Colinb17's kinda sorta build thread - now with 4-link and long travel
Discussion in '2nd Gen. Builds (2005-2015)' started by colinb17, Jun 24, 2011.
  1. Oct 8, 2014 at 6:34 AM
    #4861
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    "Taste the rainbow!"
  2. Oct 8, 2014 at 6:42 AM
    #4862
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    You guys are way too picturesque... Those shots look like the pretty people in the picture frames when you buy them at the store.;)
    Congrats on the move & getting hitched - next comes kiddos & then it all goes downhill. :p
  3. Oct 8, 2014 at 6:47 AM
    #4863
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    :rofl:
  4. Oct 8, 2014 at 6:49 AM
    #4864
    Large
    Large Red
    Damn that's funny ..
  5. Oct 8, 2014 at 8:58 AM
    #4865
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Congrats man!
  6. Oct 8, 2014 at 9:06 AM
    #4866
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    congrats!
  7. Oct 8, 2014 at 9:26 AM
    #4867
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Thanks guys. we actually got engaged 10 months ago, but with my work situation, were jsut recently able to get everything together.
  8. Jan 2, 2015 at 7:20 PM
    #4868
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Were your cracks at the tie rod arm off of the spindle? I noticed mine are cracked after just a year on them. Did you just grind them out and reweld?
  9. Jan 7, 2015 at 8:05 PM
    #4869
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    yes and yes.
    lots of stress in that area, with relatively little weld area compared to the rest of the gusset. perfect recipe for cracked welds. you'll see a lot of newer gusset designs using 2-4 extra pieces of plate to make up a full gusset for the tie rod mounting portion of the spindle.
    granted my front end hasn't taken a hit like the one you quoted singe then, but the reweld was still intact last time I looked.
  10. Jan 19, 2015 at 9:54 AM
    #4870
    YYZ
    YYZ Member
    YYZ
    SLC UT
    SR5 Sport 4x4
    A.R.E. Shell
    First of all a big Contratulations Colin.
    I've gone through your entire build thread (every page) looking for your gas tank pics and finally found them (p 239 lol). Anyhow, what was the outside diameter of the two new ends you put on the "T" (fit inside filler tube diameter). I'm looking to do a similar setup but gravity fed instead of pumps - intercepting neck below bed level (if even possible, I haven't pulled it out yet). FANTASTIC build and thanks for all the pics.
  11. Jan 20, 2015 at 1:51 PM
    #4871
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Thanks, that is what I figured. I think I will add a gusset like you mentioned and are on the ones for retaining sway bar.
  12. Jan 20, 2015 at 6:45 PM
    #4872
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I need to replicate your aux tank mod.
    Let me know when your ready to get your fab on and I'll take a ride down to MD. :cool:
  13. Mar 3, 2015 at 7:02 AM
    #4873
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
  14. Mar 3, 2015 at 7:04 AM
    #4874
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Sorry Craig, just saw this.
    how about we wait until it warms up a little :eek:
    but then it's game on. should be a lot easier the second time around.....
  15. Mar 3, 2015 at 7:48 AM
    #4875
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Say the word. I see this as probably one of the most useful mods for cross country driving. :cool:
  16. Mar 3, 2015 at 7:48 AM
    #4876
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    Wow, you really are still alive and kickin!!
  17. Mar 3, 2015 at 7:57 AM
    #4877
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    it's quite nice when you can get 10 mpg, pulling a trailer, and bathroom breaks still govern your stops as opposed to stopping to fill up.
    Hey bud :wave: still alive, and kickin like a mad man.
    what I would do for an 8th day in the week.....
  18. Mar 3, 2015 at 8:03 AM
    #4878
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    I got great mileage coming home from Gilmer at 60mph. Maybe this driving slow thing you do Colin, is all that it's cracked up to be. :luvya:
  19. Mar 3, 2015 at 8:09 AM
    #4879
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Agreed. When you can, and if you still have it, could you post a parts list? I'll need to devise a different way to fill the tank as I've got a cap on top of my bed...
  20. Mar 3, 2015 at 8:46 AM
    #4880
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    that, and you didn't have 50 lbs of driveshaft spinning the whole way home :rolleyes::p
    i'll make one hell of a grampa some day, cruising at 45 on the highway in my caddy. :cool:
