Colinb17's kinda sorta build thread - now with 4-link and long travel
Discussion in '2nd Gen. Builds (2005-2015)' started by colinb17, Jun 24, 2011.
  1. Apr 2, 2015 at 9:35 AM
    #4921
    Manwithoutaplan
    ID
    i have question for you???
    Are you running a front bumper camera if so is your image reversed. How did you remedy this?
  2. Apr 2, 2015 at 9:37 AM
    #4922
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    :spy:
  3. Apr 2, 2015 at 9:39 AM
    #4923
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    oops, answered the question in Nathan's build before I saw it here.
    a lot of monitors have a mirror button, which can flip and mirror the image to whatever is the correct orientation for the application. you can also get non mirrored cameras on Amazon for under $20.
  4. Apr 2, 2015 at 9:45 AM
    #4924
    Manwithoutaplan
    ID
    thank you very much sir
  5. Apr 2, 2015 at 10:19 AM
    #4925
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Dejavu! :rolleyes:
  6. Apr 2, 2015 at 11:20 AM
    #4926
    Manwithoutaplan
    ID
  7. Apr 6, 2015 at 7:01 AM
    #4927
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    pup learned that he loves hanging out the window over the weekend. still pretty small though, so at anything over 30 mph, he gets blown back into the truck.
  8. Apr 6, 2015 at 7:07 AM
    #4928
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    2016 is my goal as well! Although our wedding date is set for October 2016, Hopefully it all works out;)
  9. Apr 6, 2015 at 7:08 AM
    #4929
    NC15TRD
    Nick
    PA
    Best keep him strapped in! One of my friends had their dog jump out of their truck and got hit by the car behind them
  10. Apr 6, 2015 at 7:09 AM
    #4930
    NC15TRD
    Nick
    PA
    Bachelor party with all of TW!!!
  11. Apr 6, 2015 at 7:11 AM
    #4931
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    yeah, he's always on the leash when the window is down. had a couple of friends lose dogs that way because they were too lazy (or stupid) to clip a leash on and have the passenger hold on. only takes one time to lose your buddy out the window.....
  12. Apr 6, 2015 at 8:32 AM
    #4932
    NC15TRD
    Nick
    PA
    Would be an awful day for sure
  13. Apr 30, 2015 at 3:57 AM
    #4933
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    hey Colin, I sent you a pm the other day. just wondering if you had any input/ideas?
  14. Jun 2, 2015 at 5:59 AM
    #4934
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    Happy Birf!
  15. Jun 2, 2015 at 10:55 PM
    #4935
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    I did mine at home. Just pull out the drive shaft undo the u joint, take the nut off and then I used a pair of two jaw pullers to pull the carrier bearing off. The new one should just slide on with a little grease. I then used a combination of a ball joint remover tool, sockets and a bench vise. The bench vise and socket technique worked the best for putting the u joints back together. Just make sure you don't put to much grease into the new u joint cups. And don't forget to use a punch on the side of carrier nut after you torque it to set it. Hit me up if you have any more questions
  16. Jul 10, 2015 at 5:45 AM
    #4936
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Finally have some time this weekend to work on the truck. two items on the list are to replace a shot carrier bearing, and install the filler neck or sorts for my aux tank.
    Plan for the aux tank filler is to use a marine deck filling port. I'm going to cut a piece of plate and weld it to the bed rack to hold the fill port in place. if it can hold up in a marine environment, it'll do just fine for the truck. also using marine grade universal hose, compatible with gasoline
    side view.....
    XPOTRON likes this.
  17. Jul 10, 2015 at 6:16 AM
    #4937
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Going racetruck style!
  18. Jul 10, 2015 at 6:25 AM
    #4938
    SMKYTXN
    Nathan
    Houston
    DCFB
    ckeene9 likes this.
  19. Jul 10, 2015 at 6:51 AM
    #4939
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    for when you need to dump 10 gallons of fuel into a truck in 5 seconds :eek:
  20. Jul 10, 2015 at 7:43 AM
    #4940
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    I would say you need to get them but the Male connector is $300 and the female end is $260, and that dosent include tubing or the dump can, which is another $210
