Colinb17's kinda sorta build thread - now with 4-link and long travel
Discussion in '2nd Gen. Builds (2005-2015)' started by colinb17, Jun 24, 2011.
  1. Mar 13, 2014 at 11:43 AM
    #4221
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
  2. Mar 13, 2014 at 11:49 AM
    #4222
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Those tanks would work. Its all about the regulator though. That is where the quality vs money comes in. Some will freeze while airing up your tires if you arent careful.
  3. Mar 13, 2014 at 11:52 AM
    #4223
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Hey, it's a party!
    I paid around $85 for a used aluminum tank from my fire department supply store. I would stay away from the steel tanks for weight savings alone. The expensive part is the valve. You have two choices there, or powertank.
    You're looking at $100 for the tank, $135 for the valve, and then you have to buy a mount, air line, air chuck, tank boot, etc. It's almost cheaper to buy a complete setup from wheelers.
  4. Mar 13, 2014 at 12:05 PM
    #4224
    TacoFMS
    Justin
    Louisa County, VA
    thank you for the insight, you are one of many that have stressed that topic to me, dont plan on cheaping out on that part of it. thought though i might be able to skim on price for the tank to be able to afford the regulator sooner.
    sadly i have everything already except the tank and regulator. i have a 10lb mount, spare coil line, chucks, boot and all that good stuff. just gotta get a tank and then decide on the gauge. but thanks again for the heads up!!!
  5. Mar 13, 2014 at 12:09 PM
    #4225
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    1- definitely an aluminum tank
    2- if buying new, you'll most likely get a better deal by purchasing an all included kit, vs. buying parts separately
    3- your valve/regulator will ice up. A quality valve and regulator will function properly/acurately after icing up
    4- there are two ways to determine how full your tank is:
    ---1) weigh it full and weight it at the current level and take the difference
    ---2) get a regulator with a "tank pressure" gauge on it. found out over the weekend, that the tank pressure gauge on the power tank setups are very acurate. this will cost more, but adds a level of convenience.
    5- budget for how you will store/mount it. this is not something you want to have floating around in the back seat or rolling around in the bed.
  6. Mar 13, 2014 at 12:37 PM
    #4226
    TacoFMS
    Justin
    Louisa County, VA
    already have this to use... im thinking it should work just fine, even though it was originally purchased for a fire extinguisher, im thinking it should still hold it just fine.
    http://www.amazon.com/gp/product/B0...pf_rd_t=101&pf_rd_p=1688200382&pf_rd_i=507846
  7. Mar 13, 2014 at 12:47 PM
    #4227
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    substantial weight difference.
    that mount will work well. $15 cheaper than the aluminum power tank mount too.
  8. Mar 13, 2014 at 1:07 PM
    #4228
    TacoFMS
    Justin
    Louisa County, VA
    Free for me, so i guess $46 cheaper than the one i linked!!! :D
  9. Mar 13, 2014 at 7:03 PM
    #4229
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Tried the new rear view camera today and removed the head unit. there is a video 1 input and it worked, but the image was mirrored and there is no option to correct it on the head unit. So i'll have to find a camera that is designed for front facing I suppose.
    thanks for the advice though colin!
  10. Mar 13, 2014 at 9:23 PM
    #4230
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    well shoot, that's unfortunate.
    try searching for a security camera instead or a backup camera. the security cameras are typically standard display, instead of the mirrored image that backup cameras have built in.
  11. Mar 13, 2014 at 9:28 PM
    #4231
    SMKYTXN
    Nathan
    Houston
    DCFB
  12. Mar 13, 2014 at 9:35 PM
    #4232
    Jetlander
    Jetlander Just trying to measure up...
    Jonathan (aka MOAB)
    Depends on the day.
    2010 Tacoma DCSB 4x4 SR5
    TKO Wheel w/ 35" BFG KM2, Volant CAI, Safari Snorkel, 3" lift, All-Pro Full Skid Underarmor, Chopped/Re-Routed FlowMaster Exhaust, CBI Moab 2.0 Front Bumper, DerpWerx High Clearance Rear Bumper, Rear Tire Swing Out, BAMF Sliders w/Kickouts, King Resi w/700# Coilovers on front, Total Chaos UCA's, King Long Travel with Resi's, Shock Hoops and King 2.5 Bump Stops, OME Dakar Leaf Springs mounted on All-Pro Shackle Flip w/ U-Bolt Flip, extended SS Brake Lines, DerpWerx Bedrack, 10# C02 Tank, Black Badges, Dual Optima Red Top's, Blue Sea 12 Fuse Block on custom Block mount, SuperWinch 9.5iSR Talon w/synthetic line, Prolink Thimble, 20" Rigid Dual Row LED Light Bar, Rigid Dually Floods, OTRATTW Switches, Cab Mount Chop, Cobra CB w/ 4' Firestik, Center Counsel Glock 23 mount (with plenty o' ammo!), Weathertechs, and plenty more mods to come!
    I have an idea… I will buy all the necessary toys to hook up a camera system on my truck. Colin and Nathan can come over and install it. I'll supply the beer!
    Edit: Had to add Nathan
  13. Mar 13, 2014 at 9:40 PM
    #4233
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    gotta supply a thin crust peperoni pizza as well. then we can reminisce about pulling driveshafts in strip mall parking lots
  14. Mar 13, 2014 at 9:41 PM
    #4234
    Jetlander
    Jonathan (aka MOAB)
    Depends on the day.
    I can do that. I'm more serious than you probably think!
  15. Mar 13, 2014 at 9:44 PM
    #4235
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    the hardest part is figuring out where you want the monitor. the wiring itself is cake. figure out that first part and give me a holler.
  16. Mar 13, 2014 at 9:46 PM
    #4236
    Jetlander
    Jonathan (aka MOAB)
    Depends on the day.
    Alright I have it figured out. Now PM me a list (preferably with links) of everything I need. I will start acquiring this week sometime.
  17. Mar 13, 2014 at 9:49 PM
    #4237
    SMKYTXN
    Nathan
    Houston
    DCFB
    I'm still leaning towards a replacement mirror with a larger screen than stock instead of the larger display mounted on the dash. Too many ideas bouncing around in my head at the moment.
  18. Mar 13, 2014 at 9:53 PM
    #4238
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    for a setup like mine, you'll need a monitor, cameras, and switching unit. i'll dig up the links tomorrow for ya.
  19. Mar 13, 2014 at 9:53 PM
    #4239
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    more ideas are more betterer.
  20. Mar 13, 2014 at 9:56 PM
    #4240
    SMKYTXN
    Nathan
    Houston
    DCFB
