Colinb17's kinda sorta build thread
Discussion in '2nd Gen. Builds (2005-2015)' started by colinb17, Jun 24, 2011.
  1. Nov 12, 2013 at 3:53 PM
    #3321
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    That's only for the red bull resis
  2. Nov 12, 2013 at 5:48 PM
    #3322
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    FR&R?
    drilled a hole
    typically a solid option
    i'll dig around and see if I have some
  3. Nov 12, 2013 at 5:53 PM
    #3323
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
  4. Nov 12, 2013 at 6:06 PM
    #3324
    BradyT88
    BradyT88 Well-Known Member
    Yep! They post some awesome pics!
  5. Nov 12, 2013 at 7:38 PM
    #3325
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    indeed they do. a lot of European and sout American rigs recently. i love that kind of stuff. fun to see how differently people approach the sport in different parts of the world
  6. Nov 12, 2013 at 8:01 PM
    #3326
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    only shot i have
  7. Nov 12, 2013 at 8:38 PM
    #3327
    BradyT88
    Shit man, do you even have a cab mount left!!!!?:eek:
  8. Nov 12, 2013 at 9:06 PM
    #3328
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    with out setups, the wheel backspacing won't make you rub the cab mount more or less really. it'll just change where on the tire the cab mount rubs. more backspacing will have it rubbing closer to the outside of the tread, and less backspacing will have it rubbing towards the center of the tread.
    probably just wait till LT and then go nuts and 1/4'' plate it when clearance isn't really an issue anymore.
  9. Nov 12, 2013 at 9:07 PM
    #3329
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    oh and it's trimmed a little more than in that picture now that I think about it. that picture was from back in Kansas. I trimmed it a little more at rich's house the weekend before barnwell.
  10. Nov 13, 2013 at 5:57 AM
    #3330
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Singlecabguy-
    Just take the coilover out and stuff the tire, turn lock to lock and remove/trim EVERYTHING that rubs. That is the proper way to clearance.
    They never made it over to TW...from TTORA build thread on the IN board (from 5/2012):
    Gray stuff is seam sealer. Fenderwells were welded in then sealed completely.
  11. Nov 13, 2013 at 6:05 AM
    #3331
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Mark, i was talking with former member Johnw yesterday and refferred him to your build. he's fitting 37s on a stock length arm setup (next week i think) and was asking me if i forsaw any issues other than the obvious. he already has fiberglass fronts, and has a spindle lift. i said that the spindle lift, which moves the hubs both down and out may be his saving grace. i think they're 2'' spindles, which mathematically would make me think that fitting 37s would be as easy as fitting 33s, in regards to fender well clearance. figured he may be able to get away with a couple slaps of the sledge and be good. he's on 35s now, so the cab mount is already taken care of. thoughts?
  12. Nov 13, 2013 at 6:27 AM
    #3332
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Everything I did to fit 37's [at the firewall] the average Joe needs to do to properly fit 35's since my LT moved the spindle 1" forward. As for vertical travel he won't have much to do if he has lift spindles.
    I was able to push the firewall back a good 2" with a BFH and cutting/removing parts. I moved it so much the interior kick panels no longer fit properly and had to remove a bunch of material from them as well. Also said bye-bye to the dummy pedal.
  13. Nov 13, 2013 at 6:50 AM
    #3333
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    he's got total chaos lowers. i'm not sure if they move the hub forward or not. if so, it sounds like he's going to get off extremely easy. if not, he may may be in for some serious firewall work.
  14. Nov 13, 2013 at 3:53 PM
    #3334
    xweslingx
    xweslingx Well-Known Member
    Wes
    Durham, NC
    09DCSB locked and armored
    Just gussets... everywhere
    Will be doing this in the next few weeks let's see.
  15. Nov 16, 2013 at 6:30 AM
    #3335
    xweslingx
    Wes
    Durham, NC
    Hey Colin, you have any complaints from your EBC rotors? I was looking into the powerstop cross drilled and slotted ones from wheelers but I'm seeing a few people have the EBC brand.
  16. Nov 17, 2013 at 5:12 PM
    #3336
    Delmarva
    Tucson, AZ
    Quit humping your tire
  17. Nov 17, 2013 at 5:29 PM
    #3337
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    That's the only action he can get though Mike.
  18. Nov 18, 2013 at 8:29 AM
    #3338
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    zero complaints with mine. i'm on ebc dimpled and slitted rotors, and the green stuff pads. they held their own when i pulled a 6500 lb boat/trailer 900 miles from VA to FL, and i later came to find that a hydraulic line on the trailer brakes had blown before i even left, so it make that hole trip without trailer brakes. they stop the 35s effectively, but it does take a noticable amount of more pressure to stop quickly. they'll still lock of the tires though.
    that being said, i'll probably go with the yellow stuff pads next. more agressive pad that should stop a little better. they won't last as long as the greens, but pads are pretty darn cheap, so i'm not concernted about that.
    looks like a tight fit....
    you're either fatter than me, or need more travel. probably the second......though the first would be funny :D
    watch your mouth boy, i did not! i respect my tires.....therfore i made love to them.
  19. Nov 18, 2013 at 10:01 AM
    #3339
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    replaced the center pins this weekend. the other one looked just like this, with the addition of being sheared in two....
    good times.
  20. Nov 18, 2013 at 10:03 AM
    #3340
    BradyT88
    You did it with 35's though and Colin did it with 33's didn't he? That gave him some extra room. haha
