle plug is charging, or corded data transfer, and the bottom plug is for the external GPS antenna (which i am actually mounting the unit from)
    HDMI for viewing on an external screen; realtime or recorded. micro SD card slot. takes up to a 32 gb card. we'll see how many hours that holds before full.
    here's all that it comes with:
    -primary camera/screen
    -auxilary camera
    -auxilary camera cable extension
    -GPS antenna
    -suction cup mount
    -non suction universal mount
    -12v car charge cord
    -data cord
    here's how mine will likely be set up.
    camera, GPS, Aux camera, and charger
    The GPS antenna is installed in this picture. i put a 3m adhesive pad on the gps, to hold it to the windshield, instead of a suction cup.
    Credit for this step goes to Nathan (SMKYTXN). instead of dealing with a plug, you can adapt the car charger to hard wire it into the IG1 or IG2 fuse.
    only black wire i had was 10g, so while it is against my normal practice, i had to use red for ground as well. tossed black heat shrink on it every so often, so i can differentiate them.
    all sealed back up, and ready for instal :)
  8. Mar 6, 2014 at 8:12 AM
    #4128
    BradyT88
    BradyT88 Well-Known Member
    For a second I thought you were saying you had used the 10ga wire on that:eek: Haha I have some interesting color combos going on with my wiring... you can't really use a color scheme when splicing into the ECU and such. Too bad you can't easily find 22 ga wire in random colors like pink with a blue stripe and green with a black stripe etc. Haha. Would sure make figuring out where all the red wires are going.
  9. Mar 6, 2014 at 8:13 AM
    #4129
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    hmmmm, just realized, that if this thing ctually shoots half way decent HD video, and the battery life is more than 5 minutes after being unplugged, i've just gotten myself an hd camcorder for $100 :woot: even has 4x zoom (though it's probably digital zoom).
  10. Mar 6, 2014 at 8:15 AM
    #4130
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    haha, no. i test fit the black 10g, and it didn't even fit out the end of the car charger. go buy the rainbow pack of heat shrink, and you'll be able to color code all of your wire terminations, regardless of shield color. it really does make life easier. hell of a lot cleaner than electrical tape too....
  11. Mar 6, 2014 at 8:35 AM
    #4131
    CanisLupus
    Stokesdale | NC
    So is it supposed to plug into the 12V plug all the time? I guess you will see after finding out how long it lasts unplugged?
    That is a big 12V charger connection(?) to be plugged in all the time.
  12. Mar 6, 2014 at 8:38 AM
    #4132
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    you leave it plugged in (or spliced in in my case) all of the time. you do so to a port that cuts power when the keys are removed. when you turn on the vehicle, and supply power, it automatically turns on and starts recording. when you cut power, it goes into a battery fuled "sleep" mode, with only the motion detection active. when "signifficant" motion is detected, it will start snapping photos (good for if someone were to break into your vehicle)
  13. Mar 6, 2014 at 8:41 AM
    #4133
    CanisLupus
    Stokesdale | NC
    Copy…I guess it just looks big to be poking out of the 12V plug all the time :rolleyes:
  14. Mar 6, 2014 at 8:46 AM
    #4134
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    that's why i soldered the wires into it. the adaptor will be stowed behind the dash somewhere. all you'll see is a couple inches of the power cord going from the headliner to the camera. everything else will happen behind the scenes.
    edit: plus, my 12v has been moved from the stock location, to being tucked away inside the little cubby on the right side of the steering column.
  15. Mar 6, 2014 at 8:47 AM
    #4135
    CanisLupus
    Stokesdale | NC
    Must be nice to have wiring skills. :rolleyes: I'm pretty much on the level of a mentally retarded raccoon.
  16. Mar 6, 2014 at 8:48 AM
    #4136
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    bah, you could do it. all it was, was two solder spots on the board, and then it's like powering and grounding anything else. toughest part is running the sire itself...
  17. Mar 6, 2014 at 11:44 AM
    #4137
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    That camera looks pretty cool.
  18. Mar 6, 2014 at 11:48 AM
    #4138
    SMKYTXN
    Nathan
    Houston
    DCFB
    Looking forward to seeing some video from the new camera. Hopefully we won't have to wait as long as we've waited for the quad cam footage from Gilmer. :brianr:
  19. Mar 6, 2014 at 11:51 AM
    #4139
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i got half done with putting everything together, and then my video software shit the bed :( i can upload the raw footage if you'd like. just a lot of dead time in it where i'm hovering with nothing going on....
  20. Mar 6, 2014 at 11:58 AM
    #4140
    SMKYTXN
    Nathan
    Houston
    DCFB
    Don't worry about it. I'm realy bad with editing, in that if I don't finish the editing within a day or two I give up on it.
