Colinb17's kinda sorta build thread - now with 4-link and long travel
Discussion in '2nd Gen. Builds (2005-2015)' started by colinb17, Jun 24, 2011.
  1. Jul 9, 2014 at 7:22 PM
    #4661
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    11 months
  2. Jul 9, 2014 at 8:27 PM
    #4662
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Sounds like Minot, North Dakota. Spent a little time up there about this time last year, helping with the start-up of a natural gas plant we had just finished building. Mcdonalds cashiers make $17 an hour. a run of the mill loaf of bread is $8.00, and hardware/building supplies are through the roof. had to drive 100+ miles to the nearest walmart for any sort of reasonable price on anything.
  3. Jul 9, 2014 at 8:35 PM
    #4663
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    We just opened a store there.:cool:
  4. Jul 9, 2014 at 9:07 PM
    #4664
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Much needed. as the plant neared completion, an entire new town started sprouting up around the entire area. some mainstream shops that can drive prices down are going to be very welcomed.
  5. Jul 9, 2014 at 9:15 PM
    #4665
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Just ordered the tank and two pumps for the aux. fuel project. going to try to get everything mocked up this weekend. may even get it plumbed if i'm lucky.
    ordered two pumps. i'll run them in parallel, for faster fuel transfer, as well as redundancy, in case one pump craps out.
    may get something along these lines depending on how exactly the tank sits, to allow for easier fuel-ups if needed. it would allow me to mount a filler/cap flush with the bed rails, between the cab and tool box.
  6. Jul 9, 2014 at 9:17 PM
    #4666
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  7. Jul 9, 2014 at 9:24 PM
    #4667
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    to clarify, if I get the Jaz filler port, It would be similar to this (but smaller), and there would be a hose going to the filler cap by the tool box
    where it would lead to and actually be filled at. most likely use a marine style filler cap. vvvv
  8. Jul 10, 2014 at 6:44 AM
    #4668
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Sorry for the delay, lol I had to go look at the filler neck on my truck.
    The metal filler neck is around a foot long or so and then a rubber hose is attached to it from the tank itself. I would tie in there, with a short stub of hose, a tee, and some clamps. You can even shorten the end of the filler neck to make room for the tie-in if need be, but things may be flexible enough that you won't need to.
  9. Jul 10, 2014 at 6:47 AM
    #4669
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Went there on Tuesday and was greatly dissappointed. And then I went to check out and all that was open was the self-checkout... The lady working there was confused on hardware at that point.
  10. Jul 10, 2014 at 6:48 AM
    #4670
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    no worries. parts don't come in until tomorrow anyway ;)
    I was really hoping to not have to drill into the main filler neck, so i'm glad you said tee into the rubber hose, because that makes things a lot easier. at 1.4 gallons per minute, i doubt i'll exceed the flow rate of that hose, which was one of my main concerns.
    Gracias :)
  11. Jul 10, 2014 at 6:55 AM
    #4671
    phillstill
    phillstill Long hair don't care
    Phill
    Tulsa
    LT35TANK
    Everything
    :woot: let me know if you need an extra hand. I have a slow Saturday.
  12. Jul 10, 2014 at 6:57 AM
    #4672
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    10-4 buddy
  13. Jul 10, 2014 at 7:02 AM
    #4673
    jbmccul
    jbmccul Well-Known Member
    2021 GMC Sierra AT4, 2019 Audi A5, 2017 Audi Q5
    You get my PM about the lights?
  14. Jul 10, 2014 at 7:15 AM
    #4674
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Just replied :)
  15. Jul 10, 2014 at 10:55 AM
    #4675
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Mod day at my place? Lucario Runner will be down as well.
  16. Jul 10, 2014 at 10:55 AM
    #4676
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    This Saturday? Hmm...
  17. Jul 10, 2014 at 12:00 PM
    #4677
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    YES! Robert best not "get sick" again :rolleyes:
    i still need to put that last piece of my rear breaks back in.......got the piece, but never installed it
  18. Jul 10, 2014 at 1:17 PM
    #4678
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Good news everyone! I'm sick!
  19. Jul 10, 2014 at 3:14 PM
    #4679
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  20. Jul 10, 2014 at 4:02 PM
    #4680
    Lucario Runner
    Robert
    06 Toyota 4Runner
    *brakes
    better drink some more green tea mister...............:p
