Colinb17's kinda sorta build thread - now with 4-link and long travel
Discussion in '2nd Gen. Builds (2005-2015)' started by colinb17, Jun 24, 2011.
  1. Jul 8, 2014 at 9:29 AM
    #4621
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    IMO........ KISS
    Gravity works fine boat tanks and they come with a primer bulb. I see no need for filters and electric pumps but I have grown up on boats not a truck so... I could be missing something.
    A good ground for filling it up would be important.
  2. Jul 8, 2014 at 9:34 AM
    #4622
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    The pump will be gravity fed, not a pickup type pump in the tank, so that will be pretty simple. There will also need to be a low point for the fuel outlet.
    Colin also wants to hit a switch and transfer the fuel so some sort of electric cutoff will have to be used, or the fuel pump could serve that purpose. Will the pump be able to hold back the fuel?
  3. Jul 8, 2014 at 9:53 AM
    #4623
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    thaose are actually nicely priced. full blown steel fuel cells go for that much just for the shell, an you still need all of the other stuff to actually have it work.
    Kiss indeed. however, to prevent sloshing, i want the tank to either be 100% full, or 100% empty. essentially drive until the empty light comes on, then flip a switch for a few minutes, and then you're all filled up again. i don't want to be dealing with fuel foam, baffles, etc.
    I was actually thinking about using a pickup pump. that was there is no need to rely on the pump being able to hold back fuel. 12v self-priming diesel/oil/gasoline transfer pumps are pretty easy to find, and have some pretty good flow rates.
    hardest part of this is probably going to be finding the best place to tie into the existing tank/filler system. needs to be secure, leak free, and not cause the code to be thrown that you get when your gas cap isn't tight.
  4. Jul 8, 2014 at 9:58 AM
    #4624
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Just tie into the existing filler neck anywhere and use a check valve in the line to the aux tank.
  5. Jul 8, 2014 at 10:09 AM
    #4625
    XXXX
    sKiP
    05 Prius
    I would never be concerned with that. Way to overly complicated.
    As Colin said below...trucks empty so all you need to do is, screw on manual primer bulb to full aux tank, insert end into existing exterior fuel door, couple prime pumps, and all filled up.
    If you really want a emergency shut off just use a:
    I get it, but for something you'll only need should you plan poorly or in an emergency it's way to complicated IMHO. I know you guys like to go all out, but this is a simple project that needs to remain foolproof so KISS applies even more.
    Shit like this makes me LMAO:
    it's complicated, expensive, not even close to reliable as a gravity fed system and dangerous IMHO.
    In the end all this guy needed was:
  6. Jul 8, 2014 at 10:19 AM
    #4626
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  7. Jul 8, 2014 at 10:25 AM
    #4627
    SMKYTXN
    Nathan
    Houston
    DCFB
    Wow, they put a transfer pump on a roof mounted tank? Good grief.
    Colin, and myself, do tend to go overboard on things like this. :)
    My tank will be mounted just above the frame rails so there should be enough differential drop to drain the auxiliary tank into the main tank with gravity alone. My issue will be accessing the valve to start the transfer as it will be behind sheet metal. Maybe an electronic globe valve would be in order. Flip a switch, let the fuel gravity feed into the stock filler neck, and be done. Just have to see how the bed and tank lays out before I decide if I need a pump or not.
  8. Jul 8, 2014 at 11:21 AM
    #4628
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    having never taken the factory filler neck out, how would you tie into it if it were your project? thread a fiting in, and properly seal the threads?
    not as reliable doesn't mean unreliable. if a pump were to fail, there's no reason i couldn't siphon transfer the fuel as a backup. what do you see that's more dangerous about it than the factory system assuming everything is tied together properly, and fused/grounded adaquately?
    when can i see the new candy sitting in your garage?!?! Sorry for not replying to the picture you sent me. last two weeks have been insane :bananadead:
    the fact that there is a tank permanately mounted on the roof is pretty terrible, regardless of the pump. talk about COG issues.
  9. Jul 8, 2014 at 11:51 AM
    #4629
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  10. Jul 8, 2014 at 12:00 PM
    #4630
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Hah, that spare tire one is cool. not so great for off road, but an awesome idea for a street only truck/SUV. cool stuff on their site.
  11. Jul 8, 2014 at 7:51 PM
    #4631
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I'll be working on it every afternoon through Saturday. Come on by man.
  12. Jul 8, 2014 at 7:57 PM
    #4632
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    how's about Saturday? haven't gone to work the last two weeks, so this week will have some long hours to say the least :eek:
  13. Jul 8, 2014 at 8:00 PM
    #4633
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Sounds good.
  14. Jul 8, 2014 at 8:05 PM
    #4634
    Manwithoutaplan
    ID
    I have a question on the fake bolts in place of the fenders? What size bolt did you use through the holes.
    future reference
  15. Jul 8, 2014 at 8:15 PM
    #4635
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    This is my set up right now. But I might just jump up to one larger boat tank
    8982254379599856b1946f818727d990_zps8ee8_f6721642c3b749dd9755440f85451ddddecb6ab0.jpg
    3f641ec924f7ae2637a6a75373b4ee50_zpsd204_3ada79707da35e3490c37332ba451f4e653156e8.jpg
    It is this that I added some more hose for length
    914249513591619acc6a0154e3eb8e48_zps4404_8861380eaf5aea411580992114da44c4469603b8.jpg
    5562eb35172fbaf4478ac4d18dc1ca9e_zpscbc0_e67b1736bb35a21e630ea360efe9836965a59727.jpg
    df82784d7634565c96cbcdbec3ecf282_zpsc38c_7c2571fcd15bf59550626cf6f134249340902ba7.jpg
    I might take just a bit out of the hose length tho. But it does give me plenty of reach from the far side of my rack to the filler neck. Won't have to move the tanks around just take the camp off and stick in the pick up tube. A couple pumps on the handle and fuel starts to flow at a really good rate
  16. Jul 8, 2014 at 8:15 PM
    #4636
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    off the top of my head......not a clue.
    I can check though. I doubt it was much larger than 1/4'' diameter. length will depend on what washer setup you use.
  17. Jul 8, 2014 at 8:18 PM
    #4637
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    where do you keep the cans when you aren't fueling up? i'm trying to keep the COG low., so i'd rather not keep the cans up on the roof, or have to lift them there when I need to fill.
    also would like to be able to transfer the fuel into the factory tank on the fly. because i'm lazy :eek:
    I do like that handle though. could toss some fuel in the trailer when it undergoes the next overhaul, and run a pump through that handle :drevil:
  18. Jul 8, 2014 at 9:34 PM
    #4638
    uscg2008
    coby
    I just leave them up there, ya it adds a little extra weight up there but 16 gal off fuel doesn't really weigh that much really. And the pumping the handle acts like a siphon I guess it would work if you added a pump into the system. Then u wouldn't really have to pump the handle to get the flow started.
  19. Jul 8, 2014 at 9:38 PM
    #4639
    Manwithoutaplan
    ID
    Could you please check I just ripped off my fenders.
  20. Jul 8, 2014 at 9:39 PM
    #4640
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I'm sorry but that's really funny! :laughing:
