Colinb17's kinda sorta build thread - now with 4-link and long travel
Discussion in '2nd Gen. Builds (2005-2015)' started by colinb17, Jun 24, 2011.
  1. Mar 27, 2014 at 7:27 AM
    #4341
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    You're going to need more run time considering you show up to camp in the dark every time. :rofl:
  2. Mar 27, 2014 at 7:37 AM
    #4342
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    :brianr:
    except for maybe 1 or 2 others, i'm the yungest in the office, meaning i get the "privelage" of working nice long hours....even on fridays :pout:
    i did take off that friday of Toyota Jambroree, so i'll have all day friday there. but i'll still be getting there well after dark on thursday :facepalm:
    but really, while MOAR RUNTIME!!! is alway better, and the American way, i'm not going to need 9 hours of tent illumination. for camp setup, i'll probably still jsut use the truck lights.
  3. Mar 27, 2014 at 7:45 AM
    #4343
    SMKYTXN
    Nathan
    Houston
    DCFB
    Well, we're covered for the after dark arrival this time.
    More is always better!
  4. Mar 27, 2014 at 9:09 AM
    #4344
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I need to stop playing on the interwebz......
    just found this. may have to get a bigger battery and add these to the light box, or just build a second box. i have a little bluetooth speaker box that works really well, but it's not waterproof. I have some nice Polk Audio marine speakers sitting around that would be perfect for this. all it'd need is a waterproof head-unit.
  5. Mar 27, 2014 at 9:38 AM
    #4345
    xweslingx
    xweslingx Well-Known Member
    Wes
    Durham, NC
    09DCSB locked and armored
    Just gussets... everywhere
    Now were talking.
  6. Mar 27, 2014 at 11:41 AM
    #4346
    SMKYTXN
    Nathan
    Houston
    DCFB
    Tear apart your bluetooth speakers and add the module to the new speakers in the ammo can.
  7. Mar 27, 2014 at 11:49 AM
    #4347
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i thought about that, but i really like how compact that speaker is and how well it works.
    you can pick up a low end marine head unit for $50. then you have radio, cd, and aux inputs. hell, for $75 on Amazon, you can get a head unit and 2 speaker, all waterproof. it's not nice stuff, but then again, neither are the acoustics of an ammo can.
  8. Mar 27, 2014 at 11:53 AM
    #4348
    SMKYTXN
    Nathan
    Houston
    DCFB
    You'll be needing some lasers and a disco ball next.
    Oh, and a package arrived today. :spy:
  9. Mar 27, 2014 at 12:05 PM
    #4349
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    :woot:
  10. Mar 27, 2014 at 2:45 PM
    #4350
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I've gotten a larger than normal number of PMs in the last 2 weeks about Terra Grapplers, so i'll jsut repost these. actual wheeling pictures with them can be seen on the first page of the build.
  11. Mar 27, 2014 at 2:52 PM
    #4351
    Manwithoutaplan
    ID
  12. Mar 27, 2014 at 8:44 PM
    #4352
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Brown Santa dropped off some stuff today. Genisis LED, Blue Sea waterproof 12v outlet, and Rigid Industries waterproof switches. only thing still to come is the battery, which arrives tomorrow. Got everything mounted and sealed up this evening. tomorrow all I have to do is wire everything up, and we're ready to rock.
    i'll post the installed pictures tomorrow morning.
  13. Mar 27, 2014 at 9:03 PM
    #4353
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Wasn't that from the one Raush trip???
    The blue trail on the north property?
  14. Mar 27, 2014 at 9:07 PM
    #4354
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Rausch creek, yes. I don't recall the trail though. probably the new section though, as I remember a lot of those newly cut stumps over there.
  15. Mar 28, 2014 at 5:29 AM
    #4355
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Hardware done, just have to wire now....
    spot light stowed for vertical flood use
    waterproof 12v outlet to both charge the units battery, or to charge celll phones etc.
    Drain hole so the handle area doesn't fill up with water when it rains
    there is a recessed area where the lense is pressed into the sluminum housing. i don't want that having water just sit in it, so i siliconed the gap.
  16. Mar 28, 2014 at 6:03 PM
    #4356
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    It's so nice when things work out......
    turns out that these batteries might as well have been made specifically for this box. the one came in today. fit so well that I went searching for more. it's actually designed to power a game camera, so I headed to Academy and found the identical batteries. I can actually fit a 4th, but I want to use that space for some other stuff. 9.25 hours of flood light and 1.5 of spot light just tripled to almost 28 hours of flood light, or about 4.5 hours of flood light :D
  17. Mar 28, 2014 at 6:08 PM
    #4357
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Badass dude!
  18. Mar 28, 2014 at 6:25 PM
    #4358
    SMKYTXN
    Nathan
    Houston
    DCFB
    Coming together nicely!
  19. Mar 28, 2014 at 7:38 PM
    #4359
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    thinking I may add a waterproof double USB port with the voltage regulator inside the box, as well as toss a small 150 watt inverter in the box with a waterproof AC outlet. that way i'll have all of the charging bases covered, and will never have to open the box except to get the charger for the box itself out. at that point i'll add 3 more waterproof switches to control power to the 3 charging ports.
    thanks. it's been a fun little spur of the moment project :)
    should have it all wired up before the night's out. i'll bring it over tomorrow.
  20. Mar 29, 2014 at 7:12 AM
    #4360
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    you have too many hobbies...
    :devil:
