Colinb17's kinda sorta build thread - now with 4-link and long travel
Discussion in '2nd Gen. Builds (2005-2015)' started by colinb17, Jun 24, 2011.
  1. Aug 29, 2013 at 5:49 AM
    #1921
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Few other threads I've looked through looks like a speculated 1-2mph gain.
  2. Aug 29, 2013 at 5:53 AM
    #1922
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    I'm always skeptical of people who talk about mileage without posting their before and after numbers, averaged ove a decent duration. I've found that a lot of the guys claming milage from various modifications have a lot in common with the guys claiming noticable increases in HP from an intake.
    I jsut know i haven't seen a change in the 2 tanks since mine's been on.
  3. Aug 29, 2013 at 6:08 AM
    #1923
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Boom, hers's you guy!
  4. Aug 29, 2013 at 6:11 AM
    #1924
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    Nice! Almost got those but wanted a road friendly set for dd. Mounted measurment is right at 34.4".
    It will be with no more than 3" of front lift. Whole bunch of cutting, beating, grinding and welding for the 36" :D good thing is they are skinny tall.
  5. Aug 29, 2013 at 6:17 AM
    #1925
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    what dimensions are the 36s? i thought they were 12.5 wide? i'd call a 10.5 skinny at that hight, but a 12.5 would be pretty normal, no?
  6. Aug 29, 2013 at 6:29 AM
    #1926
    MY50cal
    Mojo
    Camden County, NC
    Yep.
    TSL bias; Q78-16LT, 35.5" x 9.5"
    From what I've read, they run a little large. So, ~36" x ~10.5" ?
  7. Aug 29, 2013 at 6:36 AM
    #1927
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Nice! that's an awesome (and fairly hard to find) size.
  8. Aug 29, 2013 at 6:44 AM
    #1928
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    yall been just hammering the hell out of the pinch or cutting it off completely and rewelding? or somewhere in between? i currently only have mine cut back, but not far enough to need rewelding.
  9. Aug 29, 2013 at 6:53 AM
    #1929
    MY50cal
    Mojo
    Camden County, NC
    Yep.
    I'm going the inbetween route. Trim and beat.
  10. Aug 29, 2013 at 6:57 AM
    #1930
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    10-4
    gonna do the same hopefully over the long weekend if temps don't stay above 100.
    probably going to wait to see if i actually have to cut the fenders until i have the tires on though. no need to cut if i don't have to, or more likely, cut further than i need.
  11. Aug 29, 2013 at 6:58 AM
    #1931
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    I cut the pinch weld flat, then beat back a little bit with a BFH :)
  12. Aug 29, 2013 at 6:59 AM
    #1932
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    correct me if i'm wrong, but if you cut it flat, isn't there no more weld holding the two panels together?
  13. Aug 29, 2013 at 7:07 AM
    #1933
    PLC721
    Patrick
    Chandler, Az
    :notsure:
    I just got it as flat as possible. Technically your probably right but i dont know if they are held together on the inside in any way?
  14. Aug 29, 2013 at 7:14 AM
    #1934
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i got a text from a friend yesterday saying he was getting his pinch rewelded because it split after he cut it. i've never seen that happen in person, but it got me thinking. i'm just going to be cautous when i'm cutting i guess....
  15. Aug 29, 2013 at 7:27 AM
    #1935
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    digging your method!
  16. Aug 29, 2013 at 7:32 AM
    #1936
    BradyT88
    BradyT88 Well-Known Member
    RCtoy has a 1st gen with an S/C and snorkel. Mr.TRD just put his S/C on but was having problems with it collapsing the snorkel under high loads so he unhooked it, not sure if he has fixed that or not yet. And whenever n0rth gets around to installing his S/C (assuming he leaves the snorkel on) he will also be setup that way. Not sure that any of those 3 guys are very concerned with MPG's though.
  17. Aug 29, 2013 at 7:35 AM
    #1937
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    how the hell do you collapse a snorkel?!?! :eek:
    you talking about the rubber elbow?
  18. Aug 29, 2013 at 7:35 AM
    #1938
    BradyT88
    I did the same thing, only I alternated the folds. Then I beat the piss out of the whole thing to push it all back.
  19. Aug 29, 2013 at 7:36 AM
    #1939
    BradyT88
    Yeah. It would squeeze shut on him because S/C couldn't get enough air fast enough. That was all on a stock setup TRD S/C with just the TRD flash.
  20. Aug 29, 2013 at 7:38 AM
    #1940
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    time for some snorkel modification. cut that elbow out and modify the connection between the snorkel and airbox.
